Question about Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA iP4000 has five cartridges 6BLK,e3BLK,6y,6m,6c
Black inkcartridges tracks are cloggedup and canoot print Black. I have used cleaning cartridges for e3Black and all tree colour but the black does not print.
  • ARJUN C CHEVLI Dec 09, 2008
    I have tried the cleaning cartridges to clean clogging but it did not work. Thanks.
  • joanmk_5 Dec 26, 2008
    My 3eBK cartridge print results have blank horizontal lines throughout. You recommend putting Windex in the tank and then running the cleaning process. What is the "tank"? Thank you.
  • 3 Answers
You may want to puschace and use a cleaning cartridge but positive results are not guaranteed. It depend how bad your print head is clogged.
The cost is about $5.
Google it (canon printer cleaning cartridge)
Posted on Dec 06, 2008
  • yousseph1 Dec 09, 2008
    I am afraid that you might need a new print head if the cleaning cartridge did not work.
    Please note that I did not purchase the cleaning cartridge instead I filled up my tank with Windex ( yes Windex) using a needle to fill the tank but then make sure to seal it using a glue or tape. My printer worked fine after I did 3 cleaning then 1 deep cleaning. Good luck.
    BTW are you using original canon ink because some people have issue not using the original canon ink. Mine is using none canon ink actually I am using edible ink ( The worst ink you can use to print and the best way to damage your print head fast but I must use it for my bakery shop).
    Good luck using Windex because it worked with me ( no joke).
In my pixma ip2772,when I print photo then black colors are printing properly but when I print any types of documents then my black color is not working.It's not showing dark.What can I do?
This printer has a separate cartridge for black and colour. When you print pictures, the printer uses all three colours mixed together to make black and does not use the black cartridge. Your black cartridge may be empty or the printhead may just be dried out. Try a head-clean from the maintenance menu and then print a nozzle test. If still no result then try replacing the black cartridge with a new one which has a new printhead as part of the cartridge.
Apr 14, 2015 | Office Equipment & Supplies
Get the esp 2170 to not print light green instead of black ? I keep on replacing cartridge , to no avail !
replacing a cartridge, while the nozzles are blocked won't help.
Realise the printer will mix there colours to get "black" on the paper. So even a full cartridge, can't make the other colours black till the blockage is gone.
Please try this. If you have ink cleaning fluid, (only for printer ink) use that, if you dont have cleaning fluid, use clean water.
Open the printer as if you replace a cartridge. Remove the black one and look tot the bottom of the cartridge holder. There is a little pipe, where the ink should go in. put some drops water or cleaning fluid in there leave it a few minutes. with a tissue dry it and again insert some drops of water or cleaning fluid. Then put in a cartridge and give the printer a black and white print job. Like print a few A4 papers. Let it print till the black comes back. Can take up to 4 pages A4. I hope this will unblock the nozzles.
Please even if you don't need to print, switch the printer on at least once a week. And even better, let it do a bit of printing every week. This will save a lot of frustration.
Dec 03, 2014 | Kodak ESP Office Equipment & Supplies
Why is my dcp135c printing images in brown instead of black
Several probable causes of this.
  1. Your Black is empty and the printer is trying to approximate the Black using the other colours. Check and replace Black.
  2. Your Black printhead is blocked and all you are seeing is the other colours that are used to make the black into a full black. Check cartridge and do a printhead clean to see if this clears it. Also print off a print quality test sheet (In the Ink Management options on the printer)
  3. Another colour has been put into the Black Slot on your printer. Replace the incorrect cartridge and hope that the printhead has not been damaged by using the wrong cartridge. May need several printhead cleans to clear incorrect ink from the feed lines.
Hope this helps.
Oct 07, 2014 | Brother DCP-135C Flatbed Digital MFC...
Have hp d1430 printer, I only use the color print cartridge, the printer will print color but will no print normal black lettering, have tried two different hP22 cartridges. Is the printer done for?
YOU SHOULD USE HP 21 BLACK INK CARTRIDGE FOR BLACK PRINTING.IF YOU USE 22 COLOUR CARTRIDGE YOU WILL GET ONLY GREAY PRINTING ONLY.I AM RIGHT?IF YOU USE COLOUR CARTRIDGES MAY YOU WILL GET MONEY LOSE. BECOS IT WILL FINISH EARLY.BLACK INK COST IS LESSTHAN COLOUR INK CARTRIDGES. SO YOU SHOULD BUY BLACK CARTRIDGE FOR REAL BLACK PRINTING.
Jun 29, 2011 | HP Deskjet D1430 InkJet Printer
IP3300 doesnt recognise the inkcartridges-service error 6502
could you please confirm that all the stick stuff is off the chip on the cartridge, and check the pins on the printer side were the cartridge fits is clean.
Jun 30, 2017 | OEM Systems PIXMA iP3300 Photo Printer
I recently replaced the black ink cartridge and do not wish to use the colour cartridge. However, the printer still keeps flashing the critically low level of my colour cartridge and does not print.How can...
Many printers always use a small amount of each color even if you are only printing black, to prevent the color nozzles from drying out and getting clogged (and, it forces you to buy more ink, which is a profit center for printer manufacturers)
For this reason, some printers will not work if ANY of the cartridges are empty.
It should work again if you replace the color cartridge. Make sure to select "black ink only" or the option to print in black and white or grayscale to minimize color ink usage. It may still use a little, but that's OK.
Apr 07, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Black inkcartridge doesn't show
Since your printer is new, is should be covered under guarantee. Please take it back to your dealer, he should swop it out. Alternatively you can arrange a replacement from Lexmark direct through their website.
Feb 28, 2010 | Lexmark X6675 Pro Colour Wireless...
Non printing epson c20ux
Sounds like color cartridge ran out. Were u using color to print black?
Try new color cartridge.
Then if you don't need color go in and set to use black cartridge to print black (text).
If you need color on something only takes a minute to turn color back on.
Since printer worked you can go in and select black which uses the black cartridge and if it prints gives validity to a bad/empty color cartridge.
Good luck.
JC
Nov 27, 2008 | Epson Stylus C20UX InkJet Printer
Won't print black
I found a solution to the Black printing problem :)
Under Printing Preferences: Set your Media Type to Photo Paper Pro.
We used edible ink cartridges and printed onto icing sugar paper. Same old... Just one day it refused to print black. In order to continue our small business, I degraded the color until I printed gray and not black.
Tonight, I browsed for the problem and came across this :)
Hope it helps you too
Nov 22, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
My Lexmarkx1270 will not print any black text etc
Is it a new cartridge? If the cartridge has been sitting a while it can get clogged. Try using a moist paper towel and gently wiping the cartridge where the ink comes out.
You could also try running the Lexmark Solutions Center program and use the clean nozzles option to force it to squirt out some black ink.
Nov 19, 2007 | Lexmark X1270 All-In-One InkJet Printer
Canon PIXMA iP4000 InkJet Photo Printer Logo
193 people viewed this question
old marine
old marine
