Question about Technics SCEH790 CD Shelf System
No sound i have the technics SC-DV290 stereo but cannot get sound, it plays for about 20 seconds then cuts off, i have tried playin tapes also still with no sound. I have read some of the problems other ppl have had so it may be the same problem, how much do you think it would cost to have this fixed?
  • lindylou1975 Mar 22, 2008
    I have my stereo wired up to my TV to give it a better sound. For some reason the sound is now crackling. I have checked all the speaker connections and they seem fine. Dont know whats up??
The problem seems to have sorted itself out. I was about to throw it on a skip but i gave it 1 more try and it worked. I have no idea why it didnt have any sound before, the wires were all in the correct places. The stereo was still in the same place i had put it when i first bought it so nothing had been moved or replaced. It now works perfect like it did before. My guess is that it got damp and had to dry out.
Posted on Aug 15, 2007
To my knowledge this system is Bi-Wired, meaning 2 different terminals for low frequency and midrange/high frequency, you must make sure that you have these properly wired up, i believe there is a red and a black and a grey (or blue) and a black, same on the amp, check to make 100% sure that it is correctly wired in this way, also, make sure you have the system stacked correctly, for example: spectrum analyzer, then amplifier, then dvd player, then tape deck... this ensures that you have adequate ventelation for the system... hope this helps!
I have got the same sterio with the same problem, technics are usualy the best around but this sterio is an absolute waste of £500 my solution is to just wire a different amp up to the old one
Posted on Aug 05, 2007
How to connect a mp3 to a Technics SC-DV290 5 Disc DVD/CD Home Hi-Fi
get audio lead to fit mp3 and connect to back of the stereo and set to aux
Jun 26, 2014 | Technics SC-DV290 System
How do i connect technics turntable model SL-QD33 to technics stereo model SC-DV290 and what do i need to switch to on stereo to play records.
Have a look on the back input panel of the sc-dv290. Check for a "PHONO" input. If there is no phono input it will not play turntable. If there is: then plug it the turntable in and switch the SC-DV290 to PHONO mode.
Another way would be to purchase a "phono preamplifier" from ebay: Hook the turntable into the phono preamplifier, and the preamplifer into the SC-DV290 AUX input.
Feb 26, 2011 | Technics SC-DV290 System
Hello there, I have a problem with my Technics SC-DV290 System. The problem i have is that when i go to turn it on it buzzes and it cuts out after a second or two and there is no display on the stereo...
ok. there is a MAJOR problem with the power wiring. i suggest not turning it on again until either you have fixed it or a trained professional has.
Jan 24, 2011 | Technics SC-DV290 System
Technics SA-DV290 Amp. Sound cuts out as volume is increased
hello it sound like the output ic may be in trouble you may have just dry joint on the ic which just resolder it . or there could be a capacitor leaking or they may have swelled up in which you will have to replace. it's best to do some visual checks first i'e look for any burnt parts any capacitor with bulging tops
regards
shaun
Apr 04, 2010 | Technics SC-DV290 System
Technics DVD Stereo SC-DV290
never done this myself, but I would guess you take phono jacks from your TV (L & R out) and plug them into the back of the sound processor, iether VDP(AUX) or VCR(EXT) IN
then go to your remote and press (vcr(ext)/vdp(aux) repeat pressing until you hear you tv
each time you press button it should go through a selector menu
TUNER->DVD->TAPE>VCR(EXT)->VDP(AUX)
hope this helps
Feb 02, 2009 | Technics SC-DV290 System
Can i install a turntable to my technics sc-dv290
ION has just released a turntable that connect via USB! You can now play your lp's on anything that accepts usb cables. It is available at Bed, Bath, and Beyond. Also, there are many various turntables available that connect via RCA cable. Bet Buy and Circuit City both carry mdels that will hook to your unit via RCA cable. They have some models on sale at times for under $90 bucks! Thanks for using FixYa! And don't forget to rate my solutuion! Good luck, and Happy listenng!
Jan 13, 2009 | Technics SC-DV290 System
No sound
hi let me tell you that you technics if it plays for period of time then blocks usually this problem lead with auto protection before you really burn it.......firs check all the wires well connected to speakers,check each speaker with a baterry it will pop up...if you do all above i wish you luck... if the problem is most serius needs a resoldering action or even change something overheated components. take it for qualified professional and the cost may vary where you live....... saludos
Oct 15, 2008 | Technics SC-DV290 System
hold the demo button in for a few seconds
May 06, 2008 | Technics SC-DV290 System
System stops playing
Hi Big Belchie
Sounds a bit like it is overheating. It is in a cabinet? Check that cooling vents on top and sides of the unit are not getting obstructed. hehehe sometimes parties are responsible for those piles of cd covers that block off the vents. How hot does it feel when it stops working?
regards
Graeme
Apr 12, 2008 | Technics SC-DV290 System
Technics ho2 no play error
u need a new motor in yr dvd player i had same problem so had new motor fitted cost 50 pound works now
Sep 20, 2007 | Technics SC-DV290 System
Technics SCEH790 CD Shelf System Logo
141 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Morne Olivier
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
