Question about Pioneer PRO-99 TV
CUT OFF TO STANBY
When this monitor shut down it made a loud noise thru the speakers. This this did not happen but once or twice a day but I had to get up and turn it back on with the front power switch. Today I turned it on and it clicked 2 times (power relay) but no pic or sound. I took the front off and blew out a lot of dust. Took off the back and looked I saw no burned or exces heat signs the two ceramic resisters (15k ohm were very hot to the touch. I could see the input selections on screen like ch 13 sat vcr ect different colors. I tried unpluging ect. It seems to power up but no pic or sound from game, satellite or antenna. Then it would cut off to stanby.
  • sandyspur Dec 24, 2007
    same problem. Worked last night. Had a power outage (tv is plugged into quality surge protector) and not today it turns on, but stays in standby mode.
    Genius:
  • 1,694 Answers
See Speargunner Oct.26,2007.................................T.
Posted on Nov 15, 2007
SOURCE:
My ViewSonic 2230wm made a loud noise as it flicked once and shut off forever.
Getting the parts needed and repairing this monitor would probably not be cost effective. If nothing happens when you try to turn it on (i.e. no lights or LEDs come on) then it probably is the power suppley circuitry that is failing. If you are technically capable, you could remove the covers and look for a blown capacitor (the loud bang sounds like a capacitor).
Feb 12, 2014 | ViewSonic Computers & Internet
Hi, At least once a day when I'm driving I hear a loud banging noise (clunk). It only happens once, but when it happens you feel it under the passenger side. The noise only happens when I'm dr
I had a noise like that once in a full size van it turned out to be the ball joints onthe passenger side might want to get them checked it could have been fatal for us
Nov 02, 2012 | Toyota HiAce Cars & Trucks
Speakers had a buzzing/vibrating noise. had them replaced. still making same noise. happens on very low and loud volume. any idea what it could be? possibly the sound board?
maybe just poor speakers.....had a similar problem with an old sony. Replaced the speakers twice and always had a noticeable buzzing. Try running external speakers (computer speakers will work) at low volume to see if you hear it in those. If so, you may have sound board issue.
Jan 03, 2011 | LG 37LG30 37 in. LCD HDTV
LCD HDTV turns off, displays lines & static w/ loud noises
check in your manual and follow instructions on updating the software. you download the file to computer then move it to a memory stick (USB), then simply insert it into the tv
Mar 01, 2010 | Televison & Video
Surround sound not working
Bad DSP board (digital signal processing board)- a common problem for Denon receivers. Hope you have a warranty.
Apr 06, 2009 | Denon AVR-4306 Receiver
Speakers cut out and make a loud pop noise shortly after turning on stereo. It was intermittent and if it did happen it took around at least 45 minutes to do so but now only takes a couple minutes for it...
usually a pop means the speaker is damaged in some way
first test the jaclks or plugs into the speakers
the earths
then pull boxing apart
to visually inspect the speaker membrane
Mar 01, 2017 | Audio Players & Recorders
RX-V2600 shuts down
Try checking your speaker impedance. If you have 6 ohm or 8 ohm speakers make sure the impedence matches. On the front panel hold down button that says "straight effect" while pressing Stanby/On button, it will default to SP IMP 8 min, press straight effect again, if you have 6 ohm speakers, then press Standby again to exit setting. Also, double check your speaker wires to make sure they are all connected, and none are loose.
I hope this helps.
Mar 31, 2009 | Yamaha RX-V2600 Receiver
Speakers have hissing noise coming out of them
Hook a graphic equalizer between the piano and speakers, and turn down all sliders above 8 kHz. Since the highest note of a piano is 4186 Hz (4.186 kHz), you'll still hear all the notes but cut the hiss. If the hiss is coming from the speaker's power amplifier (in which case the equalizer won't help), turn down the speaker volume and turn up the piano volume. Live instruments generally need some doctoring to sound good through high-quality stereo equipment, as they only produce a limited range of frequencies whereas good speakers reproduce a lot more - including hiss.
Dec 25, 2008 | Onkyo GX-D90 Main / Stereo Speaker
Audio noise while car is on no prob in past
I've had that same problem before. What was happening is one of my amps safety cut off usually a built in surge protector basically, was coming on thus the loud thump. Most of the time when it comes on the amp goes off. Could be a power issue as well. Have your alternator checked too. Once your car is started it is run by your altenator so it could not being supply enough power. I fixed my problem by adding two 1 fared capacitor, one for each amp I was running.
May 20, 2008 | Car Audio & Video
Denon AVR -1905 made a loud popping noise, now doesn't stay on
The output section has smoked and requires repair. The unit is not in "protect" mode. This means that the outputs are turned off to prevent additional damage to either the amp or the speakers. Expect a repair to run from $15-$40 in parts plus the local labor rate.
Dan
Mar 26, 2008 | Denon AVR-1905 Receiver
Televison & Video Logo
139 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
