Question about Garmin StreetPilot C330 GPS Receiver
Garmin C330 resets itself
My C330 will power itself off and right back on after a few minutes of use, with the power cord attached or not. It will also power itself on, without being touched when the power cord is attached. Really need a schematic for it. I have avionics gurus who can help me if I had that. Thanks, T. Brady
  • mashline Jan 10, 2008
    I have the same problem. Did you get a resolution?
  • 174 Answers
The first problem with it powering itself off is a battery problem. Your battery is not hold a charge.
The second problem with it powering itself on with the power cord attached is a power cord issue. The unit is suppose to automatically power itself on if a power cord is attached to it. This is Garmin way of turning the unit on when you start your car. Most auto cigarette lighter will cut power if the ignition is off, and restore power when the ignition is on.
Garmin uses this to turn the unit on and off. If the unit was being powered by the the cigarette lighter then it say unit is shutting down in 20 seconds after the power is cut.
Posted on Jan 11, 2008
SOURCE:
Garmin won't turn on
I hope this helps, I had the same thing happen today. I noticed on the face under the word Garmin you can pop the face off and underneath on the right side is a reset button I held it down for 10 seconds popped the face back on and pressed the power button it came on. I hope this works for you.
Mar 20, 2009 | Garmin StreetPilot C330 GPS Receiver
My streetpilot c330 won"t shut off.
IT'S CALLED A FROZEN SCREEN...
2 OPTIONS
ONE, RESET IT !!! (See resetting instructions below)
TWO, let the battery die out!
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 12, 2009 | Garmin StreetPilot C330 GPS Receiver
Frozen screen screen is frozen and wont power off
2 OPTIONS
Feb 28, 2009 | Garmin StreetPilot C330 GPS Receiver
Street pilot c330
It took a nap...
Feb 21, 2009 | Garmin StreetPilot C330 GPS Receiver
Power dors not transfer thru the connection between the wire and unit on my c330 , it appears that a little gold wire has broken in the rubber mount.
It took a nap...
Feb 18, 2009 | Garmin StreetPilot C330 GPS Receiver
C330 wont turn on or power up
It took a nap...
Jan 22, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin c 340 froze- what do I do
This solution is for c330 but it should work the same...
It took a nap...
Jan 21, 2009 | Garmin StreetPilot C330 GPS Receiver
My navigon 2100 is frozen. how do i unfreeze it?
2 OPTIONS
Oct 25, 2008 | Garmin StreetPilot C330 GPS Receiver
Street pilot is dead
It took a nap...
Aug 30, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin freezes
2 OPTIONS
Jun 13, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
383 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
