Question about Sony DVDirect VRD-MC3 DVD Recorder
No Sound with VHS Mono Input
I have an older VHS-C camcorder (Panasonic PV-L501D) and VCR (PanasonicPV-9400) that have only mono outputs (not stereo). The VRD-MC5 will notrecord any sound from my VHS or VHS-C tapes. I contacted Sony to askfor a software upgrade, but was told they could not provide one. Theyalso told me that they do not guarantee the VRD-MC5 to work with allmodels of camcorders and VCR's. I tried using a ''Y'' RCA male cableto see if providing two input signals, instead of one, will get thesound will work. But it didn't. I sent it back to Amazon, but just curious whether my VRD-MC5 is defective, or all VRD-MC5's have this problem.
5 Suggested Answers
SOURCE: Multi-function DVD recorder VRD-MC5
I had a similar no audio issue when using the I-Link connector and 8mm camcorder. I found that if i selected "Manual" rather than "Automatic" (copy everything) that I got good audio as well as video.
I have tried using a later model Sony miniDV camcorder with A to D passthrough from my 8mm Sony camcorder that I get better Video color using RCA cables directly from the 8mm Camcorder but better audio from the I-Link passthrough above.
Pogo
Posted on Aug 11, 2008
  • 102366 Answers
SOURCE: i need a manual /sony vrd-mc5
http://sony.storagesupport.com/product/137#documents
Posted on Feb 16, 2010
omoadeley
  • 84 Answers
SOURCE: I have a Sony vrd mc5 that has not been used much.
maybe the circuit is bad why not try to trace the wire to see where the fault is from but i think its the wire maybe its broken inside.
Posted on Jun 06, 2010
dvdcdlaser
  • 1285 Answers
SOURCE: Pal to NTSC
try NERO software...you will be able to go back and forth (pal or ntsc)...this might be a project / but you can also make into a very fun thing....(note also the DVD regions)
How do i hook it up to my tv
The simplest way is to connect the screw on connector marked Output on the back of the VCR to the screw on connector marked antenna or cable input on the back of the TV. There will be either a switch or menu item on the VCR where you chose to have it output on channel 3 or 4. Chose which you prefer and then tune the TV to that channel.
Sep 30, 2014 | Panasonic Pv-9400 Vhs Vcr Hi-fi Video...
JVC HR S8000U S-VHS VCR switch from stereo to mono during playing.
try to do a player head cleaning. just be careful doing this..
thanks
Aug 04, 2008 | Televison & Video
Having trouble hooking old VCR up to new LG TV and Integra Receiver. Feel like I'm missing a step...
Look at the back of the tv. What is it labeled at where you plugged the VCR into. Should probably say composite in. After that's verified, go into the tv menu and make sure you have selected composite input. Should be no need for any settings on VCR, it has to be settings on tv
Jan 11, 2013 | Panasonic Omnivision PV-7401 4 Head VHS...
Have an Aiptek HD 12 1080p with Azden wireless mic system. no sound with wireless mic, but sound works on camcorder without the wireless.
you need to use a mono-to-stereo cable, the azden is a mono output mic by the aiptek is a stereo input and you are shorting out the phantom power with a mono plug in a stereo jack.
- DL
Sep 06, 2011 | Aiptek Cameras
I HAVE A PANASONIC VCR PV-7401. THE BACK HAS ONLY A WHITE AND YELLOW RCA OUTPUT JACKS.I HAVE A RED, YELLOW AND WHITE SET OF RCA PLUGS. DO I NEED AN ADAPTER TO REDUCE RED AND WHITE STEREO PLUGS TO A SINGLE...
NO. Your VCR is not stereo capable (white and red), it is only MONO (white) so only connect the white RCA plug to the white jack. Leave the red cable unconnected.
Jan 14, 2011 | Panasonic PV-7401 VHS VCR
Tv only accepts signal from the single black cable cannot get the tv to recognize the 2 audio cables and one video cable.. how do i fix this?
Hello
Your Emerson TVs audio format is not stereo; it is mono. Therefore only one audio input will be active. There is a Note give on your TVs manual. I copies it here for your information.
1. VIDEO (IN) jack- Connect to the video
output jack of a video camera or VCR.
2. AUDIO (INPUT) L/R jacks- Connect to
the left/right channel audio output jacks of
Note: The AUDIO (INPUT)L jack is for
mono input. The sound is heard from both
speakers. Use this jack for monaural audio
equipment to be hooked up.
OK.
Dec 21, 2010 | Emerson EWF2004 20" TV
Trying to hook up a playstation one
Make sure you have the cables connected correctly from the playstation to the VCR.
Yellow colour is Video output from playsation to Video input on VCR.
To get the audio from the playstation to the VCR just match the colours of the RCA connections.
Do not forget to select video input on the VCR as well.
Good Luck.
Mar 02, 2008 | Panasonic PV-V4540 VHS VCR
Panasonic PV-810
just for recommendation, try out panasonic. panasonic has way lots of upgrades including repair service. they never run low on chips and stuff. quasar is ok too but never really heard about the tech support...
hope this helps.
Jan 29, 2008 | Panasonic PV-810 VHS Analog Camcorder
Panasonic VCR pv-7451: No sound in "normal" mode
Are these prerecorded tapes or ones that you recently recorded? Or are they all normal audio tapes?? Try a pre recored and turn off the HI fi audio and thats an easy thing to do as put it in normal and mono.. Get back to us so we can assit. Not enough info as could be 100 things.
Jun 28, 2006 | Panasonic PV-7451 VHS VCR
Open Questions:
See all Sony DVDirect VRD-MC3 DVD Recorder Questions
Sony DVDirect  VRD-MC3 DVD Recorder Logo
56 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
