Question about Fuji FinePix S5000 Digital Camera
Where is the compartment for the 5v=4w in my fujipix s5000?
  • toc525 Nov 27, 2008
    no i meant how do you change the internal battery because every time i take out the aa's i need to adjust the date/time again. thanks!
  • melwell294 Feb 04, 2009
    I contacted Fuji They Want £80 to replace as part of service. it cant be that hard to replase an internal battery. Can anyone Help ?
Hi.there are two cicuit boards in the camera,one has the battery on it,it is a special battery with two fixing brackets and is soldered to the board.After searching the net for a couple of nights I have located some batteries,I have an old 5000 that I will attempt to change the offending item on.I have a repair manual and the tools so will let you know how I get on,not a job to try without proper gear.This repair is not in the manual.Hope this helps.
Posted on Feb 16, 2009
  • 39 Answers
Do you mean where to plug in the optional 5V DC power adapter?  Its under the rubber flap on the left side of the camera.
Posted on Nov 26, 2008
MY finepix s5000 fujifilm camera has a white screen displaying when i turn it on, is there anyways i can fix that problem with out haveing to take it in.
Had the same problem with my s5700, white screen, took it apart. two screws on the left (facing the screen) under the strap, two in the usb compartment, two (screen side) screws on the bottom, three screw in the battery compartment, and the final just below the right side strap. Carefully pull the back off and check the ribbon connection from the lcd to the board. push it in made sure its seated. Reasemble being careful not to bend the ribbon connectors. Worked for me.
Aug 05, 2010 | Fuji FinePix S5000 Digital Camera
Fujipix S5000 screen is all white
I just started having the same problem with my S5000, also.
Jul 11, 2009 | Fuji FinePix S5700 Digital Camera
FujiPix A345 it shuts off when I try to take a picture.
The most common causes of this are
1) Batteries at end of their charge - renew charge or replace batteries.
2) Poor battery contacts - remove batteries and clean contact terminals.
3) The rechargeable batteries (if used) have become deactivated, or the battery
capacity has diminished due to the memory effect.
4) The Auto power off function has turned the camera off.
Often a problem like this can be corrected by removing the batteries altogether cleaning the terminals and then reloading them. Also claen the terminals in the battery compartment itself.
Jul 04, 2009 | Fuji FinePix A700 Digital Camera
Shifting into 4 wheel drive
For 4W Hi either be stopped or moving at a slow rate of speed (<20 MPH) and move your 4WD selector to the 4 Wheel Hi position.
For 4W Lo stop and move the selector from 2W Hi to 4W Hi then push down on the selector and move through N into 4W Lo.
Feb 02, 2009 | 1993 Nissan Pathfinder
How do I use the 4WD on a 1993 Nissan Pathfinder?
Dec 20, 2008 | 1993 Nissan Pathfinder
Need to download FujiPix S5000 into my computer..
Need to download installation for my camera into PC?
Jul 13, 2008 | Fuji FinePix S5000 Digital Camera
Battery compartment door is ok but the teeth on the camera are broken. is this repairable?
You would have to replace the inner housing to replace the latches.
Fuji USA might have a fixed rate for this, here is the link to the support page for the S5000: FujiFilm
Mar 24, 2008 | Fuji FinePix S5000 Digital Camera
Fuji FinePix S5000 Digital Camera Logo
54 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
