I got prematurely disconnected yesterday. Before getting disconnected yesterday, I was thinking that the Sony HDTV may have a bad blue CRT since when I took off the front cover, it looks the far right gun does not light. Going from left to right, the gun colors appear to be red, green, and blue. The far right light gun looking at the TV CRTs from the front appears to be out. I tired adjusting the blue pot but it does not show any blue color at all. This seems to be consistent with my impression that the blue CRT is not working. This is recent and is a follow up to the blue light surge on turn on and then shut down. After repeatedly turning the set on, it would stay on and operate with all three colors. Now, it seems to only have green and red.
5 Suggested Answers
  • 5 Answers
SOURCE: Red & green lamps shutting off leaving a blue screen
Could you show a picture of the distended cover you mentioned?
Were the light blue lines you were referring to, diagonal, or truly horizontal?
Posted on Oct 16, 2007
  • 8617 Answers
SOURCE: Lines horizonal - seems to be caused by voltage to green CRT
Your green CRT is shorted. To test put your red crt socket on the green and your red on the green. then try turning up red control if the green now works its not your tube. If the same thing happens with the red socket on the green you can be sure its the green CRT if the green works properly with the red socket, then you have a problem in the green drive circuit and not the CRT. hope this helps.
Posted on Jan 20, 2008
  • 8617 Answers
SOURCE: Philips 55PW9363 looks 3d
You need to replace both convergence ICs they are STK392-120 this is an easy repair that you can do yourself and save yourself around 400.00 for about 45 minutes work. You can order the new ICs at the following link and they provide free installation instructions with pictures and also free online support with a support tech while you do the repair. I am one of their support techs. You would also want to order at least 4 convergence resistors and they send the proper ones for your model as often a couple resistors go. Your model uses 6.8ohm 2watt 5% metal film resistors. So to recap you will need (2) STK392-120 Convergence ICs and (4) Convergence ICs . very inexspensive repair if you do it yourself. here is the link.
Posted on Apr 12, 2008
  • 5 Answers
SOURCE: Sony KP-51WS510, standby led blinks 5 times
It sound like you have a bad picture tube...check your 1k circuit for correct voltage and wave form.
Posted on Oct 13, 2008
Goes to blue screen then shuts off
Thats almost always caused by the Blue CRT needing replacement. You can get the replacement Blue CRT from listed under the Projection CRT category
Dec 03, 2011 | Sony KP-51WS520 51" Rear Projection...
Blue missing from picture and low brightness; whites not white shades of yellow and pink; blues are green
its most likely the Blue CRT drive board which is causing the issue since the set would not power up if the Blue CRT itself were bad, so the drive board is the most likliest. You can get the blue CRT drive board from
Oct 22, 2011 | Sony KP-46WT520 46" Rear Projection...
Turn on the big screen sony tv, but fades to blue
You probably have a bad BLUE CRT. Due to the cost and the length of time it would take to repair, I would not invest the money into it. It would require a Qualified Service Person to come to your home and remove the BLUE CRT assembly and send it back to SONY to be rebuilt. Estimated cost would be around 800.00. I would check prices of a replacement set.
I hope this helps,
Oct 27, 2009 | Sony KP-46WT500 46" Rear Projection...
5 flashing light code
Disconnect RED Tube CRT board if set plays without shuting off RED tube is bad or video IC on CRT is bad.
Feb 12, 2009 | Sony KP-51HW40 51" Rear Projection...
Sony kp-57wv600 tv turns on shows picture then blinks blue a few times and then shuts off....stnadby light blinks 7 times...whats the problem
Its either blue tube or bad componet on blue CRT board hertes how to know disconnect Blue CRT board connect to neck of blue tube turn set on see what happens if set come on and plays then this lets you know if it is a problem with tube/video ic on crt board. If set shuts back off different problem.
Dec 25, 2008 | Sony KP-57WV600 57" Rear Projection...
Blue screen sony
blue crt shorting use crt restorer to lift short or replace picture tube /crt
Aug 19, 2008 | Sony KP-46WT500 46" Rear Projection...
Sony KDF60wf Projection TV
You either have a bad Blue CRT or a blue drive transistor
Mar 10, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony kp-57ws500
Probable bad blue CRT and if blue goes bad guess what might
happen to the red and green.........T.
Nov 07, 2007 | Sony KP-46WT500 46" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
