Question about Clarion Car Audio & Video
I have a stuck cd in my Subaru Clarion PF-2597A-A car radio/cd deck. How can I extract it without damaging either the cd or the deck. Thanks! Richard
3 Suggested Answers
motor1258
  • 6674 Answers
SOURCE: Want to get the electrical
This link may help.
http://www.the12volt.com/installbay/vehiclewiring/1/yeard/Subaru.html
Posted on Nov 06, 2010
aviral_srms
  • 1216 Answers
SOURCE: I need an operators manul
If a manual exists you may find it here
Posted on Nov 18, 2010
kenw392
  • 2226 Answers
SOURCE: Hi ken, I posted the
did you get the message i sent telling you to disconnect the battery for an hour or two? sometimes the microprocessor locks up and needs to be reset.
Posted on Dec 17, 2010
Hi I need code for MODEL PU-2294A(C) serial CL040130897281C Thanks
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio
Jun 28, 2011 | Car Audio & Video
Clarion radio from 2002 Saab 9-3 Viggen. Radio works fine on AM,FM,and CD, but the Weather Band does not switch the display nor receive WB broadcasts. (Radio has Onstar module, but that service is dying,...
it i.s apparent that either the button to ingage the wb is not making contact with the module inside or there is a fault on the main board inside the deck. now depending on how old the deck is I would most likely suggest you either have it repaired at an car audio shop or just replace it with a similar unit.. please rate this...thanks
Sep 28, 2008 | Clarion Car Audio & Video
Clarion PF2851B-A car radio will not play or eject cds.
Does the unit have power ?
when you press the eject button, the cd appears to be stuck or the eject button is not responding
Thanks
proton
Jul 11, 2008 | Clarion Car Audio & Video
I just brought clarion cd player had it fitted by vauxhall dealer and when i put the key in the ignition turn key to aux cd wo'nt come on but when you turn the key to start engine cd player...
Sounds like the unit was not wired into the car properly..the dealer needs to make sure that the switched lead that they connect the red wire from the radio to is hot when in both run and aux(accessory) positions on the ignition switch...it sounds like they may have wired the switched lead to the wrong accessory lead
May 26, 2011 | Clarion Car Audio & Video
I need a code to unlock my clarion pu2294a(c) cd player
The only CLARION code availablefor free (using a serial number ) from anywhere on the Internet is if yourradio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + ++ on a separate label somewhere on themetal casing. (Note ...not beginning with CL.) If not then it will only be available from your Main Dealer or a Decoding Service oryour local Car Radio / Audio Store who will connect a laptop to read/recode thememory chip (EEPROM) inside your radio
May 20, 2011 | Clarion Car Audio & Video
I have a cd stuck in my factory cd player, i have an 05 dodge ram 1500, the cd will play but wen i push the eject button the cd switches to the radio and does not eject out
the cd mechanism is probably bad. the only way to repair it is to replace the cd mechanism. it probably has a clarion cd mechanism.
Feb 17, 2011 | Car Audio & Video
Want to get the electrical wiring diagram for the Clarion PF-2946A-A subaru car audio
This link may help.
Nov 06, 2010 | Car Audio & Video
JUST BOUGHT 06 JIMNY.- HOW CAN I DISCONNECT BATTERY WITHOUT LOSING AUDIO AS I HAVE NO PIN NUMBER FOR CLARION PS-2685 RADIO/CD PLAYER?
if you have access to a jump box to start cars most come with a double cigg lighter plug. by pluging the cord into jump box plug and into your cigg lighter outlet. this will hold power to the radio. you can now disconnect battery without loosing memory.
Mar 22, 2010 | Car Audio & Video
Car Audio & Video Logo
75 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
