Question about HP PSC 2210 All-In-One InkJet Printer
Can I replace the PSC2210 print cartridge hold down lever?
The black ink cartridge hold down lever broke on a PSC2210. I've used duct tape to try to hold the cartridge in the carriage, and duct tape on the spring end of the broken lever. I still get an error for the print cartridge. Any suggestions?
  • pieczko_mike Nov 26, 2008
    Thank you Bappa. I didn't see those parts available, do they need to come from another printer?
    Master:
  • 505 Answers
The entire unit which holds the cartridge needs to be replaced. get it dont by some local tech shop.
Thanks
Posted on Nov 26, 2008
  • Indrajit Roy
    Indrajit Roy Nov 26, 2008
    You can contact some local tech shop. At time they keep those parts from old printer for future use. You can also contact HP for the same.
    Thanks
HP 6520 keep getting lower photo tray error have to hold tray in to get it to print also getting ink error that a cartridge is damaged or paper jam? Wth it needs to decide what it wants! I've
That's a great printer but HP support can make your hair fall out.
Sounds like a misaligned sensor. Look for a micro switch probabably on the tom inside left. Tape that shut with duct tape and maybe a bit of cardboard. You can try to reposition it too, but there is little adjustment tolerance. If that doesn't take, it may require replacement. Working pulls for the hp's are inexpensive on eBay. You can also try to junction the leads together temporarily.
Nov 25, 2014 | HP Photosmart 6520 e-All-in-One -...
I am looking for a color access door for a print carriage on an hp psc2210 all in one printer. (C8654A)
  1. If you are putting in a new cartridge, make sure to remove the tape.
  2. Turn on the unit, then open the print carriage access door. The print carriage moves to the center of the unit.
  3. Fit the cartridge into the proper carriage.
    • The carriage with the gray latch is for the black ink cartridge (HP 56), or the optional photo cartridge (HP 58).
    • The carriage with the blue latch is for the tri-color cartridge (HP 57).
    Slide the cartridge into the carriage at a slight angle, as shown in the illustration above. When the cartridge is fully inserted into the carriage, rock it upright.
  4. Hold the hinged flap of the latch out while lowering the latch.
  5. When the latch is fully lowered, release the hinged flap. It should catch under the tabs on the carriage, as shown in the illustration.
  6. Close the cartridge access door.
  7. The LCD display may indicate that the cartridges need to be aligned. Press Enter on the front panel. You may discard the alignment page that prints.
Remove cartridges
  1. Turn on the unit, then open the print carriage access door. The print carriage moves to the center of the unit.
  2. Press down lightly on the top of each ink cartridge latch and pull the lower section of the latch out to release the cartridge.
  3. Pull the cartridge out of the print carriage and relatch the empty print carriage. The print carriage may move to the right automatically, and if the latch is up, it could be damaged.
Aug 23, 2011 | HP PSC 2210 All-In-One InkJet Printer
How to change the ink cartridge
Follow these instructions when you need to replace print cartridges.
• Everyday printing: Use a black cartridge along with a tri-color cartridge.
• Color photos: Use a photo cartridge along with a tri-color cartridge.
To replace the print cartridges
1. Make sure the HP All-in-One is on.
CAUTION: If the HP All-in-One is off when you open the print cartridge door to
access the print cartridges, the HP All-in-One will not release the cartridges for
changing. You might damage the HP All-in-One if the print cartridges are not
docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a print
cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from
the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge towards you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print cartridge,
store the black print cartridge in the print cartridge protector or an airtight plastic
container.
7. Remove the new print cartridge from its packaging and, being careful to touch only
the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Also, do
not re-tape the print cartridges. Doing so can result in clogs, ink failure, and bad
electrical connections.
8. Hold the print cartridge with the HP logo on top, and insert the new print cartridge into
the empty cartridge slot. Make sure you push the print cartridge in firmly until it snaps
into place.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
Jun 30, 2011 | HP PhotoSmart C4385 All-in-One Printer
I have the Dell AIO 926 and i have an Error Message. Error 1203 Consult User's Guide I cannot print, what do i do?
error 1203's error name is print head short which indicates a short circuit in the print head has occurred. solution to this problem is to disconnect and then reconnect the printer power cable. Reinstall the ink cartridges.For more information, see Replacing Ink Cartridges.
  • Turn on your printer.
  • Lift the printer unit, and then position the scanner support between the tabs to hold it open.
  • The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  • Press down on the ink cartridge lever to raise each ink cartridge lid.
    Remove the old ink cartridges.
  • Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them properly.
  • If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
    NOTE: The following illustration shows a black cartridge and a color cartridge (used for normal printing). For photo printing, use a photo cartridge and a color cartridge.
    Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.
    Snap each lid closed.
    Hold the printer unit up, push the scanner support back to unlock it, and then lower the printer unit until it is completely closed.
  • Jun 05, 2011 | Office Equipment & Supplies
    How do i change my lexmark x4650 print cartrige?
    Installing/Replacing your ink cartridges:
    1. Open the printer, and then press down on the cartridge carrier levers. printmastert_52.jpg
    2. Remove the used print cartridge or cartridges. 3. If you are installing new print cartridges, remove the tape from the back and bottom of the color cartridge, insert the cartridge in the right carrier, and then close the color cartridge carrier lid. 4. If a black cartridge is included in the box contents, remove the tape from the back and bottom of the black cartridge, insert the cartridge in the left carrier, and then close the black cartridge carrier lid. 5. Close the printer.
    Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
    1. Unplug the printer from the power source.
    2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
    3. Remove the used cartridges.
    4. Load the new cartridges. Close the cover.
    5. Plug the printer back to the power source.
    May 15, 2011 | Lexmark X4650 InkJet Printer
    Having trouble fitting new ink cartridge
    Hi, when an ink cartridge runs low in your HP Officejet 5610 All-in-One printer, you will see a message on the printer's display screen. Faded-looking text or pictures also indicate low ink. Ensure print quality by replacing ink cartridges when they run low.
    Instructions
    Things You'll Need:
    * HP #27 or #56 black, #22 color or #58 color photo print cartridge, or compatible equivalent
    Turn printer on if it is off. Never attempt to change the ink cartridge if the printer is off. If it is off, it will not properly position or release ink cartridges, and attempting to change the ink cartridges may damage the printer.
    Open the print-carriage door, located on the right side of the printer. The print carriage will automatically move into the access area.
    Push down on the top edge of the cartridge you are replacing to pop it out of its slot. Remove the print cartridge and discard or recycle.
    Pull off the protective tape on the new print cartridge using the pink tab. Do not touch any part of the cartridge except the black plastic. Touching the contacts or ink nozzles under the protective tape can damage the cartridge and result in poor print quality.
    Hold the cartridge upright and push gently forward into the empty ink cartridge slot until it clicks.
    Close the print-carriage door.
    You can also use this video clip to learn more:
    youtube.com/watch?v=wVXUndG-o_Q.
    Please don't forget to rate me thanks.
    Thanks for using fixya...
    Oct 26, 2010 | HP Officejet 5610 All-In-One InkJet...
    I changed the ink cartridge the black one but it still says cartridge empty I unplugged it and it still sais the same thing
    My MFC-420CN acts up occationally. Remove the new cartridge, hold it as you would to install it, Rotate it to the right about 45°. Snap it with the back of a finger (dislodges any air bubbles in ink feed). Reinstall cartridge (ensure it is fully seated. This works for both Brother cartridges and the eforcity cartridges I've been using for the past couple of years. HTH
    Lou
    Oct 17, 2009 | Brother MFC-685cw InkJet Printer
    The lever that holds ink cartride in place is broken
    take out the old cart'd, and get yourself some "loctite" power grab "red tape at walmart, insert the new cart'd and use the "loctite" at the top, allow it some time to "set up", and you should print a "test page", and you should be good to go, god bless
    May 29, 2009 | HP PhotoSmart 7760 InkJet Printer
    I changed my color cartridge #97 on my HP officejet 7310
    Remove the color cartridge. Make sure the contacts in the print carriage are clean. Chek to ensure the contacts on the cartridge are clean. Reinsert cartridge.
    Mar 20, 2009 | HP OfficeJet 7310 All-In-One InkJet...
    How to change black color inkonHp2175all in one
    Supported HP ink cartridge part numbers The HP PSC 2100, 2170, and 2200 all-in-one series products use the ink cartridges listed in the table below. The HP 58 tri-color photo ink cartridge replaces the black ink cartridge for six-ink photo printing. Ink cartridges Part number HP 56 black ink cartridge (19 ml) C6656A HP 57 tri-color ink cartridge (17 ml) C6657A HP 58 tri-color photo cartridge* (17 ml) C6658A HP 27 low capacity black ink cartridge (10 ml) C8727A HP 28 low capacity tri-color ink cartridge (8 ml) C8728A * Replaces the black ink cartridge for six ink photo printing and includes cartridge holder. Replacing the ink cartridges The power must be turned ON to the all-in-one or the print carriage will not come to the center.
    1. Locate and raise the print cartridge access door on the front of the unit, just above the output tray. The print cartridge carriage will move into the middle of the access area. Figure 1: Raising the front access door and the ink cartridge latches c00224418.jpg
    2. Press down lightly on the top of the ink cartridge latch of the ink cartridge to be replaced and then pull the lower section of the latch toward you to unlatch the ink cartridge.
    3. Grasping the sides of the ink cartridge, pull the cartridge toward you to remove it as shown in Figure 2. Figure 2: Removing the cartridge after raising the latch c00224419.jpg
    4. Remove the replacement cartridge from its packaging, and touching only the black plastic, gently remove any tape covering the nozzles. Do not touch the gold-colored contacts. Figure 3: Removing the protective tape c00224420.jpg
    5. Holding the ink cartridge with the printed label up, slide the cartridges one at a time into the print carriage as shown in Figure 4. The black ink cartridge (HP 56 or HP 27) goes on the right side (with the gray latch) and the tri-color cartridge (HP 57 or HP 28) goes on the left side (with the blue latch). If the optional photo cartridge (HP 58) is installed for six-ink photo printing, it is installed in place of the black ink cartridge. Figure 4: Inserting the cartridge c00224421.jpg
    6. Place your hand on the latch as shown in Figure 5, with the thumb pulling the end of the latch toward you. While holding the end of the latch out, press down on the top of the latch until it stops and then release the lower portion of the latch with your thumb so that it catches under the tabs. Do not force the latches into place or damage to the unit might occur. Close the all-in-one after latching the ink cartridges in place. Figure 5: Latching the ink cartridges in place c00224422.jpg
    7. Close the print cartridge access door.
    8. A message will appear in the front panel display requesting that the ink cartridges be aligned. Press ENTER on the front panel to start the cartridge alignment. Two pages will print. Following the instructions printed on the second page, place the first page on the scanner glass in the lower-right corner and then press ENTER to finish aligning the cartridges. Remove the page from the scanner glass when complete.
    Storing the option photo printing cartridge while not in use The optional photo print cartridge (HP 58) that may be purchased separately for six-ink photo printing includes an ink cartridge protector. The protector is designed to keep the photo cartridge from drying out when it is not in use and for holding and protecting the black cartridge when the photo cartridge is in use.
    • To insert a cartridge into the protector, slide it into the protector at a slight angle until it snaps in place.
    • To remove a cartridge from the protector, push down and back on the top of the protector to release the cartridge and then slide the cartridge out of the protector.
    Figure 6: Inserting and removing ink cartridges from the ink cartridge protector c00224423.jpg Fixing error messages that appear after changing a cartridge After inserting the cartridge, one of the following messages appears:
    • Check the black (or color) cartridge
    • Replace the black (or color) cartridge
    • The wrong black (or color) cartridge is installed
    These messages indicate that the ink cartridge is not making good electrical contact, is bad, or is the wrong cartridge. Complete the following steps to diagnose and correct the condition:
    1. Open the front of the unit to access the print cartridges (as shown in Figure 1).
    2. Remove the ink cartridge indicated in the message and inspect it.
    3. Verify that it is the correct part number and if it is, reinsert it.
    4. Close the lid to see if the problem is corrected.
    5. If the message is still displayed after a few seconds, remove the ink cartridge again.
    6. Unplug the power cord from the back of the unit.
    7. Clean the electrical contacts on the ink cartridge with a soft clean cloth, slightly dampened (not wet) with clean water. Each contact is very small and shaped like a rounded square. Figure 7: Cleaning the cartridge contacts c00224424.jpg
    8. Inside the HP all-in-one product, clean the contacts in the print carriage (the cartridge holder) with a clean cotton swab slightly dampened with clean water. Allow them to dry for five minutes before reinserting the cartridge(s) and turning on the printer. Figure 8: Contacts to be cleaned c00224425.jpg
    9. If the problem remains, replace the ink cartridge.
    10. If the problem still exists after trying all of the steps above, contact HP for assistance.
    Oct 13, 2008 | HP Office Equipment & Supplies
    HP PSC 2210 All-In-One InkJet Printer Logo
    61 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
