Question about Zanussi ZDF490 Electric Double Oven
I purchased a Zannusi Oven 15 months ago, and the lettering on the control panel wiped off. I contacted Proctor and Gamble who manufactured the product i'd purcghased and wiped over the panel with. Proctor and Gamble witnessed what their product has done and they said that it is a design fault. I obviously have cleaned the oven and use soapy water. I use the Flash clean and care as it is is detailed as a gentle cleaner and on the bottle is more than suitable. The oven is a Zanussi ZKC6020W. Proctor and Gambl ahve offered to have works done to remedy the problem but when I attempted to purchase a control pannel was told this is not a consumable part. Please advise on if this is a product design fault or if this has been recalled or if you feel that this is a cleaning product fault.
2 Suggested Answers
SOURCE: oven door zbf360x zanussi
Open the door half way, grasp it firmly and pull as hard as required using a slight side to side motion to release the hinges which are attached to the door.
There are then to nuts on the bottom of the door which when removed allows you to split the door in half.
The hinges have a little lever on them such that they can be jammed open against the door. Once the hinge hook is in the oven housing simply turn the latch the other way, stand back and have a beer.
Posted on Feb 28, 2009
We have an unnamed oven serial number framtid ov10 in our new house, the electric circuit shorted out 2 days ago and now the oven wont heat up although the grill fan light and display seem to work?
Unplug or isolate the electric before doing anything.
Check if you need to take the oven out or if you can remove the heating element by unscrewing a few nuts and bolts from within the oven itself .
Elements cost about £10 - £15 in the UK and are available from Ebay or Electrical Parts wholesalers or alternatively from the company itself if you can find a manufacturer , The name shown on the product may just be a Logo brand name but manufactured by a larger company for a specific store.
Jan 09, 2018 | Ovens
No heat from my Electrolux oven fan is running but oven light not working the oven is only six months old
Thank you for your inquiry, friend!
Based off the information you have provided your Electrolux oven is not heating properly. I would recommend performing a reset on your range which you can do by disconnecting power from it for ten minutes. If that does not help to correct your issue it could be a faulty element or control panel. I understand your range is only six months old typically the warranty for a range is one year. I would contact the manufacturer for proper resolution regarding a warranty. I hope this is helpful. -Matt
Oct 17, 2014 | Electrolux Ovens
Indesit cooker
I would contact indesit on there tech help line .Its on line on there site
Apr 21, 2017 | Ovens
Has anyone had a problem with the inner glass on the Lamona oven door exploding. Mine just has! It's only 18 months old and hardly used. I wonder if it's the difference in temperature betweeen the hot oven...
We bought our kitchen from Howden's as well about 15 months ago. They installed a Lamona double oven and hob. Last night when opening the door to the bottom oven our glass on the inner door exploded as well. Maybe there was a batch of defective ovens as ours sounds as though they mat have been bought/manufactured at the same time.
Mar 07, 2011 | Ovens
Is it possible to transfer the 'self clean' ovens from an Elotrolux EKC 6047X to a Zannusi ZKC 6020W? The Zannusi is 16mths old, and the Electrolux is 40 mths old. My wife would like self clean ovens,...
If by 'transfer the self clean' you mean just putting the oven liner panels from one oven to the other then maybe, but if you mean to transfer the high temperature clean cycle oven complete including wiring alterations then i would have to advise you NOT to do so on fire safety grounds as i'm sure it would invalidate any warranties and more importantly breach your home insurance conditions.
Dec 15, 2010 | Ovens
Thermador SC302 double oven the top oven is not getting hot
We've had the same problem. I contacted a local sales room and they contacted their rep who promptly mailed the replacement parts I requested (I'd looked up the part numbers already). Now I'm waiting to find someone who will reasonably do the work.
Aug 10, 2009 | Thermador SMW272 Electric Double Oven
Overlay Panel bubbles up!
I had the same oven panel overlay bubbling problem on my GE oven purchased in 2008. It started peeling and bubbling within the 1 yr warranty, and GE sent me a replacement panel. This new part began bubbling again within 4 months. Again, I called but now they say it's out of warranty and they will not replace it. Obviously there's a manufacturing defect in this part. The panel looks terrible. It appears that GE no longer cares about the quality of their products.
Jan 02, 2009 | Ovens
Oven fan zannusi zbf360x
Remove rear panel in back of oven, there you will see the fan,remove fan blade,usually left hand thread, and remove screws that hold fan, if they are not accessable from inside the oven then you will have to remove oven from housing, and remove rear outer panel to access fan screws and connections.
Remove fan and replace in reverse order.,don't forget the nut that holds the fan is a left hand thread.
Plz rate this solution.
Thanks.
Dec 14, 2008 | Zanussi ZBF360X Electric Single Oven
Top oven won't turn off
the problem is the high voltage relay which might be on the control board or on the back of the oven . the contacts on the relay are most likely fused together check with a ohm meter.
Dec 12, 2008 | Whirlpool RBD305PD Electric Double Oven
Zanussi ZDF490 Electric Double Oven Logo
50 people viewed this question
Top Zanussi Ovens Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
