Question about HP Designjet 4000ps InkJet Printer
I was settting up a brand new HP designjet 4000ps plotter, everything went on well until the point of ink system setup. I put in the ink catridges but the screen displayed an error message code 24:03 ink setup failure and requesting that I should instal new setup printheads. From the manual the ink is supposed to be visible from the printhead window, but NO ink is visible. Is it possible to restart the whole setup process afresh or any idea on how to solve the ink setup failure (tube purge failure). Please assist!!!
  • wayne churchill May 11, 2010
    Did you put in set up printheads or the normal ones??
    Champion:
  • HP Expert
  • 202 Answers
Try the following:
?? Switch the Power OFF from the back of the Printer and disconnect the
Power cord. Reconnect the power cord and power On the Printer.
?? Try purging the Ink Supply Tubes again once the Printer has been
rebooted.
?? Install new Ink Cartridges in to the Printer and try purging the Printer
again
If problem persists then replace the ink supply station(iss) assembly
Posted on Jul 17, 2010
  • 20 Answers
Ofcourse U can Purge Ink Tubes Using Same Dummy PRintheads
mail me for steps
Posted on Sep 11, 2009
Plotter hp 4000 message maintenance #2 required
Maintenance kit 2 includes the following
This Preventive Maintenance Kit contains the following components:
?? Complete Carriage Assembly (? Page 8-53).
?? Ink Supply Tubes and Trailing Cable (? Page 8-33).
?? Scan-Axis Motor (? Page 8-59).
?? Belt Assembly (? Page 8-58).
?? Most Left Spittoons (? Page 8-43).
?? Middle Left Spittoons (? Page 8-44).
?? Scraper (located on the Service Station).
Once installed, you reset the counters, link for manual:
http://www.partsnow.com/docs/service-manuals/hp-designjet-4000-service-manual.pdf
Feb 11, 2015 | HP Office Equipment & Supplies
Hp designjet 4000 plotter error01.0.10
Try the following: Switch the Power OFF from the back of the Printer and disconnect the Power cord. Reconnect the power cord and power On the Printer. if the issue persists replace the Gamut PCI PCA If the System Error continues, replace the Main PCA.
venkateshwar, hyd, A.P,India.
Sep 16, 2011 | HP Designjet 4000ps InkJet Printer
I have a Designjet 5500ps Printer and it is leaking blue ink, when printing, all my research indicates that I need to replace the carriage tube connector, but I am unable to find the replacement part.
Hi there
May be you can try to contact any Authorised HP Service centre for your probelm. Could you give me your correct location so i can tell you whome to contact?
Alternatively you can try to see where the leakage is taking place and try to seal it with silicon sealent so it can atleast last untill someone attends to the probelm from HP.
The technical term for it is INK TUBE ASSY. But make sure and tell the HP people about the size of the plotter that is 42" or 60" and also keep the Product Number and Sl. No. of the machine handy which is required by HP technical team. (You can find it at the back of the plotter)
Click here to find all the spares for your plotter.
Aug 24, 2011 | HP DesignJet 5500PS InkJet Printer
Printhead error showing frequently in plotter 4000ps
remove the print head and clean the contact.
The contacts in the back of the carriage assembly that mate with the contacts on the printheads also to be cleaned.
Aug 08, 2011 | HP Designjet 4000ps InkJet Printer
Errorcode 93:11 on HP designjet 4000
Unable to pressurize the IDS(ink delivery system). Ink Pumping problem.
Corrective Action: Try the following:
Remove ALL the Ink Cartridges and reinstall them one by one in to the
Printer.
Replace the Ink Cartridges.
Replace the APS Assembly.
If the System Error continues, replace the Ink Supply Tubes and Trailing
Cable
Jul 15, 2011 | HP Designjet 4000ps InkJet Printer
I have a HP Designjet100 Plus. The black went from ok to light to nothing. I have cleaned the printer head manually and thru the maintainance setting on the machine. Any suggestions? Do i need to buy a new...
You can try to disassemble the printhead and check for contamination.
First remove cap 1
than using a small flat screwdriver disassemble printhead (engagement points 2 and 3)
Warning - a printhead is filled with 8 ml ink
After disassembly - clean the printhead with fluid compatible with pigment ink (for black color) or compatible with water based ink (color printheads)
during reassembly - don't forget to fill the printhead with ink (2/3 of its volume)
May 19, 2011 | HP DesignJet 100 Plus InkJet Printer
HP Designjet 4000ps cannot start, error code 24:10
Turn the plotter of with the front panel button. Then hold down the down button
and cancel button while powering up. Hold the buttons until you hear a beep.
This should put you in the service tests. Scroll to "Others" and press enter. scroll
to 10.1 Bag Broken Recovery and press enter. This will tell you if it is seeing a
faulty cartridge (0=yellow, 1=magenta, 2=black, 3=cyan).
Mar 01, 2011 | Office Equipment & Supplies
My Designjet 4000ps is asking to install setup printheads
setup printhead used for priming of ink tube *** to remove the air from tube or blokage it comes with unit when u purchage, pls install them one for each colour then machine performs the test & then u install the new printhead & calibrate the plotor
PLS DONT USE THE OLD PRINT HEADS AFTER PRIMING>>>>>>>>>>>>>>>To keep the device safe
Apr 07, 2010 | HP Designjet 4000ps InkJet Printer
HP Designjet 4000ps printhead error
Plz Sir
Stape :: 1
Your Printer Cover Open Few Minitus
Stape :: 2
Plz Chek Your Printer Property .... And Delete Your Own Page
Stape :: 3 Plz Check Printer Property And Port Tab Chenge Selected Port
Enjoy
Aug 17, 2009 | HP DesignJet 1055cm InkJet Printer
HP Designjet 4000ps InkJet Printer Logo
385 people viewed this question
Ben Johnson
