Question about Audiovox SMP3332 MP3 Player
Mp3 my mp3 turns on for like 10seconds then says power off bye and i pit in new batterys
0 characters
1 Points
Hello how come my rca mp3 player doesnt charge when i plug it in my computer
You most likely have not turned the player off. Connect to your USB port, switch on the player using the slide switch on the side. The screen will light up. To make the battery charge, turn off the player by holding down the 'play' button until you get the bye-bye message. A couple of seconds later the screen will go black and the battery will start charging. Leave overnight if the battery is dead flat.
Mar 17, 2010 | RCA MP3 & Digital Media Players
This MP3 belongs to a friend who asked me to put music on it. I was able to do so, but now when I try to turn it on the screen says HOLD, the BYE and then shuts off. How do I get it to stay on?
it must have a problem either from the switch or the power source which is the battery. it must be a power shortage. try to charge it around 10-30 minutes and see if your mp3 will work.
Feb 04, 2010 | GPX MW-3847 MP3 Player
How do I charge my daughters amt mp3 hello kitty clip on. when I plug it into my computer do I turn the player on to charge or keep it off. she was kind enough to lose the directions.
G'Day To charge your AMT mp3 player you must first plug it into your PC USB port using the supplied cable. Next turn on the player using the sliding switch on its side.The indicator shows the battery is charging, but it is not. To make it charge you have to turn the player off. To do this, hold down the "play" button until you get the "Bye-Bye" message. The screen will go black and the battery will now charge. Do not use the slide swich to turn off!...woozie. Australia
Jan 18, 2010 | MP3 & Digital Media Players
I charged the gpx for 1 day straight and i un plugged it then it showed a battery with an x said bye bye and turned off.
I think it's safe to assume that either your batter is no good or your cable is no good. You can contact GPX and with proof of purchase you should be able to get it replaced. You can also just buy a new cord or borrow one from a friend if they have it. See if your cell phone charger will plug into the MP3 player as well.
also if you are charging from a laptop be sure that no other devices are plugged into the other USB ports. I hope this helps.
Feb 18, 2009 | GPX ML648B MP3 Player
How Do You Charge Your MP3 Player?
plug it into the computer or wall
Jan 25, 2009 | Nextar MA933A MP3 Player
I need help
This is a suggestion based on my player. Once you plug it into the USB port using the cable supplied, you have to tun it on using a mechanical switch on the side. If this works, the sreen will light up and the player will appear in "my Computer" You can then upload your mp3 files to the player. If you unplug it, it will likely stop because the battery does not charge whilst used in this mode. To charge the battery you need to turn off the player. Do not use the switch on the side. Instead hold down the play button untill you get the Bye-Bye message. It will now turn off and begin charging its battery.
Nov 22, 2008 | MGA Entertainment iBratz MP3 Player
Can't get my 3847 to play
Hi Debbie!
Had same problem. The hold button on the side is not for POWER. To turn ON simply hold down on the play button, but you must make sure the hold button on the left side of the player is in the OFF position first. All the button on the left is for is to hold your song while it is playing so it does get paused or changed.
To turn your player OFF do the same thing, just hold down on the play button it will say stop first and then bye. Again make sure your hold button is in the OFF position.
Hope this helps!
Oct 22, 2008 | GPX MW-3847 MP3 Player
Wont' turn on
Ilo Mp3 Player is weak in Power button so many people get same problem open the case and reinsert the power button still not working, change the rupper piece under the power switch
Bye Take Care
Apr 15, 2008 | iLO (2 GB) MP3 Player
Mp3 player philips
you have to unlock it i had the same prob : let th back of your mp3 face the floor andon the right you will see a button near the reset **** that button and turn it on
Oct 08, 2007 | Philips SA4010 MP3 Player
Battery dies quickly/ device shuts off randomly
ok maybe you have defective battery replace a new one!! and or you have virus inserted to your memory from your loader or loading station.
Sep 14, 2007 | Philips HDD1630 MP3 Player
MP3 & Digital Media Players Logo
14 people viewed this question
Top Audiovox MP3 & Digital Media Players Experts
aliasger yq
Are you an Audiovox MP3 and Digital Media Player Expert? Answer questions, earn points and help others
