Question about Sharp CV-P09FX Air Conditioner
My house everyonce in a while, gets burning smell - only upstairs, it smells like it is coming from the vent. I have had my heat on since October, but the smell only started in November. I had someone come out and look at my heating system, and I did need to change my filter, but the smell happens even when I have the heat turned off. I have no idea what else to do
  • 833 Answers
I'm going to guess that there is something in the heater area which doesn't belong there.  It might be insects or worse.  Get someone else in to look at the burner/heater unit.  The other problem could be a stuck fan which is burning...although that usually starts as a squealing bearing.
Posted on Nov 26, 2008
My heatilator fireplace seems to have a closed flue but I cannot find one?
First of all, immediately install carbon monoxide detectors in all living areas of your home. You stated you smell gas? Call a plumber! He or she will verify if it's raw gas or not. What you probably meant to state is you smell the flue gas/combustibles. You'll need to have your flue piping connections/outlet checked.
Oct 17, 2017 | Heating & Cooling
Why is the dishwasher smelling like electric burning and smoke coming out of the door vent?
Hi friend, thank you for your post!
I understand that your Frigidaire dishwasher is giving off an electric burning smell and you are seeing smoke coming out of the door vent. It could possibly be an issue with your control panel or door vent, both have electrical components inside of them. Since it could be either one of these underlying issues I would recommend having a technician come out to your home and diagnose and repair the dishwasher. Hope this helps. -Matt
Jul 27, 2014 | Frigidaire Dishwashers
I have 3 central ac units for my house. 1 for the upstairs and 1 for the west side of house and 1 for the east side of house. just had a very cold night and the east side of house vents smelled like...
To make sure that there is not a problem with your blower test it on cool. if it runs good. then start the heater on auto and it should be okay. but still supervise the operation for about 5 mins. if you still smell something burning . then call an AC Technician for help.
Albert Saavedra
AC Technician
Fort Worth/Dallas TX
773-627-8766
Dec 28, 2010 | Heating & Cooling
Goodman GMPH075-4 Heater with new louder noise & strange smell
The burning smell could be anything inside the furnace blower compartment. Most all the controls are located there. Me not being there is it hard to say what it it and what to replace. I would start by removing blower compartment cover and inspecting the wires and controls. Look for any bad connections. If it was transformer it would have already burnt up. Goodman has a fuse on there controlls in case of shorts, Limit controls in case of unit over heating. If you cannot visably see anything wrong it would be a good idea to call a service tech to check heat exchanger. I would have it checked anyway. James
Mar 26, 2010 | Heating & Cooling
MPV 2002. Black particles come out from air vents
I get the feeling this is the first time you've used the heater? Its probably accumulated dust. As long as you don't get a burning smell or smell exhaust fumes you should be ok after a few hours use.
Jan 06, 2010 | Mazda MPV Cars & Trucks
I have a Trane XE1200 AC unit which emits a slight electrical burning smell when it turns on / cycles throughout the day. the smell is very similar to that of the furnace when it initially turns on during...
I would have a tech come out and check the voltage going into the fan relay and fan itself. The smell being as how it is coming through the vents in the house tells me that the problem has got to be at the blower or in the area at the blower fan which leads me to the possibilty that the smell could be the windings on the motor. This could be because the voltage may be to high. Good luck on repairs
Dave
Sep 01, 2009 | Heating & Cooling
Smells like it's burning and smoke coming out of chimney vent
Get the filter housing out of the machine and wash it out. Blow out the blowers housing. Change the control thermostat.It mounts right next to the fuse on the back:
Dec 07, 2008 | Roper REX4634KQ Electric Dryer
Dryer burning smell
Have you painted or stained in your house or apartment recently? The smell gets everywhere, dryer, stove, heating unit. I recently primed with Kilz and the clothes from my dryer smelled burned. When I called for service, it was the first question the service person asked and said they made a lot of useless trips only to find nothing wrong with the appliance. That was my case. I had to rewash clothes and let the dryer run with towels for a while
Jan 22, 2008 | Dryers
Sharp CV-P09FX Air Conditioner Logo
231 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
