Brother dcp-135c I cannot see how to scan and save a file in pdf format
  • Anonymous Apr 02, 2009
    Just istalled the DCP-135C, anxious to use the scanning mode for documents. When I press scan, the display says "connecting to PC" for awhile then goes back to the normal display without scanning. In other words, nothing happens! If anyone uses this model to scan documents please let me know what you do to make it work.
I want to scan a 4 sets of documents under pdf file, but i can only scan it one by one either by file or mail.
Please advise on how to scan it on pdf file.
Thank you.
Posted on Apr 21, 2009
Brother DCP-135 unable to clean
How to Open Brother DCP-135C
Loosen + remove 3x Cross-Collar Screws on Control Panel. Rise, 2x unplug Control Cable, Control Panel release to forward. Remove 1x Cross Collar Screw front top left, remove the Casing. Remove upper Cable Covers of Scanning Unit Cables, unplug and free the Cables. Remove Scan Unit Pillar, rise complete up and release backward. Remove 3x Cross-Screws at the front top, 1x inside the Cable Compartment, 2x rear top. Remove upper Cover. Now, the Print Head is accessible.
Brother DCP-135C Oeffnen
3x Kr-KragenSchrauben an Bedienfeld oben loesen. Hochklappen, 2x Stecker abziehen, Bedien-Blende nach vorne ausklinken. 1x Kr-KragenSchraube vorne oben links loesen, Front-Verkleidungen abnehmen. Obere Kabelabdeckungen der ScannUnit abnehmen, Kabel abziehen und freilegen. ScannUnit Stuetze loesen, ganz hochklappen und nach hinten ausklinken. 3x Kr-Schrauben vorne oben, 1x im Kabelfach, 2x hinten oben loesen. Obere Verkleidung abnehmen. Jetzt ist der Druckkopf zugaenglich.
Jan 21, 2014 | Brother DCP-340CW All-In-One InkJet...
How do I scan a document?
see the printer is connected to the computer, printer is powered on, & the document u want to scan is layed upside down in scanner. then open "paint" software & go to "from scanner or camera". follow the instructions on screen & finally save the image in required format which u will see in save window bottom side (drop down menu).
Sep 03, 2011 | Brother DCP-135C Flatbed Digital MFC...
LOST INSTALLATION DISC FOR MY BROTHER DCP135C PRINTER HOW CAN I GET ANOTHER ONE
The drivers and software for the Brother DCP-135C 4 IN 1 Flatbed Digital MFC All-In-One InkJet Printer can be downloaded by clicking on download below.
Download
OR use the link provided
http://download.brother.com/welcome/dlf002943/135INST-A.EXE
1.Enter the link provided in the navigation bar
2.And press enter
3.You will get a pop-up screen, select save as to destination you wish to save.
4.After completion install the downloaded file.
I hope this information will be helpful. Thank you for using FixYa!
Jan 31, 2011 | Brother DCP-135C Flatbed Digital MFC...
When I try to use my brother MFC-465CN as a scanner, it does not allow me to scan into a file. It always scans in a PDF file, even it I select scan to file.
You can configure the "File Type" properties while saving as you will see the explanation in this link.
File Type:
This is where you can change the format that the file will be saved in. If you choose PDF(*.pdf) to scan and save the data in pdf format it will be saved as pdf file.
Hope this helps.
Sep 28, 2010 | Brother MFC-465CN InkJet Printer
How do i scan on my brpther DCP-135C
there is scaner function as printer functino( which u load from printer driver. from there u can scan any docement-nepal
Feb 03, 2010 | Brother DCP-135C Flatbed Digital MFC...
Brother DCP-135C won't print yellow
1 years?
Means still under warranty for print head. maybe print head faulty. Better send to Brother.
Jan 27, 2010 | Brother DCP-135C Flatbed Digital MFC...
I lost my brother dcp 135C printer driver. where can I find a free downloadable site?
here you go software and driver please rate me http://welcome.solutions.brother.com/bsc/public/eu/gb/en/dlf/dlf/000000/002900/dlf002942.html?reg=eu&c=gb&lang=en&prod=dcp135c_eu_as&type2=1&os=74&flang=4&dlid=d
Jan 04, 2010 | Brother DCP-135C Flatbed Digital MFC...
Printer says refer to manual troubleshoot problem 68. Printer is BROTHER DCP-135C . Haven't got the manual.
There is no DCP-135C on Brother's website, but there is a 130C, which I suspect is simply a series number rather than a specific modle number. Check out this manual, see it is of any help.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_DCP_130c_EN_294.PDF
Aug 07, 2009 | Brother Office Equipment & Supplies
Brother printer/fax/scanner MFC-240 C
i need to scan and save multiple documents under one pdf file. how do i do this and save all under one file?
Dec 18, 2008 | Brother DCP 130C All-In-One InkJet Printer
BROTHER PRINTER DCP-135C INSTALLATION
i got disk if u want i can uplod disk and u can download
Dec 12, 2008 | Brother DCP-350C InkJet Printer
130 people viewed this question
jasbo
jasbo
