Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
Food left on dishes
My Kitchenaid Stainless steel with black control panel dishwasher leaves all kinds of dried up food debris on the glasses and inside the glasses how do i fix this?
  • 833 Answers
Scrape your dishes of food.  Dishwashers remove whatever is left.
Posted on Nov 26, 2008
2 Suggested Answers
  • 833 Answers
SOURCE: food on dishes
Dish washers are not good at removing food debris.  They filter the water somewhat but in the main, they recirculate whatever was on the plates when you put them in plus the detergent.  The rinse takes all grease and solubles away.  Scrape your dishes of as much as you can before putting them in.  Use a good detergent in the amount specified.
My dishwasher is not cleaning my dishes well, leaving food and redisue on same, changed the knob for the dish rince hole, my wahser is only 2 yrs old,
Hi lacrick,
Please follow my below Tip on how to get the best results from your Dishwasher:
DISHWASHER NOT CLEANING WELL ANYMORE...
Kind Regards d")
JEDEMEYER1
* If this solution helped you, please rate it
Jul 31, 2011 | KitchenAid 24 in. KUDI02IRBS Stainless...
Mould on inside of washer
The water may not be heating up. Does the DW feel warm to the touch when it is washing? How long do you leave dirty dishes in the machine? Do you empty the clean dishes right away. If you do not you should open the door a crack to allow the steam and moisture to escape so the dishwasher can dry itself.Some people who don't have a lot of dishes don't wash them often enough and this can happen. You should inspect the inside of the diswasher for food debris build up even in the little holes of the arms, which you can pull out with needle nose tweezers.You can't use bleach to clean it. Nor any other household cleaners.I would clean it with very hot water mixed in a little bucket with some dishwasher detergent. You don't want to introduce any other kind of detergent into it. I would clean it thoroughly, using a semi rough washcloth then use a clean cloth to rinse it off with hot clear water. Then I would run a full cycle with no dishes in it.Maybe even twice. I hope this is helpful!
Dec 16, 2010 | KitchenAid 24 in. KUDI01ILBS Stainless...
Problem with dishwasher
inspect the drain, there may be debris in the drain system. While at it see if you can clean the unit. Normally food that had remained on the dishes would accumulate and start clogging the unit over time.
Jun 08, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Glasses and cups after cleaning spoted hard food particals .
There may be debris in the pump that needs cleaned out. I have put together some instructions on how to clean it out on this model if you care to try it out. It takes a bit of technical understand but it is not too difficult.
Let me know if it helps you out.
poor_cleaning_or_noisy_pump_KitchenAId
Apr 30, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishes on top are not coming clean-
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Dec 29, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
White film left on dishes, does not seem to be cleaning thoroughly
could be several things... usually it just needs rinse aid.. all dishwashers spot or leave dishes cloudy without rinse aid.. or your water is just to hard, in that case you will need to soften it with salt, check the owners manual to see how that is done.. also run the dishwasher right after you put the dishes in, if you leave them for a day to wait to fill it up then the dried food gets like cement.
Dec 01, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
My dishwasher leaves crumbs and food particles stuck to everything in the top rack
Usually this problem is due to the fact that the dirty particle filled water isn't fully draining and the unit is trying to rinse the dishes with fouled water thus baking any leftover food particles during the dry cycle.
Make sure that all of the water is draining from the dishwasher after all drain cycles.
Usually poor draining is due to a blockage or partial blockage in the drain line,also the blockage can be at the drain pump itself or where the drain connects to the under sink drain
Dec 20, 2008 | KitchenAid Superba Architect KBCA06XPBS...
Food on dishes
Nov 26, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Food Deposits left on dishes
I had an old machine with a similiar problem & I found that food had somehow entered into the arm that spins & sprays out water. The food blocked somewhat the holes which of course means less cleaning.
Mar 05, 2008 | Maytag 24 in. MDB5601AWS Stainless Steel...
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
419 people viewed this question
Top KitchenAid Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
