Question about Kitchen Ranges
How to remove the oven door on Whirlpool model GR450LXH
  • jomitchell Nov 26, 2008
    Duh! Thank You larryb!
    Sergeant:
    Champion:
  • 291 Answers
Open the door and slide down the latches on door at henges, raise door till it catch, raise up and slide out.
Posted on Nov 26, 2008
How to remove whirlpool oven door and take out glass
Usually the oven doors when opened just slide out of the hinges especially on whirlpool. Once you slide out the door you will have to remove the inner door screws as well as the handle screws and the screws around the sides of the door if there are screws there too. Then you can get to the glass. Then you should be able to replace or clean the glass.
P.S. On some models you may also find screws holding the door to the hinges. If so you will want to remove those too.
Nov 05, 2012 | Ovens
Remove glass oven door
The video on You Tube will show you how to remove your oven door. You may need to watch it all of the way through to see your type of hinge. The video shows four different hinge types which are common and so covers most oven models.
Oct 20, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
I can't remove the door on a whirlpool oven model RBS305PDB
I removed the oven door without putting in the door removal pins that I was supposed to use. Now I can't put the door back on.
Oct 22, 2009 | Whirlpool RBS305PD Electric Single Oven
Whirlpool GMC275PD build in electric double oven
I have a different model Whirlpool oven but if the door opens downwards then there are usually two smalll catches on top of the main hinges. Lift these up (they can be quite stiff) away from the oven, partially close the door and it should lift upwards to free the hinges.
Hope this helps
Sep 14, 2009 | Ovens
Can not remove oven door
Usually open the door to the first setting where the door is 6 to 10 inches from the reame let it sit there and pull up and out . The springs are in the door and the hinge sits into a reciever in the range.
Mar 26, 2009 | Ovens
Can't remove oven door from Whirlpool model GR450LXH
the hinges problably require to be "locked" beforer removing from door frame, usually explains in hte manual "how to remve door". if needed, you can input your model number here, to download a copy
http://shared.whirlpoolcorp.com/product_literature/literatureSearchResults.cmd?siteCd=WHRCOM
Nov 26, 2008 | Kitchen Ranges
Whirlpool Oven Self Cleaning Lock
sound slike you have a bad monitor switch on the latch motor assy( it should sense that its locked and advance into cleaning however since the switch is bad it continues to try to lock itself.you can try to pull nit out and remove the back panel from stove teh atch/lock assy is mounted there adn chek the switch mounted on it for operation.( just looked up and the entire lock/latch assy is no longert avail as of 6-07
Apr 01, 2008 | Kitchen Ranges
Microwave oven door removal
First you have to tell why you want to remove the door. The door seal is important to keeping the radiation from excaping and is not recommended to fool with it.
Dec 28, 2007 | Whirlpool MH7135XE Microwave Oven
Kitchen Ranges Logo
99 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
