Question about Lexmark Optra M412 Laser Printer
Want to print from letter tray but printer is constantly giving the message "Load MP feeder". I've tried to remove the paper tray and put it back and the same message appears. Tried shutting off printer and back on, same message appears. It does print however from the MP Feeder, but I need to print from the paper tray because of volume printing. Can you help
  • Anonymous Dec 27, 2008
    I have the same problem with an IBM printer
  • 849 Answers
Select the proper tray from the properties of printer. the properties could get by right clicking on printer icon.
Posted on Nov 26, 2008
  • 10 Answers
SOURCE: my lexmark t520 says "load mp feeder letter"
Easy one. Open your tray back up and make sure that the paper settings are reflecting the type of paper that is in the tray. The times that I have seen the issue that you just described, the paper setting were off... thus causing this issue.
If that does not work. Powercycle printer. When it comes ready go to the Paper Menu, then to Default Paper source. Make sure that setting reflects the tray that you would like the printer to print from.
Hope that helps.
Posted on Mar 19, 2009
SOURCE: Will not print
Try to power down the printer (including unplugging it from the wall) then take out the paper trays. From there, reseat the tray guides (so pull them all the way in, then all the way out). From there replace the paper in the tray, and then re-align the guides to the paper. Plug it in, and then try a test print.
Posted on Apr 18, 2008
SOURCE: Lexmark T644 MP Feeder STOP ASKING FOR MP FEEDER???!!!
Thanks mate, it worked for me too and my works printers (work in IT and this 'error' was driving us crazy)
Posted on Sep 18, 2008
Corysf62
  • 188 Answers
This usually happens when the paper tray is set to the incorrect paper size.
This printer determines what size paper is installed in it by the little "fingers" on the left side of the tray. When you adjust the paper tray, it determines how those fingers are positioned, and therefore, how the switch reads the paper size.
If the tray setting is off, even by one little click, then the machine may read the paper size as other then letter. If this happens, you send a letter size job to the printer, and it doesnt think it has letter size paper, it will tell you to put letter paper in the MPF feeder.
If the tray is definately set to letter, but the machine still thinks it does not have letter, then the tray or the switch that reads the tray is defective, but 99% of the time it is just the tray is not set correctly.
The MPF door can be open or closed 100% of the time with NO EFFECT on how the printer works.
Posted on Nov 22, 2008
Testimonial: "Absolutely useful although I didn't see it when I worked it out by my own."
  • 13 Answers
SOURCE: lexmark t642 load mp feeder with letter
The reason that your printer is asking you to load paper into the MPF is that it doesn't think it has that size paper in tray 1 or 2. Make sure that the green paper guide in the paper tray that you want to print from is latched in the correct position. This guide tells the printer what size paper is in the tray. If you have it even slightly out of position you'll get this message.
Posted on Apr 30, 2009
Message window shows "load mp
The printer tells you to insert a letter format paper in the mp (multi purpose) feeder (the manual tray).
If you press the GO key the print probably proceeds with print job (if has the paper loaded in mp feeder)
Jun 15, 2011 | Lexmark T634 Laser Printer
My lexmark t430 says load mp feeder letter. what does this mean?
You have send a print job from your application (ex. word), and the paper format in this appl. is letter. The printer tells you to insert a letter format paper in the mp (multi purpose) feeder (upper the tray).
If you press the GO key the print probably proceeds with print job (if has the paper load in mp feeder)
Feb 23, 2011 | Lexmark T430 Laser Printer
Load mp feeder error optra t 642 printer
I received this message when I was trying to print a pdf file. I attempted messing with the positioning of green paper guide to no avail. My co-worker suggested I uncheck the Choose paper source by PDF page size box on the Print pop-up box. This did the trick.
Dec 08, 2009 | Lexmark T642 Laser Printer
I keep getting a Load MP Feeder Letter message. I can't clear what to do?
MP Feeder refers to Multi Purpose Feeder or Manual Paper Feeder or just plain bypass feeder. There should be a door that folds down to gain access to your MP Feeder tray. Try loading letter size paper on this tray.
Nov 24, 2009 | IBM Infoprint 1332 Laser Printer
Hi I get this 250.07 paper jam check mp feeder on Lexmark t644
Please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Lexmark T644 Laser Printer
Tray selection issue: Documents may be setup to print to the MP feeder, (multipurpose feed, not manual feed), but the printer will only pull from tray 4. I'm not sure why, earlier this week it would o
The usual reason that the printer will ask you to load paper into the MPF is that the green paper guides in the paper tray is not clicked in the right position. It only needs to be slightly out of position to give the wrong paper size info to the printer. The easiest way to confirm if the guides are correct is to print the Menu Settings Page. Check that the paper sizes listed in that report are the same as the actual paper sizes in each tray. If it's different you need to adjust the guide correctly. It's remotely possible that the sensing switch is faulty but it's more likely that the paper tray guide isn't latched in it's correct position.
May 29, 2009 | IBM Infoprint 1532 Laser Printer
Lexmark t642 load mp feeder with letter
Mar 11, 2009 | Lexmark T642 Laser Printer
Load MP Feeder
That is not an error message. it is telling you to load the Manual Paper feeder. Put some papaer in it and it will print. check youyr set up to make sure that you are printing to the trays not the manual feeder
Nov 20, 2008 | Lexmark Optra M412 Laser Printer
Will not print
Oct 10, 2008 | Dell W5300N Laser Printer
Jul 29, 2008 | Lexmark T644 Laser Printer
Lexmark Optra M412 Laser Printer Logo
608 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
