Question about Locks & Locksmithing
How do we adjust an aluminium door?
We Have a set of aluminium double glass doors. The problem is the opening door seems to have 'dropped' and we have no idea how to 'Lift'' it so that it can open and close properly, any ideas?
    Novelist:
  • 148 Answers
The door has a cam that has to be adjusted to force the pin up
call a local glass company and ask them where the adjustment is located
there is usually some type of access plat near the bottom of the door frame close to the hingee on the inside close to the bottom
Posted on Jan 06, 2009
Drivers side window will not go completely airtight when up.drops and goes up when door opens and shuts, but not high enough to seal correctly
My 02 had this same problem, the glass has shifted position in the mechanism. You will need to take the inner door card off to get at the mechanism, lower the glass about half way then reach through the large opening in the door panel to feel for the large 'cog' shaped retaining bolts that hold the glass to the mechanism (one either side, both facing the outer door skin). A 5mm torx or allen key bit is required to loosen both 'cogs'. You can then adjust the glass position. This is possibly best done with two people...once the glass is loose, make sure you move the glass first to break the seal (it may have stuck to the rubber seal over time, so will not move much), then gently tighten into place, raise the window to the full up position, shut the door fully, then with the help of an assistant, one inside the car one outside, move the glass into the desired place and tighten the cogs. Open the door, fully lower and fully raise the glass, then keep the switch in the up position for 5 seconds, this teaches the ECU the new position. Check that the window closes when you open and close the door, if not, try adjusting the glass angle with the adjustment screws located at the very bottom of the door. When in the right position, you should just be able to pull a sheet of paper past the glass and the seal. Boom, done!
Sep 30, 2016 | 2004 Mini Cooper
Whirlpool fridge door "drops" into place when opening.
are both door leveled? if not the door cam worn out and need replacement
Nov 23, 2017 | Whirlpool GSS30C6EYW 30 cu. ft....
Frigidaire Side By Side Door Stop adjustment
I'm sorry, but the answer is no. The doors are set on hinges with what they call cam risers that allow the door to open and close smoothly but there is no adjustment for them.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 15, 2012 | Frigidaire Refrigerators
Remove door and glass on whirlpool gbd307pdq1 double oven
hi there sometimes glass will just pull up on sliders on the side just open door etc and the glass panel should simply slide up.
Nov 27, 2011 | Whirlpool Ovens
Hi. The outer glass grill door has come away and smashed on the floor when going to open grill by the handle. Can't see that there were any screws in the bottom of this. Would they have been factory...
Sometimes the glass is bonded to the door (glued) which may be why you can't see any screws.
It seems as if you are going to need a new grill door complete.
Dec 30, 2009 | Electrolux EOG9330 Gas Double Oven
Little door that lets ice fall into glass won't
need to check door chute hinge it could be broken
Nov 05, 2009 | Kenmore Refrigerators
My whirlpool double oven lower door won't stay closed all the way. model RBD305PD810. is there an adjustment that is needed?
If it is a drop down door, then you need to replace both door hinges, if it is a door that opens sideways, then it is probably the door catch, or door striker that needs to be replaced.
Please rate my solution.
Thanks.
Nov 01, 2009 | Whirlpool RBD305PD Electric Double Oven
Cleaning between double glass oven door
Without disassembling the door, you can't. the glass is sandwiched between two rather rugged metalized gaskets to create an air pocket (or vent space) to keep the outside glass cooler than the inside.
Feb 04, 2009 | Ovens
Door Glass
The only solution seems to be ordering a custom glass piece matching the dimension of the glass on the oven door. However, since my oven is white I would like the door to be white too. Although I have found glass guys who can tint the glass door dark, I have not found anyone who can color it white. Let me know if anyone knows such a glass vendor.
Mar 14, 2008 | Amana AOGD2750 Gas Double Oven
Jenn air double ovens
First, with the door closed, find the screws at the bottom of the door and remove. With an assistant, open the door and remove any side and inside screws you find. The door will separate into two halves. Be aware that most glass is not clipped in...they can fall and break. Remove the front panel from the door...the door may try to slam shut. To clean the glass, use a blue cleaner and a scrubby or very fine steel wool rubbing gently. Scratches are not allowed! Take pictures of what you're doing so you can replace. Be careful of brittle door insulation.
Oct 30, 2007 | Jenn-Air JJW8230D Electric Double Oven
Locks & Locksmithing Logo
969 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
