Question about HP Pavilion dv2000t Notebook
Same Problem Black is REd)
Deb8chick,
I have the same problem and was hoping that you have solved the problem.
Thanks Gerry
  • Uwe Klopfer
    Uwe Klopfer May 11, 2010
    black is red on the display ?... what version of windows and what laptop you using ?
Need parts.Where do I order
Gerry, here's a link to where you can locate a Frigidaire parts distributor in your area.
http://www.frigidaire.com/partsdistributorlocator
Hope this helped you and thanks for choosing FixYa.
Sep 11, 2011 | Frigidaire FAP094P1Z Portable Air...
How do I remove the cover of the black and decker angle grinder.It stopped working,I think a wire is loose inside,but i cannot get it open to see if I am right. Can anyone help? Thanks. Gerry
Hi Gerry,
The body of the grinder should be in two halves. Normally there are two or more screws holding the plastic parts together but these may be hidden behind plastic stoppers. See diagram:
http://servicenet.blackanddecker.com/Products/DetailDiagram?isId=true&productNumber=11651&selectedType=16337#
Remove the screws and it should be possible to split the case.
Hope this helps!
Apr 27, 2011 | Black & Decker 4 1/2" Small Angle Grinder
Was watching TV, heard a pop and the screeen went black. Now when I turn it on, the pwoer light blinks green but their is no picture or audio. The light then starts blinking red
Is is standby light blinking red or any other light? Let me know how many times red standby light blinking after three seconds long pause to provide you helpful info.
It seems pop sound was due to broken lamp, please check lamp inside tv and if it is broken, replace it to solve tv problem.
Hope this will help.
Thanks.
Mar 09, 2011 | Sony KDS-50A2020 Television
Do you know how to get sound back on when you switch to av1 picture fine but no sound thanks
Make sure that you have the audio input hooked up to the correct input (AV1). For the AV1 channel there should be either RCA (yellow, red, and white) or S-Video (generally a black plug) plus the red, and white from the RCA. Make sure the red and the white are both connected to the AV1 Input. Hopefully this solves your problem.
Thank you
Feb 28, 2011 | Sony Televison & Video
My panasonic rear projection tv does not turn on the red light blinks 3 times
3 times red light blinking indicates that tv got problem of convergence output ICs failure and need to replace two big black ICs (convergence output) to solve this problem.
IC replacement requires soldering work and good knowledge of electronics stuff repair, please cal local tv repairman if you do not have prior experience of such work to avoid any damage.
Thanks.
Feb 28, 2011 | Panasonic PT-53TW53 53" Rear Projection...
I have a 93 Ford Laser hatch back and I need to know the radio wiring color codes for the wires that plug into the back of the radio-cassette. 1)Orange-green tracer 2)Orange-black tracer 3)Grey-green...
OK this is what I did: First I soldered a wire each end of a 1.5v battery. I then bared the other ends of the two wires and tinned them. Then I touched the wires coming from under the dash in pairs until I heard the resultant sound coming from a speaker. This then told me the position of each speaker in the car. From there it was just a matter of noting the color codes for each pair of wires and from which speaker they came. My Gregory's Laser KH manual had wiring codes, but entirely different to my vehicle. Also there is no indication of what color matches what letter code! Cheers. Gerry
Dec 19, 2009 | Philips Car Audio & Video
I need the pin cinfig, for the front pannel
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 01, 2009 | MSI MS-6580 Motherboard
Maytag dryer MDE4000AYW change 3 prong to a 4 prong
HI thanks for your question. the red to red black to black white to white green goes to the fram of the dryer. thanks hope i was helpful. please rate my answer.
Oct 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
X reg bmw e46 325cise
I'm sorry , I don't do German cars.
Thank you.
Gerry
Aug 31, 2008 | 2001 BMW 325
HP Pavilion dv2000t Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
