Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
Food on dishes
My kitchenaid stainless steel with the black control panel dishwasher keeps leaving a lot of food debris on the glasses and inside the glasses, how do i fix this?
  • christina362 Nov 26, 2008
    I do rinse and scrape my dishes before placing them in the dishwasher. Does the dishwasher have a catch basin like a washing machine that needs to be empty so often and if so where is it located at?
  • 833 Answers
Dish washers are not good at removing food debris.  They filter the water somewhat but in the main, they recirculate whatever was on the plates when you put them in plus the detergent.  The rinse takes all grease and solubles away.  Scrape your dishes of as much as you can before putting them in.  Use a good detergent in the amount specified.
Posted on Nov 26, 2008
There is a rotten food smell coming from the dishwasher. How do I clean the food processor inside?
see this video how to clean the Dish. God bless you
http://www.ehow.com/video_4951790_clean-dishwasher.html
May 15, 2012 | KitchenAid 24 in. KUDI02IRBS Stainless...
My dishwasher is not cleaning my dishes well, leaving food and redisue on same, changed the knob for the dish rince hole, my wahser is only 2 yrs old,
Hi lacrick,
Please follow my below Tip on how to get the best results from your Dishwasher:
DISHWASHER NOT CLEANING WELL ANYMORE...
Kind Regards d")
JEDEMEYER1
* If this solution helped you, please rate it
Jul 31, 2011 | KitchenAid 24 in. KUDI02IRBS Stainless...
Leaving white residue on glasses and dishes
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Dec 24, 2010 | KitchenAid 24 in. KUDK02CRBS Stainless...
Mould on inside of washer
The water may not be heating up. Does the DW feel warm to the touch when it is washing? How long do you leave dirty dishes in the machine? Do you empty the clean dishes right away. If you do not you should open the door a crack to allow the steam and moisture to escape so the dishwasher can dry itself.Some people who don't have a lot of dishes don't wash them often enough and this can happen. You should inspect the inside of the diswasher for food debris build up even in the little holes of the arms, which you can pull out with needle nose tweezers.You can't use bleach to clean it. Nor any other household cleaners.I would clean it with very hot water mixed in a little bucket with some dishwasher detergent. You don't want to introduce any other kind of detergent into it. I would clean it thoroughly, using a semi rough washcloth then use a clean cloth to rinse it off with hot clear water. Then I would run a full cycle with no dishes in it.Maybe even twice. I hope this is helpful!
Dec 16, 2010 | KitchenAid 24 in. KUDI01ILBS Stainless...
Problem with dishwasher
inspect the drain, there may be debris in the drain system. While at it see if you can clean the unit. Normally food that had remained on the dishes would accumulate and start clogging the unit over time.
Jun 08, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Grit on the dishes. Foggy glasses. Blue type stain on the stainless flatware and the stainless inside of the dishwasher is very cloudy and streaked. Many areas inside the dishwasher feel gritty.
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
May 03, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Glasses and cups after cleaning spoted hard food particals .
There may be debris in the pump that needs cleaned out. I have put together some instructions on how to clean it out on this model if you care to try it out. It takes a bit of technical understand but it is not too difficult.
Let me know if it helps you out.
poor_cleaning_or_noisy_pump_KitchenAId
Apr 30, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
My kitchenaid dishwasher is not cleaning the dishes on the top rack well. It is nine years old.
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Jul 08, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Food left on dishes
Scrape your dishes of food.  Dishwashers remove whatever is left.
Nov 26, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
262 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
