Question about HP LaserJet 1020 Printer
Every time i try to print multiply pages a window opens up
Which says "HP Laserjet 1020 Manuel Feed"
for each page that i want to print.
  • 849 Answers
Select the proper tray from the propeties of printer. it will take paper from that tray.
Posted on Nov 26, 2008
How do I align the HP Laserjet 1020 to print straight? Its printing crooked every time. No two sheets are in the same position
Most likely to be a page feed problem, look online to clean page feeder rubber rollers.
Try here for the pdf manual which covers problem with jams and skewing
http://www.hp.com/ctg/Manual/c00264334.pdf
Mar 05, 2015 | HP LaserJet 1020 Printer
How to find print count in hp laser jet 1020 plus
To Check the page count follow the following steps: -
-Go to Start, then Printers and Faxes
-Right-click on the HP LaserJet 1020 and Select Properties
-On the General Tab, under Printing Preferences, Click the Basics tab, and select the About button
-Page Count at the bottom of the window
Good Luck!
Hope this helps! Dont forget to appreciate the solution!!
CreativeTECH
Feb 15, 2011 | HP LaserJet 1020 Printer
My hp laserjet 1020 cant print and did feed the paper
you min that you have a blank page ? if yes, your laser unit is locked, the interlock switch was not actuated, open the front cover and look inside , with a screw drive try to touch the switch is it ok, if broken you must replace it or repair.
Dec 06, 2010 | HP LaserJet 1020 Printer
How do I get a page count on my laserjet 1020?
The printer may not have it on the panel board but you can try the bellow , although this step may be driver related :
If you are using windows XP
> Go to Start , then Printers and Faxes
> On the General tab, under Printing Preferences
> It should give you a Page Count in the bottom of that window
Remeber to rate it if it works for you.
Feb 02, 2010 | HP LaserJet 1020 Printer
LaserJet 1020 printing solid black pages
1.replace the cartridge.
2. check PCB board contacts
3. replace PCB board
Jun 19, 2009 | HP LaserJet 1020 Printer
Images of previous page remains on the new printed page
It is either a bad drum in the toner cartridge or toner on the fuser. Try changing out the toner. If the problem remains, you'll have to get a new fuser module.
Nov 29, 2008 | HP LaserJet 1020 Printer
Doesn't took A4 Page, page torns and come sometimes jammed
Brother change the toner and give the printout hope this may solve
Aug 11, 2008 | HP LaserJet 1020 Printer
HP 1020
Check that paper and paper tray are installed correctly. Print from MP tray and check if it's still slanted. If not, the problem is related to the tray and the feed rollers for the tray. Check also these feed roller and separation pad.
Jul 31, 2007 | HP LaserJet 1020 Printer
HP LaserJet 1020 Printer Logo
93 people viewed this question
Ben Johnson
