Question about Xerox Phaser 8550DX Laser Printer
Xerox phaser 8560 DN is jamming in same place every time.  I remove paper and it re jams in same place.  Now printer is making a loud gear slipping noise.
  • 37 Answers
There is mostlikey a scrap of paper that you can not see still in the machine. You can gently walk a thicker piece of paper through the paper path and see if it pushes out the obstruction. Be very careful not to scratch the drum when you try this.
Hope this helps
Posted on Dec 04, 2008
Xerox phaser 8500 paper jam
Before you clear the paper out, If you press the question mark button (?) it will display the Jam Code which will narrow down what kind of jam you have. You can look it up if you can get access to a service manual.
Oddly, the most common jams aren't caused by rollers and need a DM camshaft 020K14801 changed instead. If you have jams right at the tray then get the roller kit 604K42200 after all.
Good luck ...Whit at www.iteminconline.com
Aug 18, 2013 | Xerox Phaser 8500/DN Printer
Xerox 8560 duplex paper jam
your machine should show where the paper is jammed. Open that compartment and pull the paper out.
Jul 15, 2013 | Xerox Phaser 8560MFP Laser Printer
Xerox phaser 8560 says "paper jam - open front
try cleaning the microswitches. it may also have a sensor and if the little plastic piece that crosses between them has broken off it will throw codes. mine is ok so i cant say for sure but you can try to glue a suitable piece in there to trick the printer if thats the case or bypass the sensor. just a few suggestions from my experience with electronics
sensor is kind of this: gap is where the plastic part is supposed to go in between.
Oct 12, 2011 | Xerox Phaser 8560MFP Laser Printer
My Phaser 8500 will not print and has error 08,045,43:75066 - Anyone know what this means?
The Xerox support site indicates there is a paper jam to the printer, so you should check the paper tray, front and exit cover for any jammed paper then power off and back on the printer. Have a look here: http://www.support.xerox.com/support/phaser-8500-8550/support/enus.html?operatingSystem=win7x64&fileLanguage=en
Feb 24, 2011 | Xerox Phaser 8500/DN Printer
I have Xerox 8550 coming up with a jam when the printer starts up. The C3T error code is given. Today I opened it up and following the instructions from the Service Manual I did the homing procedures on...
Two things normally cause that. Look in the area inside the top cover where there are 2 green guides that flip up so you can clear a jam off the drum. See if the clear mylar guide it bent or cut causing the jam.
If that is ok then more than likely you have a process drive timing problem. That is the drive gear assembly on the right side of the machine.
You can try removing it and retiming it by inerting pins throught the timing holes.
I suspect a process Drive timing problem
Mar 01, 2010 | Xerox Phaser 8500/DN Printer
Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Apr 15, 2009 | Xerox Phaser 8500/DN Printer
Repeated paper jams
These errors are usually caused by a cracked DM Camshaft (Drum Maintenance). This was a very common problem for Xerox, they usually broke while under warranty, but there a heck of a lot out there that are just now going bad after a year.
You may or may not need to replace the "Motor Process Drive Gears" as well as the DM camshaft.
You might be able to talk Xerox into doing this as a warranty repair, if you ***** real loud.
Mar 12, 2009 | Xerox Phaser 8550DX Laser Printer
Install wiper on xerox 8560 dn
The user guide is available here http://www.support.xerox.com/go/results.asp?Xtype=docs&prodID=8560&Xlang=en_US&Xcntry=USA&prodName=Phaser%208560
Also, I think there are two wiper blades on the 8560, one is on the maintance kit and the other is supposed to be removed, that was the old 860 that could remove theirs. Perhaps cleaning it will be fine. just open the top of the machine and its right there, give it a wipe and it should be fine. The other wiper blade on the maintanance kit and here is a link below to show you how to clean it!
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=355,E=0000000001343253407,K=1300,Sxi=12,Case=obj(902)
You can use this site to troubleshoot any problems with Xerox printers.
Niallbt
Feb 17, 2009 | Xerox Phaser 8500/DN Printer
Xerox Phaser  8550DX Laser Printer Logo
1,371 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
