Question about GE Profile Spectra JGBP90 Gas Kitchen Range
I just conveted my ge gas range model #JGBP85CEJ2CC. how do i calibrate the oven
  • 833 Answers
I assume you mean converted.  Changing the gas supply from natural to LP or vice versa should not change the temperature calibration settings. Most manuals have a compensation method for their units within them, should you suspect your temperature dial is out of range.  Get a small oven thermometer, put it in the oven, run at a known setting...say 350 and read what the gauge says after 15 minutes.
Your manual can be found on the GE site under http://www.geappliances.com/service_and_support/literature/
Posted on Nov 26, 2008
Ge model jb400d oven will not heat up
Troubleshooting Why Your Gas Oven Won't Ignite or Heat ...
? 4:39
https://www.youtube.com/watch?v=Oe0BJmXhh7M
Dec 20, 2012 - Uploaded by PartSelect
Remember, parts are specific to your model and the ones shown t. ... Range/Stove/Oven Repair - Replacing ...
Gas Oven Won't Heat - How to Repair (Part 1 of 2 ... - YouTube
? 9:20
https://www.youtube.com/watch?v=sHWRRMrIpfU
Jan 29, 2012 - Uploaded by Tomahawk DIY
If I order on ebay for ge gas range oven ignitor do they as formodel #? .... removed the entire gas tube with ...
GE, Hotpoint & RCA - Wall Oven Diagnostic - Not heating ...
? 11:16
https://www.youtube.com/watch?v=BQNs4gHlT_A
Jun 13, 2013 - Uploaded by ApplianceVideo.com
Fix a GE Wall Oven which has some of the following dilemmas:Not heating By ... GE, Hotpoint & RCA ..
Dec 30, 2015 | GE Kitchen Ranges
My Frigidaire FGFL67DBF gas oven does not reach the temperature set. I tried to calibrating the control, but it did not work. Any suggestions?
I believe that you have a convection oven.... by design, convection ovens built by GE come up to temperature....at 25 degrees below the set level .... when the Convection function is enabled.
Oct 15, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
My GE Profile Spectra oven is taking approximately 10-15 minutes to preheat to 350 degrees and does not seem to fully bake food as per instructions. It takes an extra 5 to 20 minutes to bake anything. ...
18 mins from room temp to 350 is factory standard,
you may need to calibrate the range, most now adays come factory set at -25 degrees for safety
depending on your model number in your instruction manuel should be a part about recalibrating it sounds like your about 25 degrees off
Oct 02, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Claibrating the temperature of a GE gas oven
5 degree increments from factory setting
1 is +5
2+10
and so on
Apr 12, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Temperature is wrong
Many ranges show a beginning temperature that is higher than actual temperature, then the gap closes as it heats up.
Use a accurate oven thermometer to check your temps.
If it is faulty, it will not recalibrate to offset 200 degrees. You will have to replace the ERC.
Mar 20, 2009 | GE 24" Built-In Single Gas Wall Oven
Oven temp control not working
you need to calibrate the oven.
go to this web site
http://genet.geappliances.com/geasearch/Dispatcher?REQUEST=GETSEARCHRESULT
the second in the list is your solution
Dec 02, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Gas Range, serial at235522p, model JGBP79WEW1WW
If this is a newer range, the instructions to recalibrate should be in the manual that came with the stove
Sep 27, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven Temperature Sensor
it's just not just the sensor ,it's the thermostat which is on the back of oven knob. that sensor is part of the thermostat it's all one of the same part. to check the temperature put a thermometer inside the oven and set the the oven knob at 200 degrees. 20 minutes later check and see what temperature it's inside the oven, to regulate the temperature many of the new ovens are set from the factory, It can not be calibrate, on the older ones the adjustment screw is inside the shaft when you take the oven knob of, it's inside the shaft.
Apr 04, 2008 | GE JGBP28 Gas Kitchen Range
Calibration
Electric ovens are calibrated behind the temp knob. Pull the knob straight off of the shaft and look at the back of the knob. There should be a metal slide with a scale and a little set screw. Loosen the screw and move the slide in the direction indicated for your needs.
Mar 06, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
First of all, do not use the oven thermometers from a grocery store. they can be off by 20 degrees or more. These directions may help you for electronically controlled ovens. The older manually controlled ovens have a small screw head in the center of the oven temperature knob that can be adjusted in usually 10 degree increments.
To Adjust the Thermostat
Touch the Bake and Broil Hi/Lo pads
at the same time for 3 seconds until the
display shows SF.
Touch the Bake pad. A two digit number
shows in the display.
Touch Bake once to decrease (-)
the oven temperature, or twice to
increase (+).
The oven temperature can be adjusted
up as much as 35°F. or down as much
as 35°F. Touch the number pads the
same way you read them. For example,
to change the oven temperature 15°F,
touch 1 and 5.
When you have made the adjustment,
touch the Start pad to go back to the
time of day display. Use your oven as
you would normally.
NOTE: The thermostat adjustment for Baking
will also affect Convection Baking or Convection Roasting.
Nov 22, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
200 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
