Question about Kenmore 24032\24036 Top Load Washer
Kenmore top load washer 11092588210 will not agitate
I put in my king size comforter into the washing machine & it agitated, then stopped, figured it was becasuse the comforter got stuck, so I pulled out the comforter and the machine would not agitate. I drained the water which worked, then I ran a small cycle to see if it would agitate and it won't . I checked the circuit breaker box as it said to do on the machine lid, but those were fine. Then it also said to check the fuses, where are the fuses? My husband is deer hunting, so I'm by myself. Please any help you can give would be greatly appreciated!
Thank you - Karen
    Genius:
  • 1,011 Answers
Sir,
Check this link
also check this link
Thanks
Good luck
Posted on Nov 26, 2008
  • 685 Answers
You need to check your belt also make sure nothing is stuck in it.your belt could be broke
    Genius:
  • 3,422 Answers
If your washer doesn't agitate, check these:
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
I have a Kenmore washing machine that stopped working while washing a king size comforter. It looks likt the comfortor may have got caught on the agitator. I can hear a sound coming from the motor area...
The comforter is too big for these washers. But it sounds like you may have taken out the motor coupler. It's an easy fix. If that's not it, then the transmission broke. But it is more than likely the coupler.
Dec 30, 2009 | Kenmore 22422 Top Load Washer
Kenmore Elite King Capacity wont agitate or spin
Following is the Sears Parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20952992
Following is the Whirlpool / Kenmore installation and maintenance PDF for top load, direct drive washers. It includes troubleshooting and testing sections for both the motor and capacitor.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Oct 06, 2009 | Kenmore 15864/15862 Top Load Washer
I put a down comforter in my Whirlpool Ultimate Care II washing machine (I have done this at least 50 times). Last time, it got hung up around the agitator and started making a funny sound. The agitator...
Pull the agitator off and check the plastic drive hub at the top of the agitator shaft. It should not be split, or have it's internal splines sheared off. If this all looks ok, then likely transmission problems or a slipping drive belt (motor to transmission). Good luck!
Jul 12, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 70 series slow agitator
You have burned the clutch this must be replaced
Jun 09, 2009 | Kenmore 15864/15862 Top Load Washer
Kenmore Series 80 top loading washer that doesn't spin or agitate
Unplug machine, remove water pump and motor, behind the motor is a coupler, take broken parts to your local appliance parts store. Costs 16 bucks, replace the broken parts with new ones, reassemble machine. Never ever do a blanket/comforter in your machine again!!
Mar 31, 2009 | Kenmore 24032\24036 Top Load Washer
Agitator moving just a little.
If it is a Whirlpool or Kenmore make washer you probably stripped the "dog ears" in the agitator. They give you the duel agitation that makes your clothes cycle from top to bottom of the machine. Should only rin you around $8.00 or so. Hope that helps.
Jan 24, 2009 | GE WBSR3140DW Top Load Washer
Top Load Kenmore 100-92587210 wasn't agitate
you want to grab the agitator and see if you can spin it both ways if so you agitator dogs are bad and all you have to do is take the softner cup if you have one if not there is a cap that just prys up on the top of the agitator then there is a 7/16" bolt in the center take it out and pull the agitator out then the agitator will pull apart top from the bottom in the top part where the bolt is there is 4 looks like dog ears that need to be replaced
Dec 28, 2008 | Kenmore 3.5 cu. ft. King Size Capacity Top...
What is the capaity of 2005 Kenmore Elite Washer and Dryer, models 110?
Starting in early 2002, the capacity sizes were changed around a little bit. A normal sized washer now all have the same sized tubs (pretty much) in the 110 series (Whirlpool Manufactured) washers. The capacity is now rated somewhat by the agitator action the washer comes with. Depending on the type of agitator you have, will determine the capacity. King size capacity means you have a pretty good capacity (size wise) than others. You have normal capacity, large capacity, super capacity, king capacity, and I even think they have canyon (yes canyon) capacity. Capacity sizes dont really mean to much though. In order for you clothes to get clean, the must have room in the tub to move. The must be able to float up, then get pulled down by agitator action. That should determine the size of what goes in the washer. Always use same type clothing when doing laundry (i.e. towels with towels, sheets with sheets, etc, this will keep the load balanced better). Watch what you load, comforters are ok (per manufactures ok) but I do not tlike the idea unless its a front loader, and only by itself. Let me know if this helps you out any.
May 10, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
you need to replace the timer it is faulty let me know how you make out
Oct 30, 2006 | Kenmore 15944 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
35 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
