Question about Intel Motherboard
Problem getting hard drives to run
I have a msi 865pe neo2-v mother board (used ebay) pluged everthing in.fan turns on chip and power supply, light comes on on the case but no power to cd or hard drives, however when i unplug them from the mother board (ide slots)power is there.any help would be great.thank .you
  • threshmachol Nov 26, 2008
    voltage is ok. thanks anyway
  • 849 Answers
Check the power supply. some time power supply not suppling the proper voltage to the accessories.
Posted on Nov 26, 2008
How to instal the vga for prescott s33 mother board
Hi, here is the download site for your mainboard:
http://www.msi.com/product/mb/865PE-Neo2-PLS--PFS--PFISR.html#/?div=Driver&os=XP%2032
Try also windows update.
And try to look for the screencard driver elsewhere.
http://support.amd.com/us/gpudownload/Pages/index.aspx
http://www.nvidia.com/Download/index.aspx?lang=en-us
You can find the screencards name in the device settings.
Hope this will help you.
Aug 15, 2011 | MSI : 865PE Neo2-PLS P4 Prescott FSB800...
MSI 865PE Neo2-V Motherboard does not boot to BIOS. It just powers up and the drive lights are on continuously. Is there a replacement MB that uses essentially the same BIOS and won't require re-formating...
This one is pretty much identical
http://cgi.ebay.com/MSI-865PE-Neo2-P-Motherboard-P4-socket-478-EMS-/180572214688?pt=Motherboards&hash=item2a0af155a0
This one is similar but you will need to reinstall a new audio driver
http://cgi.ebay.com/MSI-865PE-NEO-2-Motherboard-Processor-/200552149636?pt=Motherboards&hash=item2eb1d6f284
Dec 09, 2010 | MSI 865PE Neo2-V Motherboard
What is the max ram that I can install in the 865pe neo2-p board
The MSI 865pe motherboard can use up to a maximum of 4GB of PC1600/2100/2700/3200 non-ECC DDR RAM
Apr 04, 2010 | MSI 865PE Neo2-V Motherboard
Can prescott 800 mother support p4 2.4ghz/1m/533 processor
The MSI 865PE Neo2-PLS
Supports Intel® P4 Northwood/Prescott (Socket 478) processors.
FSB 400 (for Northwood only), 533, 800MHz.
Supports up to 3.2GHz or higher speed.
See page 1-2 in your manual. Also see page 2-3.
MSI supported CPU list; http://www.msi.com/index.php?func=prodcpusupport&maincat_no=1&prod_no=569#menu
Main link for 865PE Neo2 platform; http://www.msi.com/index.php?func=searchresult&keywords=865PE+Neo2
Cheers'
Mike
Jan 20, 2010 | MSI : 865PE Neo2-PLS P4 Prescott FSB800...
Starting PC: No Beep, No LED on motherboard, all fans seem to have power. No videosignal at all. Videocard and cable OK.
This MAY be the power supply. Fans often run from different voltage than most of the processor.
The power on reset may not be releasing as one of MANY possible problems. Power supplies are less expensive to try tahn motherboards.
Jan 04, 2010 | MSI 865PE Neo2-V Motherboard
When I attempt to turn on my computer after playing with the switch front and back it will start sometimes and run for a few minutes and then shut down. When I remove the four pin connector to the mother...
I've seen this before but the 4 pin connector was burnt pretty bad and not making a good connection. I'd see if you could gently scrape the pins a little bit with a small knife(motherboard) See if the connector from the power supply looks ok and doesn't look like it's gotten hot. The holes in the center of the 4 wire connector can be a little bit larger than the pins themselves also. You might try plugging in the connector and then holding some side pressure on the connector while you try to start the computer. Also unplug the hard drive and cdrom while you try booting. The power supply may not be putting out enough amperage and unplugging drives may give it a little more power. That would mean you might need another power supply if it works.
Nov 29, 2009 | MSI 865PE Neo2-V Motherboard
Fan running blank screen cant get into bios.was ok now this
Can you feel the hdd vibrating when you power up or not
Jan 18, 2009 | MSI 865PE Neo2-V Motherboard
Mother board cd
Hi quadir, you will not find a CD for your MSI 865PE Neo2-PLS board. You can order it from MSI or you can download the driver software by clicking on this link. http://global.msi.com.tw/index.php?func=searchresult&keywords=865PE+Neo2-PLS&table=download
This next site will open MSI to you're board. Suggest you add this to you're favorites.
http://www.msicomputer.com/product/p_spec.asp?model=865PE_Neo2-PLS&class=mb
To call MSI & order a CD click on this link.
http://www.msicomputer.com/company/contactUs.asp
Good Luck!
Have more questions, feel free to ask.
Mike
Apr 26, 2008 | MSI : 865PE Neo2-PLS P4 Prescott FSB800...
Intel Motherboard Logo
47 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
