posted by CD Freeze on Jan 08, 2007
as soon as the power turns on the icons flash and the entire image looks like its shaking
4 Other Users Have The Same Problem
Comment by dmolini, posted on Aug 19, 2008
The quick view from the outside panel keeps flashing on the screen scrolling from movie to photo to gaming to text to custom and adjusts the image as it scrolls, and I can't see through it because it is in the middle of the screen
Comment by Guest, posted on Mar 19, 2008
Monitor is showing the desktop but is flashing so rapidly that mouse cursor cannot be located.
Comment by Guest, posted on Jan 02, 2008
I have the problem but with ACER LCD AL1717
Comment by Guest, posted on Nov 10, 2007
it works of a waile and it stops and than it works again but the most time that didn't wirk was for a week and than it worked agane help
Solution #1
posted on Jan 15, 2007
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
I've fixed a monitor with the exact problem. Had to resolder bad joints on the mainbord. mostly from the power components. Good Luck!
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jan 12, 2007
Then it goes away? That sounds like the normal degauss feature is working.
Comment by MicrowaveSvc, posted on Jan 12, 2007
Sorry I didn't finish my post. Got interrupted.
I posted that picture to suggest that you check your menu to see if you can find that (degauss) function.
Select that, and it should do what you are describing.
I don't think you have an actual problem.
But post back if I'm wrong.
Suggest a new solution for this problem
Post a New problem for BenQ P992, 19 in. 19" CRT Monitor
Email this problem
Email this problem
This Problem Also Relates To:
HP Pavilion F1703 17" LCD Monitor
HP Pavilion F1503 15 in. Flat Panel LCD Monitor
HP vs19 (Silver) 19" LCD Monitor
HP 91 (White) 19" CRT Monitor
Philips 107E56 (Black) 17" CRT Monitor
Philips 230W5VS (Silver) 23" LCD Monitor
Philips 170B5CB (Black) 17" LCD Monitor
Can you Help with these Monitors problems?
Repair Service
Find Monitor Repairman Near You:
