Can you help me?
I read your post at http://www.fixya.com/support/t115527-aiwa_av_d58_receiver and i have the same probleme that i hear no sound just when i click on "Source Direct"Button in Radio-Mode then came Music on the both Frontspeaker.
Can you help me?
    Problem Solver:
  • 7 Answers
Sorry to tell you this, but that sounds like your amplifier's DSP or DSP power supply/control circuitry has failed. DSP stands for Digital Sound Processing - Source Direct bypasses all internal amplifier digital processing, which is why you have sound here. Unfortunately, you'll want to brace yourself for an expensive repair, because DSP components are difficult or impossible to troubleshoot for a servicer, though sometimes it is something simple and quick.
If it's under warrantee, obviously it'll be covered - if not, you may still consider contacting the manufacturer for repair. They're often less expensive than local servicers.
Posted on Nov 26, 2008
WHERE CAN I FIND A SERVICE MANUAL FOR AV-D58 TO DOWN LOAD ON MY COMPUTER?
http://www.retrevo.com/support/Aiwa-AV-D58-Receivers-manual/id/1076dj789/t/2/
May 20, 2011 | Audio Players & Recorders
Okay my problem is its stuck on 5.1ch input and anything els i do it says CAN`T USE. (M. NO#. AV-D58U)
When turning it on hold the enter key at the same time to reset the machine back to the factory settings...worked for me when I had that exact problem.
Feb 23, 2011 | Aiwa AV-D58 Receiver
Picked up a av-d58 and cannot hook up my previous subwoofer setup. I have a tester setup that has been proven to work with anything. I checked and re-checked on other systems I own and the tester works on...
Can we simplify this a bit. It sounds like you're making more of the task than it requires.
When you say "can't hook up my previous subwoofer", do you mean physically impossible or that you can't get it to work after it's attached? This receiver requires a self-powered subwoofer.
Do you have the manual? The receiver is its own tester. I have no idea what kind of tester you're using.
Get it here. http://www.retrevo.com/support/Aiwa-AV-D58-Receivers-manual/id/1076dj789/t/2/ and give it read. Pages 6 and 19 discuss the subwoofer.
Aug 18, 2010 | Aiwa AV-D58 Receiver
AIWA AV-D58 receiver ECO problem
Hi, I've found the problem. There was a closure in the Sorround Amlifier, and the protect circuit stopped the whole receiver. Br., csdombi
Jan 05, 2010 | Aiwa AV-D58 Receiver
Model AV-D58 red light on but unit not turning on no display not sound
I had the same problem, there was a closure by the Q335 transistor in the sorround amplifier. You have to abolish this. Br., csdombi
Jan 02, 2010 | Aiwa AV-D58 Receiver
I have a Aiwa Stereo Receiver Av-D58. The sound
If I remember this model correctly, there is only 1 direct input. The remainder of the inputs are bufferred through a switching IC. It is likely that this IC is defective. Are there any other symptoms at all?
Thanks,
Dan
Mar 13, 2009 | Aiwa AV-D58 Receiver
Hooking Components
You can download the manual from the link below: http://www.us.aiwa.com/default.asp?page=ownerManual&action=browse&model=244 There are good diagrams to help you. When you have followed this guide then come back with any items you can get working. Please update the question & let us know if the information given was useful to you - Good Luck!
Sep 02, 2007 | Aiwa AV-D58 Receiver
AIWA AV-D58 RECEIVER
On 5.1 receivers, some inputs can be switched to Digital/Optical/Coaxial instead of Analog (RCA cables) - look for an Input Mode button. If this doesn't help, turn the unit off, then power it on. If you don't hear a click 3 to 7 seconds after turning it on, it may be in Protect mode, and simply be a coincedence that it failed after installing the new cables. This can be caused by several things, most of which require in-shop service.
Jul 11, 2006 | Aiwa AV-D58 Receiver
62 people viewed this question
 Grubhead
Grubhead
