Question about Maytag Dependable Clean Top MAV5920EWW Top Load Washer
Burning smell and smoke from motor
I Have Replaced The Motor (new One) And Still Grtting The Smell And Smoke From Thr Motor Plz Help Y .the drum is empty even with out the belt on it only the motor running there is burning smell and smoke from the motor
  • fychohan Nov 26, 2008
    were is the transmission located and what do u suggest i do remember the motor is by it self i mean no belt.
  • 833 Answers
Sounds like the transmission is jammed.  This will cause the motor to bog and burn.
Posted on Nov 26, 2008
Smoke, burning smell coming from my machine. Door wont open and clothes and water inside is black
the bad smell you refer to is a smell of the electric motor burned out have the motor replaced the machine should be ok
Nov 23, 2017 | Whirlpool Washing Machines
Burning smell smoke
Same problem here. Have you found a fix?
Jan 22, 2014 | Triumph 7.3T Treadmill Drive Motor
My mowers blades are not turning but the hum of the motor is there and it has a burning smell with smoke coming out of the motor housing unit ...help
It sounds like bearings are seized and need to be replaced. Too much attempted use will burn out the field windings and a rewind or new motor will be needed - both costly.
Sep 20, 2010 | Electric Lawn Mower
Burning smell from motor
Check your filter and also check that nothing got pulled into the motor...otherwise the motor is burning up and will need to be replaced... probably cheaper to replace the whole vacuum..
heatman101
Aug 27, 2010 | Numatic HVR200P Bagged Canister Vacuum
Stadt J90 Heater electrical buring smell when unit fires up smell goes away after 5 - 10min for a day or 2 then comes back. Check but no signs of fire or smoke or burnt area. Unit is old but works well...
Hello
Could be your fan blower motor overheating.Normally you wont see any smoke or burning from this motor.
There are sealed bearings in these motors that go bad and cuase a strain on the motor.Also the windings could be clogged with dirt.
Have a look at the motor after you run for a little while.IF the motor is hot to the touch have it replaced.
Apr 12, 2010 | Heating & Cooling
The washine machine finished it's cycle but there was smoke coming out of the drum and a burning rubber smell
The usual cause of smoke coming out of drum is that the heater element has come on or stayed on with no water in the drum
Try it on a spin cycle only, if smoke still comes out of drum, then could be a faulty pump, or main motor is burning.
Jan 20, 2010 | Baumatic BTWM4 Front Load Washer
My beko washing machine smells of burning
i need a motor circuit to test the motor of a defy automaid it does not spin fast
Nov 24, 2009 | Washing Machines
When you turn it on....is the belt turning the brushes? Something may be caught causing the brushes to stick and the belt to just grind the brush assembly.
Jan 03, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
K45 started smoking while mixing cookie dough
There is the possibility that if the mixer is 30 years old and it has never been serviced that the gasket around the gear case is leaking oil and in that case it would not be hard to get liquids on the armature or the stator as the gear grease in the transmission is vegetable base grease and it separates into liquids and solid and when the head is tilted up the failed gasket allows the separated oil to leak down and to the rear onto the mixer right onto the motor parts. It maybe nothing more that cleaning out all the old grease and re-packing and adding a new gasket.
Dec 14, 2007 | Food Mixers
Smoke smell coming from my 80 series Washer
do you actually see smoke or is it you have a burning smell
if you have a smell the motor may be overloading on spin
sometimes this is due to too much soap powder in wash
and when machine spins the water cant get away due to soap suds under and around bowl
acts like a brake on motor
try no soap powder in next wash
a good way to tell is that you still have soap in washing if you lift the lid (with no soap powder added)
Dec 02, 2007 | Kenmore 15864/15862 Top Load Washer
Maytag Dependable Clean Top MAV5920EWW Top Load Washer Logo
713 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
