Question about Xerox DOCUMATE 510 Flatbed Scanner
Driver won't load
I lost the original software disk and I needed to setup the scanner on a new PC running Vusta. I downloaded the driver from Zerox, but it won't load. I also ordered replacement disk and had the same results. The driver starts the loading proccess and get almost fully loaded and stops and backs out everything it loaded. Then the message simple reads "Driver failed to load".
  • 849 Answers
Lost setup disk to Canoscan LiDE 100 scanner, want to install
You can download the installation driver and software from manufacturer's support website by clicking this link
On the page which opens, select the operating system of your computer (Windows Xp/ Vista..) from the drop-down menu. Then download the required drivers and software.
The list of available drivers will load only after selecting the operating system of the computer.
Hope this solves your problem. Thanks for using FixYa.
Aug 27, 2010 | Canon CanoScan LiDE 25 Flatbed Scanner
I have a cnoscan Lide 30 flatbed scanner and have tried to load it on my new Acer computer with Vista and cannot get it to operate when I install the original Canoscan Lide 20/30 disk driver. Can you help...
You are correct, you will need to download 2 applications from the canon website in order to use your scanner.
you will need the drivers which are here
http://www.canon.ca/english/index-customersupportdownloads.asp
You will need to navigate to the downloads then select the model you have. The two programs are the LIDE Driver for windows then you will need to install the Toolbox software. you will require to reboot your computer between the installs so it's best to download both to your computer then install the LIDE and then the Toolbox.
Jan 15, 2010 | Canon CanoScan LiDE 30 Flatbed Scanner
Unable to download software
yes your original disk is setup for only like windows 98 xp nt vista not windows 7 all you have to do is go to epson.com and input your make and model printer then download the driver for windows 7! good luck!
Dec 18, 2009 | Epson Perfection 1660 Photo Flatbed...
Lost disc to install scanner
You can download the Driver Here
Regards,
Waqar.
Aug 19, 2009 | Office Equipment & Supplies
Scanner not working need software install
hi friend,
u can download software in
www.econtentos.com/scanner-driver.htm
Installing a scanner on newer PCs is pretty straight-forward. If the scanner is a USB device, you'll need to install the software CD that came with the scanner. These will normally be one or two disks and a few others that usually only prove to be trial software or other programs you do not need. Be wary of installing these third-party CDs, as you likely will never use them and they tend to want to take over the way media is handled on your computer.
First, unpack the scanner from the box. Make sure you have all of the attachments and especially the quick setup instructions if they were in the box. You can assemble the scanner and set if off to the side. You can plug the power cable in, but do not plug the USB cable into the computer.
Boot up the computer and load the scanner software disk into the CD ROM drive. If it does not launch automatically, you can navigate to it through My Computer and click the setup.exe file. If there are additional disks for your scanner that need to be loaded, you will be prompted for them.
Once the software has been installed, you can then attach the USB cable to the computer. Windows should find the new scanner and load the drivers for it automatically.
Troubleshooting Scanner Problems:
If your scanner had worked in the past but has stopped functioning, you can usually unplug the scanner, then go to Add / Remove Programs in the Control Panel and remove the scanning software. Then you can repeat the installation process above.
thank u for using fixya
regards,
sivaranjini
Aug 11, 2009 | HP Photosmart 2610xi All-In-One InkJet...
HAVE A LEXMAR P3150 LOST THE DISK TO DOWN LOAD TO NEW COMPUTER W2HAT CAN I D0
Hey,
The lexmark drivers and software required for installing the printer is available at www.lexmark.com
Select Drivers & downloads then driver finder.
Type in your model x2350 for example
Select your windows version
Download the setup program.
1.Download software
2.Run the downloaded setup
3.Plugin the printer when asked
4.Done
Thanks,
Ekse
Mar 06, 2009 | Lexmark Office Equipment & Supplies
I lost the Lexmark X5650 Printer, Scanner, Copier and Fax CD, What can I do?
Hey,
1.Download software
4.Done
Thanks,
Ekse
Mar 05, 2009 | Lexmark X7350 All-In-One Printer
Lost my webcam installation cd
can someone help me? I lost my CD installation too...
May 25, 2008 | Logitech QuickCam Express Web Camera
Xerox DOCUMATE 510 Flatbed Scanner Logo
173 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
