Question about Sony KP-51HW40 51" Rear Projection Television
Green flashes then tv turns off
My Sony, KP-51HW40, flashes green blips and then shuts down. The little red light on the front of the TV goes on and off eight times after the tv shuts down. IS there a part associated with this red flash code or is there something I can do to solve this?
  • 21 more comments
  • Dan Lodema Jan 12, 2007
    I could not find T8005 but did find T8002, T8003 and T8004. I did adjust the green color from the front but that did not help. I contacted Sony and they basically said it needs to be serviced. I am going to take it in to be serviced.
  • zuloo7 Mar 28, 2008
    screen flickers and flashes then shuts off. red led on the front of set flashes 8 times over and over.
  • Anonymous Apr 26, 2008
    it started by showing greeen and then turning off immediately. then after a couple of months it shows the green but does not turn off so we put it off for like two minuites and then put it on and its fine. now it shows nothing but green. what to do, what to do
  • Anonymous Apr 28, 2008
    Green screen, then turns itself off and red light flashes
  • bob0u812 Apr 28, 2008
    green screen, then shuts itself off and red light flashes
  • Anonymous Apr 30, 2008
    sony rear projection t.v. has green screen then shuts off
  • Anonymous Jun 17, 2008
    goes green then off
  • Jsturm Jun 22, 2008
    I have a Sony KPWV600 and it flashes green and sometime blue than shuts off and the red LED on the front of the TV flashes 8 times. Any ideas?
  • maverick_997 Jul 21, 2008
    flashes green on the screen a few times then shuts off
  • Anonymous Jul 26, 2008
    Screen will display a green line then image for about 15 seconds, then turns OFF. The red light will flash 8 times. When this happened was immediately after my 1 yr daugter fell and hit the bottom right portion of the tv. Hasn't worked since! What solutions worked???
  • monimonitamp Jul 28, 2008
    My sony KP51HWHD was working fine until I hooked a dvd/vcr into the front connection panel. The TV then turned green and shut off - same as others reported. If I turn it on it turns green then shuts off and the red button flashes for a while.
  • karafaye Sep 28, 2008
    I have the exact same problem. Goes green then turns off and red power ligh flashes eight times and stays offf for a few seconds then flashes eight times, ect.
  • speded2004
    speded2004 Sep 30, 2008
    i turn on my tv, picture is fine then in seconds flashes blue then shuts off. then the timer/standby light flashes.can anyone help me solve this problem
  • Anonymous Oct 14, 2008
    Green lines and flashes behind the picture... then turns off... pls help... its almost 7 yrs old 51 inch Sony.
    Should i repair or just buy the new one... Thanks
  • Anonymous Oct 21, 2008
    Same Problem - Started with green lines across the screen, then TV shuts down after a few seconds of being on, 8 red blinks of lights.
  • R C
    R C Feb 23, 2009
    I have a kp-51hw40 that blinks 6 times picture or sound never come on
  • desconocido Mar 01, 2009
    when i turn tv on the screen turns red and then it turns off
  • mjrb Mar 23, 2009
    I have sony tv kp-51hw40. I have the same problem as most of us here. My tv shows all blue screen for few seconds then shut off. Stand by light blinks 8 times. I did the adjusting but it didn't work. I openned the back cover of my tv to find out if all my tubes work and I found out that blue and green lights work but not the red. Do you think that might be the cause of all these problems? If tubes/ bulbs need to be replace, can you please help me how to replace it?
    thanks
  • gstickle Mar 24, 2009
    tv is playing then it flashes red and then green and shuts down
  • smansfield19 Mar 28, 2009
    my problem is identical. The tv has had visible lines across the screen for months with the picture going in and out. I got home today and turned it on and it just started to come on and then shut off.
  • waja00727 Apr 22, 2009
    My front Red light on tv flashes five times and i am unable to adjust the red color
  • Dale 9999 May 11, 2010
    Thank you so much for helping me fix my KP-51. I took a chance on your instructions and somehow it worked like magic.
    Question - Why did my TV act up with the blue color and then blink red dot eight times? Second Question is how do I increase the life or avoid certain methods to keep this TV running good?
  • Anonymous Mar 25, 2014
    Problem Solver:
  • 8 Answers
OMG! My TV has been sitting in a closet for the last three years because I couldn't afford to have it fixed.  I have googled now and then trying to find a cure for its green affliction but never found the right advice until tonight. I can't thank J19666566666 enough!!  I just followed the instructions and presto!  Working TV again! And just in time for the Oscars (which is like the Super Bowl for me).
The editor in me tweaked the instructions a little...
Its is real easy to fix. There are 2 screws holding the front speaker cover on near the bottom corners (there are plastic plugs covering the screws that need to come out first). Unscrew and remove the speaker cover (pull it out from the bottom a little then sort of down and out to get it loose but be careful because there are wires attached). Next remove the 4 screws holding the particle board panel in place. There will be a cluster of 6 adjustment nobs with a drop of white paint on each one (2 rows of 3 - do not touch the top row). The green is controlled by the bottom middle screw, Using a screwdriver turn it counter clockwise (to the left) ever so slightly (1-3mm) and there you have your TV back. Use the bottom right screw to adjust the red and bottom left screw for blue.
Thanks again so much!
Posted on Feb 23, 2009
Its is real easy to fix. There are 2 screws holding the front speaker cover on (there are plugs covering the screws that you take out first).Unscrew and reove speaker cover(you got to give it a bit of a tug to get it off ) then remove the piece of wood cover held by 4 screws .. Once you have taken that off when you look down you will see 6 screw like adjusters with a white painted mark on them (do not touch top row ) the green is controlled by the bottom middle screw ,, witha screwdriver turn it counter clockwise (to the left) ever so slightly (1-3mm)and there you have your TV back .. when the screen turns red use the bottom right screw and blue bottom left screw.. I hope this helps
Posted on Jan 10, 2007
Solution by J19666566666 clarified again by CrunkMomma corrected this issue for me. This TV was given to me by a friend who was going to throw it out, all it took was a few adjustments as described above (red flash for me versus green) and works like new again. Thanks a ton for the help!
Posted on Mar 05, 2009
I have this tv sony KP-57HW40 I had the flash of green then it turns of problem.I had a shop pick it up and repair it.They charged me around $600 .Well that was 3 months ago.After I got it back they said the warranty was for a month.Real nice.Anyways,The tv is doing it again.My advice is this telivision should be considered garbage.Stay away from it.I think Sony should repair there junk tv's.I am into this tv for over $4,000 now.Im pissed
Posted on Mar 24, 2008
I need to know where the T8005 d board is located
Posted on Apr 15, 2010
WOW!! Just did the J19666566666 / CrunkMomma method and it worked! took maybe 15 minutes to do. I was so bummed because I thought I was gonna be out major bucks for a repair or a new unit. Thank you so much!
Posted on Apr 20, 2009
Everyone follow the instructions on solution #2 it is the key!!!! I was even able to eliminate the annoying faint green lines in the background by doing this! Thank you for saving me 600 bucks!
Posted on Oct 12, 2008
CRT Shorted, need replace green CRT.
Posted on Jan 12, 2007
    Scholar:
  • 119 Answers
My research indicates a possible faulty T8005. it is locate on the "D" board. t8005 is the flyback transformer. i do not know of a way to test this part other than by replacement. sony part # 1-453-285-21 sony's price about $150.00. you may also have another bad part. sometimes the horizontal o/p can go when the flyback goes. i recomend you call your nearest service center to get their opinon. good luck.
TV turns red,shuts off, stand-by light blinking 8Times
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Feb 27, 2014 | Sony KP-51HW40 51" Rear Projection...
I have no picture and the power light flashes green and then red.
I can help you to solve your Sony tv problem.
Is it Sony KP-51HW40 tv or any other model?
How many times red light start blinking after three seconds long pause?
Let me know to proceed, can you check voltages with multimeter in tv circuit board?
Thanks.
Nov 26, 2010 | Sony KP-51HW40 51" Rear Projection...
My KP-51HW40 clicks off after running for a period. The red power light blinks when it goes off but screen stays dark. When TV is shut off for a while it restarts and runs fine. The "On"...
KP-51HW40 shuts off due to incorrect white balance and blue arch lines is an evidence of that incorrect white balance. I hope tv standby red light would flashing 5 times then 3 seconds pause and again 5 times when tv shuts down.
This is rear projection tv that has three picture tubes (red-green-blue) inside to generate picture that projected at front screen. These three picture tubes must be drive with correct drive voltage to produce good picture of each color.
Solution for your tv problem is Screen Voltage adjustment that can be done easily if you are handy with electronics stuff repair.
Let me know your expertise level to guide you more and if you feel unconformable by tv repair then local tv repairman will help you to adjust white balance in tv.
Hope these info will help you.
Let me know if you have additional questions.
Thanks.
Nov 05, 2010 | Sony KP-51HW40 51" Rear Projection...
Turn tv on,picture good for 4 seconds,then green curved line like a rainbow all green,then 4 green sequence flashes,picture goes out theN volume continues for 2 seconds then out front red power light then...
This is a set with bad picture tubes-not available except on rebuild basis.
Are you seeing bright green screen and then set shuts off?
Let me know so I can help--8 blinks is AKB error.
SD TECH
Sep 15, 2010 | Sony KP-51HW40 51" Rear Projection...
5 flashing light code,unplug CR board,now 8 flashing light code
If you put the "CR" board back on, the error code will once again be 5 blinks. Your problem is likely the TV's IK blanking circuit. The Kine driver ICs on the CRT sockets boards CR, CB, and CG need replacement along with a few components in the 200 volt supply to the circuit.
Feb 12, 2009 | Sony KP-51HW40 51" Rear Projection...
Turns red then shuts off
the red CRT is shorted . You should be able to get a replacement CRT at the following link.
http://servicemanuals.vstore.ca/
Sep 27, 2008 | Sony KP-51HW40 51" Rear Projection...
Green screen and shut down
TV screen flashes with Red lights for few times. sometime it shut down TV or red color is lost showing pictures without Red looks terrible. Any solution
Sep 17, 2008 | Sony KP-51HW40 51" Rear Projection...
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
5,568 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
