I notice others on other brands of computers have had the same problem with cursors moving back in the text unexpectedly, so is it a software problem, or what?/
SOURCE: jumping cursor
You need to adjust the sensitivity of the touchpad
In the TouchPad Properties window you can access additional TouchPad preferences.
»To access the TouchPad Properties window, use the TouchPad to select Start > Control Panel > Printers and Other Hardware > Mouse > Device Settings, and then select the Settings button.
(If you follow this path using an optional external mouse, the TouchPad Properties window may be unavailable.)
SOURCE: moving cursor
Hi, sheila_sharp.
Please make sure you remove any dirt and/or fluid found on your touchpad. Even the tiniest grain of dirt may result in this. If you are using an external mouse, poor quality mice may cause this type of behavior.
Your responses are intended to improve the level of service provided. Please rate your experience.
control panel keyboard settings make sure all your settings are correct
then control panel and mouse or pointer settings make sure there correct
SOURCE: cursor skipping and jumping back into previously typed text
Have a D600 myself and found anothe post that worked for me!
First, my problem was replying to emails the cursor would jump when typing usually back up into the middle of the text somewhere.
If this is similar, read on.
First, go to Dell's website, downlaod the latest driver for the Alps Touchpad: http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R113813&SystemID=LAT_PNT_PM_D600&servicetag=&os=WW1&osl=en&deviceid=2514&devlib=0&typecnt=0&vercnt=7&catid=-1&impid=-1&formatcnt=1&libid=17&fileid=149404
Download the driver but do not install yet. Note, this is for a Dell Latitude D600, Windows XP. Vista may have a different driver.
Open Control Panel/Mouse/TouchPad Tab/Touch Sensitivity Button. Open Touch Sensitivity, adjust below the halfway point on the slider. Try different settings, you may also want to check the "Tap off when typing" box.
If you do not show these properties as above, you probably don't have the latest driver installed. In that case, install the driver you downloaded above then come back and refer to the instructions.
I spend 90% of my day on this D600 and really love it, not a speed demon, but light enought to carry with one hand and is a great email/browser machine as you probably already know!
Before installing tis driver
SOURCE: while typing on my laptop, my cursor jumps to
I guess the 'other places of the pages' is mostly the beginning of the line? It usually happens when the key stroke is not proper while using combination keys. Or also it happens when if you dont release a key when you press the next in between your speedy typings.
