Question about Brother CS-80
F4 Error My machine is displaying "F4" when I plug in the presser foot. It sews without it...But I really prefer sewing with the pedal.
  • 2 more comments
  • jmanbkga07 Aug 03, 2008
    Same problem--- foot pedal results in F4 code when connected.
  • Anonymous Aug 30, 2008
    the same problem here. F4 would not go away, continues beeping. don't konw what to do.
  • peta field Jun 12, 2013
    wish we could get an answer for this i have a brother nx200qe as soon as i put in the foot pedal F4 comes up beeping i want to learn free motion quilting and am finding this a bit tricky without the pedal.....please help...
    I wish someone would answer this problem i have a brother nx200qe as soon as i put i the foot pedal error F4 is displayed im trying to teach myself free motion quilting and am finding this a bit hard without the pedal please help us someone....
In the middle of sewing the machine made a loud noise and then would not run just chaters when you push the start button its like it is jambed the model is cs80
Posted on Dec 17, 2007
My machine displays a f4 and does not want to work, what can I do?
Posted on Feb 10, 2010
Error message foot too high. To correct this, it is necessary to restart the machine. Unless it is impossible to continue sewing.What is the problem?
Try taking your presser foot off and lower the presser foot lever. Does the error code go away? The machine won't sew without the presser foot to hold the fabric down, but without threading the needle, will the machine run without the presser foot? Now try the standard presser foot (usually J ) and if you get the error code then the sensor at the top of the presser foot assembly is out of adjustment. Without knowing more about your machine this is all I can suggest.
Good luck,
Bob
May 30, 2017 | Sewing Machines
E 1 error message
Make sure you lower the presser foot before continuing the operation.
The foot controller was pressed (or the start/stop button
was pressed if the foot controller is not connected)
and the reverse/reinforcement stitch button
was pressed while the presser foot was raised.
Mar 01, 2014 | Brother CS6000i Computerized Sewing...
430 aurora
Probably too thick to feed without dislodging the bobbin case, causing the error message.
May 07, 2013 | Bernina Activa 140
Foot pedal not working
Well, you are definitely getting power from the electric plug in.
Let's do some diagnostic work. Do you hear anything when you press the foot pedal? Any hum? Did you happen to leave it in bobbin winding mode?
your machine doesn't have a "sew" button for use without the pedal. So please rotate the hand wheel toward you as you press the pedal. Did the motor take over and sew?
If you know someone with a meter... have them test the pedal. (they will place probes on/in the part that plugs in which tests for shorts, etc.) If that tests ok... then we know it's something more than the pedal and it will need servicing by a Singer Tech.
Aug 27, 2012 | SINGER 7470 Sewing Machine
Vintage Tough and Sew Model # 628 PRESSER FOOT QUESTION!
You should be able to figure out which shank your machine has here:
http://www.sewingpartsonline.com/sewing-machine-presser-feet.aspx
If you have the manual, it should show you how to change the presser feet.
SINGER Instruction Manual pdf model 628
If your machine and presser foot look like the one in the video, the screw on the left side of the presser foot should be what holds the presser foot in place.
Singer Touch and Sew Threading and Bobbin Winding
There may be other videos here that would be helpful.
Jun 06, 2017 | Singer Sewing Machines
My Rose sewing machine will not sew. It beeps and the presser foot icon flashes. I have re threaded, re bobbined, re placed the presser foot, and I think I have cleared the memory, but I am not really...
That light means you need to lower the presser foot. It cannot sew until the foot is lowered. The lever to lower the foot is behind the needle area on the back.
Feb 05, 2011 | Husqvarna Rose
How to adjust the tension of the presser foot on a brother sewing machine model ls-2220? I am trying to lighten the pressure of the presser foot for machine quilting.
You are not actually able to adjust the presser foot. For quilting you should pick up a "free motion" foot pedal made specifically for that. They run on e-bay for roughly $10-$20. Make sure you get one that fits your type of machine.
Dec 21, 2010 | Brother LS-2220 Mechanical Sewing Machine
I am getting error message E4 when foot pedal is plugged in. Unplug the foot pedal and the machine goes back to normal with the exception that you really can't sew without the foot pedal.
Your reverse reinforcement stitch button was pushed or needle position was pushed while bobbin winder was moved to the right. You can download a free manual brother-usa.com and you will see all of the troubleshooting and error messages there
Sep 10, 2010 | Brother CE4000 Computerized Sewing Machine
F4 error on my brother cs-80 sewing machine
Can't answer your problem, my problem also. But I don't have the auto button, so I am really stuck. Was hoping you got the answer and did not have time to post.
Amy
Apr 12, 2010 | Brother CS-80
Brother CS-80 Logo
912 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
