Question about Audiovox P88 CD Player
CD PLAYER P88 RDS/A AUDIOVOX
CD PLAYER TURNS BUT NOT HEAR THE MUSIC (MODEL AUDIOVOX PRESTIGE P88 RDS/A)
3 Suggested Answers
SOURCE:
  • 55 Answers
SOURCE: my audiovox prestige alarm only does slient. How
Simple....
1st turn the ignition key on than off
2nd within 10 seconds press and release the valet button switch 3 times.
If you did it right you will hear 1 chirp to indicatate the chirps are back to irritate and ******** all your neighbors.. just kidding. good luck
Posted on Aug 09, 2009
  • 50 Answers
SOURCE: Would you recomend the Audiovox prestige APS901N
IF RANGE IS NOT IMPORTANT I SUGGEST A AUDIOVOX AS9076N . ITS AN ADD ON REMOTE START WHERE YOU WOULD PRESS
LOCK
THEN UNLOCK
THEN LOCK AGAIN ON YOUR FACTORY REMOTE AND THIS WOULD START THE CAR.
I BELIEVE THE IGNITION KEY HAS BUILT IN KEYLESS ENTRY BUTTON ON IT ALREADY. SO WHY CARRY ANOTHER REMOTE?
MOST OF AUDIOVOX MIDRANGE SYSTEMS HAVE THIS OPTION FOR ADD ON REMOTE START SYSTEMS WHERE YOU CAN USE THERE REMOTE OR TIE IT IN WITH YOUR EXSISTING REMOTE.
OTHER UNITS WILL HAVE DOUBLE LOCK OPTION TO START CAR. OR TRIPLE LOCK OPERATION.
Posted on Jan 22, 2010
Testimonial: "sounds like good info. Will the 9056n work the same way?"
Cd changer connections
Hi, On your Audiovox ACC56 10-Disc CD Changer with a Prestige P-165/P-185 FM Modulator, the wires: black - goes to the body (-) ground (as you correctly posted); Green/white - (with a small filter box) goes to the constant/always on 12V supply such as the + terminal of your battery Orange/White - should be connected to a switched power source such as the accessory terminal of your ignition switch or to the blue or yellow wire of your head unit or car stereo or whatever wire that will have 12V+ only when the head unit or car stereo is switched on. Hope this be of some help to you. Post back how things turned up or should you need further information. Good luck and kind regards.
Sep 21, 2007 | Audiovox ACC56 10-Disc CD Changer
Would you recomend the Audiovox Prestige APS901N for my '06 Chrysler T & C mini van?
LOCK
THEN UNLOCK
Dec 24, 2009 | Prestige Remote Start
I have a audiovox car alarm model as-9490-4p how can i hook it up?
GO TO:
TECHSERVICES.AUDIOVOX.COM
DO NOT PUT WWW IN FRONT.
REGISTER
THEN CHOOSE TECH DOCUMENTS FOR YOUR MODEL.
Nov 28, 2009 | Car APS25CH Prestige 2 Button Remote...
My audiovox prestige alarm only does slient. How do I get it back to chirping ? model # aps02bt2
Simple....
Jul 31, 2009 | Car APS02BT2 Transmitter for...
I need the diagram of alarm Prestige model: APS95BT3
go to google and write this> audiovoxtechservices press enter,and in that website request a password to get the instalation manual
May 11, 2009 | Car APS95BT3 Transmitter with 3 Button...
I don't know how to use my keyless remote start
DO YOU THE MODEL OF THE ALARM,PROBABLY NOT,EMAIL ME I THINK I CAN HELP YOU,I NEED TO KNOW HOW THE REMOTE TRANSMITER LOOKS LIKE.HERES MY EMAIL: [email protected]
Mar 14, 2009 | Prestige Remote Start
Prestige platinum by audiovox need to replace the remote for it
if you need a remote you can buy one from audiovox.com and also you can download the installation manual and user manual in which that will tell you how to program the new remote for the remote start.
Feb 15, 2009 | Prestige 2 Button Remote Security System...
Power connected right, pops fuses in player
HI Paul,
No one evidently wants to tell you that your Radio is shot. The circuits in the head units is not worth repairing. It is too minute and hard to do to the point it isnt worthy of attempt. I do not mean to be the harbinger of doom here. Just get a new head unit and this time dont get an Audiovox.
Aug 23, 2007 | Audiovox P88 CD Player
Power to unit but not working
First of all, if you connect iginition and constant to the same wire, it sometimes will not work, make sure they are hooked up to dedicated wires in the car. Also once they are connected and the car is on, press the source (src) button or am/fm button. Check the fuse on the back of the stereo by the wire harness too. Also make sure yellow is on constant and red is on ignition.
Aug 20, 2007 | Audiovox P88 CD Player
Audiovox P88 CD Player Logo
55 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Marvin
Marvin
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
