Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Will not spin
5 year old bosch WFMC6400UC washer will not spin. The word error comes on the screen.
  • jnbrow Dec 31, 2008
    I have the same problem, but the washer states E04 on the screen.
I have an older model that would not spin. We did not have a digital display, so can't help there, but it turned out the bushes on the motor were worn out and needed replacing. Hope this helps.
Posted on Feb 13, 2009
How to check error codes on Bosch Nexxt 6400
Hi there:
You directed this question at me, but unfortunately this isn't my expertise and I am unable to provide you with a real solution at this time.
Hopefully one of other experts will be able to provide you with a real solution.
Thank you for using FixYa.
Jan 29, 2012 | Bosch Nexxt Premium WFMC6400UC Front Load...
I have Bosch Nexxt Premium WFMC6400UC Front Load Washer. It noted a suds or pump blocked error. I was able to access the pump cleanout at the bottom of the washer and remove a small wire that was lodged....
Hello and welcome to fixya.
I`d suggest removing the back panel and inspecting if the belt has perhaps come off.
**Unplug the unit from the wall first**
If so, put the belt around the motor pulley and start it around the drum/drive pulley. As you hold it in place spin the large pulley and it should go back on, careful not to pinch your fingers...ouch :(
Let me know what you find out or if you require further assistance.
If this indeed solves the problem please take a second to rate my solution accordingly.
Thank you for choosing`"fixya" and good luck.
macmarkus :)
Jun 18, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washer will not open, drain or spin.
if the error code is SE it needs 2 be manually drained
Apr 16, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Nexxt Premium WFMC6400UC washer will not wash or spin!
Hi there, In reading your post I'm not sure I know how to approach giving a solution. Would it be possible for you to expand your post and perhaps provide more details ? Does the unit have 120vac going to it ? ( is there any lights in the display ) Does it fill with water ? ( with either hot or cold ) Do you hear the door lock ? ( you should hear a "click" when the lock engages ) Has there been any error code displayed at anytime recently ? As you can see just by saying the "washer will not wash or spin" leaves more questions rather than possible starting places to help move you toward a solution. I will watch for you to reply. Thank you for coming to fixya, I hope we/I can assist you further. Macmarkus :)
Mar 29, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
Clothes come out wet
HI, this is a common issue that is easily fixed by, replacing the control unit. this control manages the motor functions during operations. if this unit is not spinning correctly, replace the Control unit. aka(motor control unit). In you washer, they call the motor control board a (Control Unit). replace this asap if possible. this will fix your washer. ADDITIONAL CHECKS--(Make sure that this unit is also draining water properly as well. this will cuase wet spin outs as well).
Jun 10, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washer will not spin
Carbon brushes in motor have worn down clean armture and replace brushes.
Nov 26, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch nexxt front koader
If you have had the washer for awhile you should clean the sediment filters, where the hose goes into the back of the machine and where the fascet and hose connect. The cold water side usually collect more sediment. The filter screens are delicate so be careful pulling them out.
Apr 01, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
265 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
