Question about HP DeskJet 610cl InkJet Printer
No multiple copy option
Yeah, The # of pages option is there, but the '# of copies' remains brown, or grey, whichever- not 'on'. Automatic always preferred in the modern world, now I can't get a date. Word travels fast! Mighty Fine + Thankin' You! Downemup
5 Suggested Answers
  • 5568 Answers
SOURCE: My hp 1320 prints only one copy
Windows may have eaten its baby again- that is, the driver for that printer.
Open the Control Panel, then Printers and Faxes, delete any listing for that model of printer, make sure the printer is on and connected, then reboot your system. This will force Win to 'find' the printer and install an uncorrupted driver for it.
(=Plug and Pray)
Posted on Sep 23, 2008
SOURCE: hp LaserJet 1320 will not print multiple copies
Do you have a PCL6 driver installed? We had the same problem with several networked HP printers - downgraded the driver to either PCL5 or PS depending on the printer and driver available and users are now able to print multiple copies.
Posted on Nov 28, 2008
SOURCE: HP J5780 All in one printer
When i try to make a copy, it printing out just only whole page black color even ,I put color button.Why.
Posted on Nov 29, 2008
  • 224 Answers
SOURCE: HP J4680- change copy settings so printouts are fast draft
Change settings and copy from HP Solution Center
  1. Open HP Solution Center.
    • Windows 2000: Click Start , click Programs , point to HP , and then click HP Solution Center .
    • Windows XP: Click Start , click All Programs , point to HP , and then click HP Solution Center .
    • Windows Vista: Click the Start icon (c01319360.gif ), click All Programs , point to HP , and then click HP Solution Center .
  2. Click Make Copies . The Copy window opens.
  3. In the Paper section, click A4 on the Size drop-down list.
  4. In the Start Copy section, click Black or Color .
  5. In the new window you can also change the copy settings
Posted on Jun 24, 2009
SOURCE: My hp 1320 prints multiple copies instead of one copy
Go to "printers and faxes."
Right click on your printer and select "Printing preferences."
Select "Advanced" tab
Double click "paper output"
If "Copy count=2" then change to 1 and apply
Set "copy count=2" then APPLY
Repeat the above and now set "copy count=1"
The process of setting and resetting the copy count fixed my issues.
Posted on Mar 01, 2010
0 characters
1 Points
Hp 4345
Check ADF unit (automatic document feeder) working condition.
For diagnoses : Insert few paper(ex:10papers) in ADF unit & do copying, if UR succeed in copying, ADF is working well.. If not check the fault.
HP M4345 facilitated with digital sending option., for configuring digital sending U need to create shared folder with fully permissions in system. Better visit hp site or google to know about how to create folder.. You can do multiple scanning once configuration completed successfully..for more info visit:
Sep 04, 2014 | HP LaserJet 4345mfp Printer
How can i print multiple copies of the same document with 3 pages and have the printer staple the copies in the correct groups?
In the print driver you should have the option to collate, you need to make sure that that option is on, and when you go to send the print job, you need to make sure that you adjust the finishing options in the driver to tell it to staple.
May 11, 2011 | HP LaserJet 4250 Printer
Brothers printer mcf, how to make a 2 sided copy?
there is no options to make two sided copy can do like this once copy done use same paper to copy in opposite side .... you can copy multiple pages Make sure you are in Copy mode ........... Load your document.......... Use the dial pad to enter the number of copies (up to 99).............. Press Black Start or Color Start.
Dec 14, 2009 | Brother Multi-Function Center MFC-240C...
Ricoh 1027 ADF grabs multiple pages causing adf jam
you need to replace the lower of 3 rollers in the ADF (sep roller), for a temp fix you can clean this roller with wd40 as it will soften the rubber and get it to "grip". these rollers (lower of three) are always the first to go "bald on any mnf copier in the ADF and Drawers causing multiple feeding. they are used to allow one page at a time as they either turn backwards or offer torque (resistance) to lower pages
Aug 04, 2009 | Printers & Copiers
FIRST printed page is quite wrinkled, the rest are fine
Hello sir;Try to print one page, when the paper process half way then stop the machine, remove the cartridge, check the paper is wrinkling, if yes ,that's meanspaper feed roller dirty or registration roller slipply, ortherwise, check the fusing unit, need to replace presure roller. The 2nd issue, you need to replace paper stop roller or rubber pad.
May 12, 2009 | Brother HL 5250DN Laser Printer
Printing too many pages
try this touch add functions key then printer settings one option should be number of copies make sure it is set at 1
Jan 21, 2009 | Canon imageRUNNER 5000 Copier
Paper error
I hope that this can help someone else as it has taken me all day to fix this issue on a C6180 all-in-one machine. I will ignore the normal solutions to a "paper mismatch" error such as your settings not matching your printing media. Obviously, check these first:
If your problem is not solved with the above steps, you have an issue with your "spot sensor" and it needs to be calibrated. Instructions:
1. Press * and # at the same time, and then release both keys.
The display reads "Enter Special Key Combo".
2. Press 3, 2, and then 9, releasing each key before pressing the next.
The display window should read "Service: R0622M" with a revision number.
3. Press the right arrow button once.
The display should read "System Configuration".
4. Press Enter or OK.
5. You will be prompted to enter serial number. Do not enter any information
on the unit.
Press the right arrow button until "media sense calibration" appears in the
6. Load Paper into the unit and then press Enter or OK.
7. Media Sense Calibration process will take place.
It is one of the rare times that HP chat has fixed my printer at no cost and instantly. Here is a full transcript describing my issue and the HP chat solution:
Nov 11, 2008 | Printers & Copiers
In the driver there are "copy protect" and "Watermark" options.
See if these are on.
Oct 08, 2008 | Konica Minolta bizhub C250 All-In-One...
Cuts off left hand few letters in a word
Either put the paper closer to the other side of the glass, or go into the settings to see if it is copying or scanning at 100% See if gives you the option of stretch or shrink to paper size. Also, see if it says Crop Automatically versus copying or scanning entire glass. If there is a choice between Automatic, Home Mode, or Professional Mode, try each one. There is always a reset button to return to original defaults. If you are given the option of seeing a preview first, always do that, even though it takes a little longer.
Aug 06, 2008 | Dell A960 All-In-One InkJet Printer
Scanning multiple copies
The trick is to put the scanner in PROFESSIONAL MODE !!!!! Select that option in the top right corner of the Epson Scan application when it first opens up.
Dec 21, 2007 | Epson Stylus CX4200 All-In-One InkJet...
HP DeskJet 610cl InkJet Printer Logo
15 people viewed this question
Top HP Printers & Copiers Experts
Brian Sullivan
Brian Sullivan
Are you a HP Printer and Copier Expert? Answer questions, earn points and help others
