Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Jenn Air oven door won't open after clean cycle
I had to interrupt the clean clyle of my Jenn Air Oven due to too much smoke. Not not matter what I do I can't get the door to open. I even ran it thru a clean cycle on lower heat, but it still won't open.
  • 3 more comments
  • lbrytus16 Nov 26, 2008
    Is there an emergency latch that I can open?
  • Anonymous Nov 27, 2008
    I have the same problem. The door won't open after cleaning cycle. Started the cleaning process again and it still wouldn't open after going through cleaning cycle again.
  • lisa f m Nov 27, 2008
    ran the self-clean cycle, the oven has cooled down all the way -- but the door will not unlock, even after cutting power to the oven and turning it back on.
  • robinepn Dec 14, 2008
    I have the exacgt same problem as the first problem. Had to interrupt the clean cycle due to too much smoke and 24 hours later still cnanot open the oven door. Help!
  • Norma
    Norma Nov 23, 2013
    It worked! But things likes this should not happen
Had this EXACT same problem the day before a party where I needed the oven for lots of baking.... Tried all sorts of things, was about to call a repair man- I FINALLY got it to open by following the first two directions for putting it into self clean mode (turned both knobs to CLEAN), then when it said to lock door I tried to move the lock lever and bam it worked! Give it a shot! Good luck! (:
Posted on Jun 13, 2009
  • julie pearson May 24, 2013
    Just happened to me... a 20 year old jennair- it would not open when the lock light went out, I waited 2 hours, left the clean switch and the temp switch on, then turned the power off from the electrical panel for 20 min. then turned it back on, and it finally came open.
Put both knobs on clean and then push the unlock button and slide the lock while holding in the unlock button
Posted on May 10, 2010
  • 70Challenger Feb 12, 2011
    Worked for me! Thank you !
I had the same problem. I turned off the breaker and turned it back on which did not help.
What DID work was putting the oven back into self clean mode. Set the start time / End time settings about an hour apart. Manually changed the time on the broken clock until the clock went past the end time. The oven popped right open.
-Oughtsix
Posted on Jan 08, 2009
SOURCE:
Self cleaning ovens
Perhaps it hasn't cooled down enough; or you may have to run the self-cleaning cycle again. The oven has to reach a certain temperature before it starts to turn the residue to ash.You may have interrupted its cycle.
It then has to cool off sufficiently to safely open the door.
Dec 22, 2012 | Jenn-Air Kitchen Ranges
Oven is finished cleaning but the door says "locked". The panel just shows the time and "locked" in red, under it. Help
I have Jenn Air oven S136-C with a locking bar. After cleaning cycle wait for the oven to cool down and the lock light will go out (but the oven is not yet unlocked.)
Set SELECTOR knob to OFF
Set TEMPERATURE knob to CLEAN
Press CANCEL button (on right) twice.
Slide the locking bar to the left and the oven door will open
Jan 16, 2011 | Jenn-Air JJW8530C Expressions Collection...
Jenn air oven won't open after cleaning. What can
on some models if you unplug it for a few minutes
it will unlock itself when you plug it back in
Oct 09, 2009 | Jenn-Air SVE47100 Slide-In Electric...
I need direction on how to start the clean cycle on my jenn air
CLEAN PAD
Use to set a self-clean cycle or a delayed
self-clean cycle. One press of the Clean
pad sets up an immediate clean cycle. A
second press of the Clean pad sets up a
delayed clean cycle.
• Clean oven
frame, door
frame (area
outside of gasket)
and
around the
opening in the door gasket with a nonabrasive
cleaner such as Bon Ami*. These
areas are not exposed to cleaning temperatures.
• Remove air grille.
• Remove oven racks. If racks are left in
during a clean cycle, it may impair function
and they will discolor. Turn off the
oven light and close door.
* Brand names for cleaning products are
registered trademarks of the respective
manufacturers.
TO SET FOR IMMEDIATE START:
1. Press Clean pad once.
2. Press the Auto Set pad for 3 hours of
cleaning time, press again for 4 hours
and again if 2 hours of clean time are
desired.
3. CLEANING and LOC plus the clean
time will appear in the display.
4. When the clean cycle is complete,
CLEANED will be displayed. LOC will
remain on until the oven has cooled
(approx. 1 hour).
5. When the oven is cool, LOC will no
longer be displayed and the door may be
opened.
6. Wipe out the oven interior with a damp
cloth. If soil remains it indicates the
cycle was not long enough.
TO CANCEL SELF-CLEAN:
1. Press Cancel pad.
2. If LOC is NOT displayed, open oven
door. If LOC is displayed, allow oven to
cool.
Thanks for using Fix Ya, Please take the time to rate this solution.
clarkco
Feb 08, 2009 | Jenn-Air JDS9860A Dual Fuel (Electric and...
Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 | Ovens
You need the repair man; not a diy project. Please contact me if you need further help and leave feedback. Thanks for letting me help you!
Nov 30, 2008 | Jenn-Air JGR8775QD Gas Kitchen Range
I want to stop the self cleaning function
To Stop or Interrupt a Self-Cleaning Cycle
If it becomes necessary to stop or interrupt a self-cleaning cycle due to excessive smoke or fire:
1. Push CANCEL.
2. Once the oven has cooled down and the word "LOCKED" shown in the display has gone out, then the oven door can be opened.
Nov 15, 2008 | Frigidaire GLEB27S7A Electric Single Oven
Jenn-Air S160
I did it by mistake. I tried to move the lever over and of course, it didn't open but went to restart. I hit the cancel button and then tried the door again and it opened. Yup, we all here feel likes dorks!
Thank you!
Sep 06, 2008 | Kitchen Ranges
Jenn-air gas electric grill range
any power to unit at all?? clear, start, clean ,button?? what happens when you push them??? clock on?what happens when you try to set to clean again??? it should activate hte door lock latch at which point cancel and it should reset itself. with any luck! what happened thankgiving how was it fixed
Mar 14, 2008 | Kitchen Ranges
Oven door will not unlock.
You will not be able to open the door if you turn off temp gage. Return the temp gage only to clean and door should open.
Dec 13, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
7,570 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Thomas F. Schneider
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
