Question about Kenmore Freezer 20.3 cu. ft. Frost Free Upright Freezer
Freezer Burn I can not put meat in the freezer with regular freezer bags it starts getting freezer burn from the beginning so I invested in a food saver (as they suggested) the meat doesn't get freezer burn but it does change color (brownish) I have noticed that when I check on the meat 24 hours later there are parts of it that have not froze solid (it takes about 48 hours) My icecream is always soft. I keep the freezer on minus -10. I have had 2 different repair companys and one Sears repair man to check my freezer and everyone says there is nothing wrong with it and that I'm not packing my meat correctly..they say that no air is getting inside and temp. is correct. I have been a housewife for 45 years and have had about 3 freezers in my lifetime and I never had this problem. They told me that you have to use a vacuum sealer although I have not needed to ever before. My thoughts are it may be defrosting and re freezing when I'm not aware since it is in my basement away from my everyday living space. What do you think can be wrong that I can ask a repair man to check.
    Problem Solver:
  • 11 Answers
It sounds like you may be overloading your unit. If you place a large quanity of non frozen items in the freezer at one time, it may take a few hours to bring the temperature back down. This usually happens with a chest type not an upright. Insure when adding items to the freezer there is room for air movement. With out looking at it I think the problem is the defrost timer or sensor. Maybe staying on too long increasing the overall temperature of the unit. When ever the defrost cycle is on, the cooling unit is also off. As far as the meat freezer burning, none of the freezer bags I have used prevent this. I pr-wrap my meat in freezer paper and then place it in a bag, sometimes freezer bags sometimes not. I try not to buy meat from grocery stores, I grow my own meat and have it butchered and vacuum packed, it doesn't change color. Please note that items in a freezer bag moved around after the contents have frozen will cause air leaks in the bags very easily.
Posted on Nov 29, 2008
What setting do I use to make the freezer freeze food
When you are freezing something, set your freezer on its highest setting. However, if you are going to leave your freezer empty for a long time, you should change the setting to a lower one. Here's a great tip for ice cream: place a tub of ice cream in a ziplock bag before putting it in the freezer; it prevents freezer burn. You know when your ice cream gets so cold, it's hard to scoop out? Doing this stops that, it's keeps the ice cream just soft enough for easy scooping!
Sep 28, 2014 | Maytag 20 cu. ft. Upright Freezer MQU2056B
When I shut my freezer door, the freezer makes a hissing sound for roughtly 15 seconds, during which, the freezer door wont open. At the moment there is no food in it, could that be the problem?
the auto defrost fan is drawing the air out to cut down on frost buildup....when you do put food in freezer use vacuum sealer to stop freezer burn and keep portions seperate,easier to rotate food for consumption.also frozen meat can be kept for upto a year at minus 18/20c
Feb 21, 2010 | Freezers
Can i turn off auto defrost in my whirlpool side-by-side freezer, food is getting freezer burnt after just 2 weeks
No you cannot turn off the auto-defrost as the unit would stop working at all after a short time, and there's no provision to do so anyway. And I don't understand why you would thing the feature would have anything to do with fFreezer Burn. Freezer Burn imay be somewhat affected by the temperature, but mostly how well the food is sealed, keeping air out of the package. If freezing packaged meats from your supermarket for instance, the air in the package will burn them in, yes as little as two weeks. If that is the problem, you must repackage those items, eliminating as much air contact with the food in the package as possible to avoid the problem. I myself use both plastic wrap and aluminum foil to repackage anything I want to keep a while.
Nov 29, 2009 | Whirlpool Freezers
Plugged in the freezer full of meat, and it did not freeze...
My advice to you is to transfer the meat to another place (preferably somewhere cold, for both the sake of the meat, and your freezer), let the compressor cool down, and then try starting the freezer. If it does start (it should), let it run until it has pulled the box down to 0 F. Then add the meat back in. Note at the beginning I told you to store the meat somewhere cold. It can be quite an overloading situation for the freezer, not only to have to pull itself down to such a cold temp, but when you add a bunch of "warm" meat to the appliance it is just to much of a load for it to handle. Hope this helps
Oct 05, 2009 | Danby 3.6 cu. ft. / 102 liter Chest...
Freezer burn
freezer burn is the result of sublimation (the change of state from a solid to a vapor) In order to prevent/cut down on the rate of freezer burn make sure that all foods are tightly wrapped and/or sealed. The more are you can remove from the package before freezing the better. That is why vacuum sealing is so popular. Hope this helps
Sep 09, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
I have a GLFU1467FW upright freezer that is about 1 year old. Since I have had I have noticed that there is a lot of freezer burn on food, to the point where I throw it away. It was set at #4 on the panel,...
Freezer burn is caused by oxidisation of the food contained in the freezer bag that has air in it still. Ensure you remove as much air as possible before freezing food.
Oct 24, 2017 | Frigidaire Freezers
Ice builds up inside packages in freezer.
This is the moisture coming out of the food. It is what causes freezer burn.
The problem is made worse in frost free models by the defrost cylce. Best way to slow it down is to use vacuum bags or freezer bags. Also above 0 F food deterioates faster and below it gets freezer burn and the moisture problem faster.
Mar 22, 2009 | Frigidaire 9 cu. ft. / 255 liter Chest...
There is freezer burn on chicken in plastic packages
Hello
Welcome to Fixya
My name is Huum,
You need to use good freezer bags and not just plastic bags in the freezer.
And use these products witin six months..
When you put food into a plastic container for the freezer.
you need to burp the container.
That means to hold it with two hands and with one hand raise the corner of the lit a tiny bit while with the other hand you press down on the center of the lid and close the corner quickly so as to have burped out most of the air in the container. a little like a vacuum packed container.
So less air is in the container to cause condensation inside which is the frost you are getting
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Feb 02, 2009 | Frigidaire Freezer Refrigeration White...
Meat freezer burns
Hi,tomonbow
ngafm at your service,
You said,you are getting freezer burn in only two days, right?
Are you putting the meat in proper freezer bags and squeezing
air out as you zip lock the bag?
If you do not use proper freezer bags you will always get freezer burn on meats!
WAIT ! This will not happen in two days!
Seems to me something else has happened to your meat prior to your purchase and it probably is not the freezer at fault.
If it happens to meat that you feel was not frozen when you bought it, check with the store of purchase to see if it came into them frozen before it was put in their refrigerator case!
Most super markets receive cases of frozen meat and then put them in the walk in refrigerator, or refrigerator case to present them for sale to the customers and they defrost in the case.
Then we think we are buying meat that is fresh and never been frozen!
Fresh meat will not freezer burn in 2 days unless it has happened previously to the time you bought it.
Also when you freeze any meat you buy, repack it in proper freezer bags and not just any zip lock bag!
But I believe it happened before you bought it.
And i'll bet it all came from the same store.
that's why some people shop at a butcher shop or Costco type store where the meat is fresher and sells out faster!
Bless you.
ngafm
Please give me a good rating before you sign off.
Thank You.
Let me know the verdict. I think I'm right on target!
Do some investigating and ask the store some hard questions!
Sep 09, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
196 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
