What is the maximum amount of RAM I can add to my computer
Take the guesswork out if you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system hope it helps
SOURCE: Suitable psu for packard bell istart 1359
Dera Telxon,
The PSU you have linked is FSP250-50LPU - which is not the one in question.
Thanks and regards,
Bandi
SOURCE: Specifications for Fujitsu Semiens Scaleo 600 desktop PC.
Visit http://support.ts.fujitsu.com/com/support/manuals.html
Make sure you have your serial number ready to view the manual. Hope this helps
www.mcmsacto.com
SOURCE: what internal hard drive can i put in a packard
This computer is capable of utilizing any 3.5" internal hard drive with a SATA interface. Just make sure you use the included software to install and initialize the new hard drive.
SOURCE: how to add another hard drive to my pc desktop
if you have a 3 plug ribbon, plug it into the new hard drive and plug in a power supply plug
SOURCE: what type of hardrive do i need for my packard bell istart 2369 desktop computer?
For one, I abhor Packard Bell, and the lack of support for it's users, of older computers.
If you don't support your computers, I say do not buy one from them.
(Oh, excuse me. For $$$$$$ they will)
Can't even find the specifications on the internet, (I do not own one), and Peckard Bell Support is of no help.
So let's do it another way.
What kind of cables connect to the Harddrive?
This will tell us if it is an IDE unit, or a SATA unit.
An IDE, (Also known as PATA), harddrive uses a flat ribbon cable, for it's data cable,
http://en.wikipedia.org/wiki/Parallel_ATA
Click on the photo all the way to the upper right. Shows a blue connector on a grayish flat cable.
The power cable for an IDE (PATA) harddrive, is a 4-pin standard Peripheral power cable. Shown here,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Note the harddrive shown in the photos, is an IDE harddrive.
If it is a SATA unit, it will use a SATA power cable.
Has 15 contact pins in the connector.
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
The SATA power cable has an L connection on the inside, to match the L connection on the back of the harddrive.
Same with a SATA data cable, only it is shorter in width, and has 7 contact pins,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
Also look at the label of the harddrive, and state what you see.
Is it a Seagate harddrive? What is the size? 250GB?
Smaller? Larger?
Once we find this info out, I can recommend harddrives.
Be aware that the Windows operating system was on that harddrive.
If you install a new harddrive, it won't have Windows on it.
You will need to obtain a genuine copy of Windows, and install it.
Post back in a Comment.
Regards,
joecoolvette
It depends on the OS. What OS do you have? (For example, Windows XP, Vista, 7, Linux Ubuntu, ect.) What version of the OS do you have? 32- or 64-bit?
I have Vista as my OS
