Question about Starbucks Saeco Italia Digital Barista Coffee Machine
When i turn the machine on and try to grind up some coffee beans, the machine makes a sound like the motor is trying to grind. when i open up the grinder lid, i can see that the grinder is spinning but nothing is getting ground. then the sound will stop and "Grinder empty" button will light but the grinder has plenty of coffee beans in it. how do i fix this problem?
  • 833 Answers
Generally, coffee beans are oily and form a goo in these machines.  You may get lucky by first unplugging the machine, getting some copper wire (#14 or #12) and poking around in there to loosen the crud up.  If this doesn't work, the unit will have to be disassembled and cleaned.  Messy!
Posted on Nov 26, 2008
Makes funny noise when I try to grind coffee and no ground coffee comes down into the handle. Seems like something is stuck in the grinder.
if you hear it trying to grind, but is not, or hear it spinning and is not grinding, more than likely it is blocked, or so oily that bean will not drop. Coffee beans, have so much oils in them, that after a while it gets caked up, and beans either get jammed, or stuck. If you hear grinder low humming, then it is probably stuck or clogged, if it is on but hear like a spinning sound, beans are not dropping, because they are stuck because of oil build up. If you can get to the grinder, turn machine off, unplug, get all beans out, take like a wooden chop stick and put it in area where beans go and move the chop stick around the gears. you like your reaming it out kind of. turn machine back on, try this procedure a few times. ( MAKE SURE MACHINE IS UNPLUGGED WHEN DOING THIS) As said early if it is a low humming, like motor turning but jammed, do not use until jam is fixed, you will burn up motor, then have more expensive fix. Let me know if this helped and solved problem. Mr Bean Man from Fixya
Jun 12, 2011 | Breville BES860XL
The grinder runs but does not grind the coffee beans
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
Nov 12, 2009 | Saeco Royal Professional Espresso Machine
Coffee beans don't grind even though there are beans in the hopper. Message: empty coffee beans. Grinder turns, but doesn't sound like the beans are going through.
Sounds like you have a blockage in you grind passage. Try removing the brew group. Then inside on the roof of the machine where the brew unit was setting there is a drop chute where the coffee is dropped into the brew unit. From the left side of the drop chute pull down and back, and it will drop coffee. This will clear an opening that relieves pressure on the passage. There is a passage inside the drop chute area that goes to the grinder. Vacuum it out. It will be on the right side of the drop chute.
Once that is cleared go to the bean hopper. There is a lever on the right side of the bean hopper. Push the lever back to the largest number. You can push the lever to a larger number any time but it has to be grinding to pull to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can pull back to a number that was higher than the one you had it on, but only when the grinder is running.
Nov 11, 2009 | Saeco Royal Professional Espresso Machine
I bought new green coffee beans recently, roasted it myself and wanted to use it in the machine but the grinder gets stuck and won't turn. The new beans are harder and smaller than the type I used to have....
Oct 21, 2009 | Gaggia Paros Espresso Machine
Hello. grinder won't grind
HI
Sounds like you have a blockage in you grind passage. Try removing the brew group. Then inside the machine where the brew unit was setting there is a drop chute where the coffee is dropped into the brew unit. This will be above where the brew unit was. From the left side of the drop chute pull down and back, and it will drop coffee. This will clear an opening that relieves pressure on the passage. There is a passage inside the drop chute area that goes to the grinder. Vacuum it out. It will be on the right side of the drop chute.
Once that is cleared go to the bean hopper. There are 2 knobs in the bean hopper. Turn the large knob to the largest number. You can turn the knob to a larger number any time but it has to be grinding to turn to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can turn the knob back to a number that was higher than the one you had it on, but only when the grinder is running.
Jul 24, 2009 | Gaggia Syncrony Espresso Machine
My A-9 Coffee grinder no longer grinds coffee. Have cleaned it and checked it out and nothing. The motor runs but no grounds. Thanks for your help!
Jul 21, 2009 | KitchenAid A-9 Electric Burr Grinder
I have a Divina Deluxe and the coffee grinder is moving but it does not appear to be grinding it justs runs until the cycle stops. The machine turns on and gets ready but not grind. I have opened it up and...
Remove brew unit and check the grounds chute from the grinder, if that is clear, then re-insert unit, then when the grinder is grinding adjust to a coarser grind.
May 31, 2009 | Spidem Divina De Luxe Espresso & Coffee...
The machine sounds like it is grinding the beans but it times out
Hi
1. Open the front door.
2. Remove the driptray and brew unit.
3. Above where the brew unit was is an L shaped flap with a plastic triangle molded to it.
4. Pull the triangle down and to the rear of the machine. This will dump ground coffee.
5. That is your doser box and if you look up when the flap is open you will see a rectangular open on the right that is plugged with coffee.
6. Clean this out. I use a vacuum and **** it out, but anything to open this up again.
7. Once it is clean, go to your bean hopper and turn the large knob to the hightest number.
8. Now replace everything and try it again.
9. If it makes coffee, GREAT.
10. Next time your grinder is grinding turn the big knob down to a number 2 above where you had it.
Apr 29, 2009 | Starbucks Saeco Italia Digital Barista...
The water is not adding to the ground beans , is it plugged?
I haven't seen a Vienna in a long time so I cannot remember if there is a door for preground coffee, if that option is there, open door and press button to make a coffee if you get water, then adjust the grind and dosage on the grinder and try the auto function.
Jan 17, 2009 | Saeco Vienna Digital Coffee Maker,...
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
183 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
eyecam
ray gallant
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
