Black screen on my hitachi ultravision 55 inch plasma tv
I can hear the tv but the screen is black so I know its on. Is there anything I can do like hit a reset switch to bring the picture back or something else I can try to fix it?
  • marcies Nov 26, 2008
    samsung 42" 3 years old
  • 106 Answers
With a black screen, it could be any number of things. You cold have a bad Y sustain brd, Z sustain brd, digital brd, etc. As the tv powers on it develops turn on signals to the power supply. If there are any bad drive boards, these signals will not be developed thus not allowing the power supply to fully energize. This repair will probably require a qualified technician.
Posted on Nov 26, 2008
My tv has sound, but no picture. When I turn it on the blue light blinks eight times and the screen is black. What is wrong?
Hi Tammy,
Please check the INPUT of your TV by pressing INPUT, SOURCE or TV/VIDEO on your TV remote. Once you press one of those ( that was on your TV remote ) you should have INPUT lists on your TV screen. All you have to do is select each one on the list until you get a picture ( normally input is TV ). Hope it helps.
May 05, 2014 | Hitachi UltraVision 55HDS69 55 in. Plasma...
How do I fix My 50 inch Hitachi Ultravision TV?
Likely the lamp in the set has failed here which does make sense if the picture was dim before---a lot of lamps just before failing all the way dim down.
Apr 25, 2012 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi ultravision director's series 55"
I don't know how to fix your issue but I have the same tv with a cracked glass front. I would be interested in buying your tv for parts to replace my glass front if you are unable to fix yours. Please let me know. Thanks, Dan
dcgezz@yahoo.com
Jun 10, 2011 | Hitachi 55HDX99 55 in. Plasma HDTV
I have a 2006 Hitachi Ultravision 42 inch plasma
plasma tv units use a lot of power ,well into the hundreds of watts 9 some big screens use up to 800 watts to work)
I suggest that you consider a new led unit which uses barely any power and you will get a remote with it
Jun 24, 2017 | Hitachi UltraVision 42HDS52 42 in....
I have a spot in the middle of the screen that red shows up as almost black. It looks like the old problems when magnets were put on the old fashioned TV's It is a 50 inch Hitachi Ultravision. I replaced...
That is going to be a failure of the light engine itself. The part number for that is UX25302R. The part is not a user replaceable part due to the complexity to remove and reinstall the new one. Here is a link for the part and to purchase it as it runs 521 dollars. Please take a few moments to rate my answer. Thanks...
http://www.partstore.com/Part/Hitachi+Ltd/Hitachi/UX25302R/New.aspx
Nov 16, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Screen went black while watching, no sound
Almost for certain your power supply board is bad, Can be repaired at the component level only if you have some electronics savy! Good Luck!
Dec 26, 2008 | Hitachi 55HDT79 55 in. Plasma HDTV
Many thin black horizontal lines on my Hitachi Ultravision 50" TV
Good Day, LDS also;
You may have a poor seated cable connector. Unplug TV from A/C, remove back look for a large black connector. It connects between the Main Digital Module and the Drive PWB. Re-insert both ends several times to make better contact, use contact cleaner if have but not always needed. Good Luck, big IRISH.
Jul 21, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
50 INCH HITACHI ULTRAVISION HAS COLOR DIFFERENCE ON EDGE OF SCREEN
Hey, I found this on a blogsite about lcd rear projections....looks like our tv's screens have been burned by the "pillers" that surround the tv when switching from 4:3 to 16:9 or fullscreen... read below, I hope it helps !
cheers!
Vern
Rear projection crt's,the first generation widescreen tv's were notorious for that.Lcd and plasma can have the same problem,but it takes much longer and is not as harsh.Dlp's use tiny mirrors,so it isn't a problem with them.Lcd and plasma tv's should be ok unless you watch them with blck bars on them all the time.
We have lcd monitors at work,and i've seen them after a year with bad burn in.They also run 24 hrs a day 7 days a week with the same display.
GKar posted 2006 Oct 10 15:31 TooLFooL : i have 51" sony rear-projection and those freakin' grey bars burned themselves right into the screen...
I read that to avoid the burning you had to limit your 4:3 viewing time to 15% of total time viewed. (applied to my TV but apparently yours and others as well...great! now they tell you :-x , this applies unless 4:3 aspect was changed to stretched or zoomed...yuck :-x )
This really sucks as a Star Trek/Lexx/Farscape fan as they are mostly 4:3, fortunately the upconvert player/hdmi combo sends a 1080i 16:9 signal to my TV so the effects are drastically reduced by nearly filling the TV without the grey bars or burn in problem without stretch or zoom modes being used. yay! :wink: (default grey bars set to black automatically, apparently grey isn't needed due to screen area covered is sufficient for burn in not to be a problem.)
Apr 11, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Tv screen stays black with the blue light and two red lights blinking
I have the same problem, if anyone has a solution PLEASE mail me at macry2121@aol.com
Apr 04, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Televison & Video Logo
678 people viewed this question
Top Televison & Video Experts
