Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
I just replaced the piston ring on my poulan chainsaw it now has good compression but im not getting any gas to the piston area and if i shoot starting fluid to it. it dont even hit and try to start. i have checked and it is firing.
  • 211 Answers
The engine is not sealed properly
check the gasket(seal glue)at crankshaft and other gaskets
check the carburator,clean it,inside there is a fine gas filter,check the needle,the diafragm,the fuel pump,the gas tube from the gas tank and the gas filter from inside the tank.
regards Mihai71
Posted on Nov 28, 2008
I just rebuilt my poulan will not start now. Getting fuel and spark I can't seem to find a head gasket So i used silicone which looked to be what was used before. New head new piston & ring new carb
if you have fuel & spark there is only one thing missing and that's compression. Probably because you have no head gasket. Try to check the compression to see if it's good.
Apr 02, 2016 | Poulan Garden
It is getting fuel but has a weak spark and will not start.
DO NOT , I repeat do not use starting fluid on a 2 stroke chainsaw or trimmer. you will score the cylinder or the piston. When trying to diagnose a hard to start motor just give it a small squirt of mix in the carburetor. If it won't fire you have a compression problem or an ignition problem. when you test for spark make sure you have a good plug, that is well grounded and not in bright sunlight which can make it hard to see the spark. if you have spark, do a compression test.
Mar 19, 2015 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Compression test on poulan pro chain saw
Yes, but 100 or lower and you need to think about ring and/or cylinder, piston and ring set.
Jul 27, 2014 | Poulan Pro PP4218AVX 18-Inch 42cc 2-Cycle...
My poulan pro 295 has very low compression what do i need to do to fix it
Its either seized, or the rings are worn, either way you need to remove the cylinder to see just what has happened, if there is scuffing on the exhaust side of the piston, it will require a new piston, if the cylinder wall will not clean up well enough it will need a cylinder as well, if there is no scuffing replace the piston ring,
Dec 15, 2013 | Poulan Pro Chain Saw 46cc 20"
I have a wild thing 2375. Was running one day,shut itself off,and has never fired or started since. It has compression,fuel,spark,but will not so much as even pop. Not even on ether. Even local chainsaw...
In my experiance with two-cycles that have spark and fuel usually the missing ingredient is not enough compression. Try taking the piston out of the cylinder and check the condition of the piston ring and cylinder wall. The piston ring cannot be broken, collapsed or 'welded' to the piston which can happen if the saw is run on straight gas. The cylinder wall cannot be scored at all to get the compression levels required for gas with oil mixed in it to burn. One other possibility is that your spark isn't hot enough. Possibly caused by a small piece of carbon stuck in the spark plug or a bad ignition module.
Mar 05, 2012 | Poulan Garden
Lost compression in saw what couuld bee problem
The piston has probably scuffed in the cylinder, this then traps the rings in causing loss of compression, this will require an engine rebuild and possible cylinder/piston replacment.
Jun 11, 2011 | Poulan Garden
Can't get weed eater started. Have an older weed eater brand. Fuel is getting to engine, but can't get it to start. How do I adjust the carb to get it to start. I have cleaned everything out and have the...
This is a common problem on older Poulan models. Press the primer button 10 times and pull the starter rope twice, then pull the spark plug and examine it. If the plug is wet that means gas is definitely getting to the combustion chamber. Next thing is to use a compression tester. If you do not have a compression tester but have an AutoZone anywhere near you, you can get a loaner from them. Screw the compression tester into the plug hole and pull the start rope 4 times. If the tester reads anything below 90psi, you have a bad ring and will have to take the motor apart to clean the piston and ring or replace the ring.
Keep me posted on what you find, ok? I can walk you through the procedure to replace the ring if necessary. Good Luck!
Sep 17, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Poulan/Weed Eater No. Bvm200le kills when taking it off choke or giving it gas.
Most likely low compression caused by stuck piston rings or a scored piston and cylinder. This unit was made by Poulan and they have had an epidemic of this problem. The solution is to tear the unit down and put in new piston rings. Before you install the new rings you need to get a sheet of glass and some 600 grit wet dry sand paper. Sand each ring down about .002 to .003 and reinstall. This should solve your problem as long as you have good fire and the piston and cylinder is not scored.
You might also need to rebuild the carb.
Sep 12, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Engine pulls over good, without spark plug in , but very hard to
nope the rod will not stretch.did you put the piston on backwards.ring openings go to the intake side of piston
Jan 03, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My Poulan saw will not fire
Hi
Check if the gas tank cap vent is plugged.Check if the flyweel key is sheared(ignition timing point).Check the fuel filter and air filter.
Hope this helps.
best regards savumihai71
Dec 15, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
101 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
