Question about Jenn-Air JJW8530C Expressions Collection Dual Single Oven
Alarm continusly dings and display is blank.
This is a Jenn-Air model JJW5830BAW. The display was getting very dim. I disconneted the front panel wire plugs and reconnected. Now the display is blank and the alarm continously dings. I turned off breaker to oven.
  • 833 Answers
Spencer...I hope you did this with the power off! First, disconnect all connections and reconnect them. You may have forced a connector. Likely the board is blown...the display and microprocessor are closely connected.
Posted on Dec 07, 2007
Oven digital lighted display is dim
You need to replace the C3 capacitor on the control board
http://fixitnow.com/wp/2009/01/28/cheap-fix-for-a-dim-display-on-an-oven-control-panel/
You can replace only the C3 - it is 68uF / 35V and you can go to Radio Shack and get their part # 272-1028 - 100uF/35V one. It takes all but 10 minutes to re-solder the new one in place
May 31, 2009 | Jenn-Air JJW8530C Expressions Collection...
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
Display on my Jenn-Air electric wall oven is very dim
douglas9101,
I had the same problem and found the solution on-line.
Replace the C3 capacitor on the dispaly module. (100 UF, 35 volt, high temperature)
The local Jenn Air dealer wanted $211 for a new display module.
I purchased a Cap from a local electronics supply store for 79cents.
The only problem is that you need to have a soldering pencil/iron, a solder ******/wick and a small amount of solder.
Steps I had to take on my oven:
- Flip the AC breaker supplying the oven to off to be save
- remove 3 screws on top and 4 on the bottom of the display panel
- gently pull out the display panel and unplug the 2 cables to the display
- unclip the ribbon cable to the display module
- unclip the module itself by pushing on the 2 black tabs
- locate C3
- unsolder C3 and replace with new Cap- keeping the polarity strip the same as theh old Cap
- reasemble in reverse order.
It took me all of 20 minutes. It may sound difficult but is very easy if you have the tools
Good Luck
K
May 11, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
I replaced the C3 capacitor on the circuit board and works fine. This was mentioned in a prior post and took 5 minutes and was under $5.00 for the part.
Nov 27, 2008 | Jenn-Air JJW8530C Expressions Collection...
The light and temperature display are very dim and hard to see.
We own a Jenn-Aire model W27400W oven. The display module has gradually gone dim over a period of several months prior to the end of the warranty, and the display is no longer visible. It is apparent that several Jenn-Aire oven models use the same display. Does Anyone else have the same problem, and If so, are they willing to join a class-action suit against Jenn-Aire with us?
Steve Patterson
303-256-8494
stevieb4019@comcast.net
Nov 23, 2008 | Jenn-Air JJW8230D Electric Double Oven
Jenn Air JMW8530CAB time/temperature light don't work
Steve Patterson
303-256-8494
Nov 18, 2008 | Jenn-Air JMW8530C Electric Double Oven
No display, No beeps, No heat
I was able to fix my problem by pushing the setup button and holding for about 10 sec.No where in the manual is this described. I call Jenn air and all they could suggest is that I checked the power supply!
Jul 15, 2008 | Jenn-Air JJW8530C Expressions Collection...
Display blank
Every time I have seen this problem, it has been a bad display assembly. These are fairly easy to change yourself, but the part is kind of expensive, I think in the $150-$200 range. Hope this helps!
Aug 21, 2006 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air JJW8530C Expressions Collection Dual Single Oven Logo
305 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
