Question about Bosch Axxis WTA 3510 Electric Dryer
Indesit IC70C Condensor dryer
Our IC70C is stopping after running for a few seconds. I have replaced the door catch without improving the problem. The rod in the door which appears to allow the dryer to detect the door being closed has a bend end. The dryer stops when the vibration opens the door fractionally. I suspect the door-closed detection mechanism is at fault, but dont know the part numbers. If I start it and tape the door closed, the dryer operates perfectly. Can anyone help me with the part number, or suggest where the real problem may lie?
  • rumex Feb 26, 2009
    I fixed the problem: The pin that enables the dryer to detect the door woas closed had bent at the end. By putting a washer around the base, it made a better contact. Thanks anyway.
  • Anonymous Apr 02, 2009
    keep on shuting off after i turn it on
    Problem Solver:
  • 7 Answers
We experienced a similar problem and corrected it by closing the drying door and then hitting "OPEN" followed by closing. Sometimes we use a tool to release the catch and then close the door. We have not seen this problem return.
Posted on Feb 25, 2009
Dryer not working indesit
Hi.
Is it a condensor or vented dryer.
Jan 04, 2014 | Washing Machines
IT IS NOT INDESIT 123. IT IS INDESIT 133
its prob your inner door catch or door striking plate the inner door catch has a bymetal strip inside that looks the door they wear out but if the striking plate is worn on the door it will also stop the inner catch to lock it is better to replaice both at the same time they are not to expensive to buy and easy to fit just turn off the power to machine unplug take the top off and you can get your hand dowm the front where the inner lock is undue the two screws which holds the inner door catch lift out and unplug the lock plug in new one and put back you will see how to replaice the outer door catch best to take the door off and lay flat
Nov 06, 2011 | Indesit W 123 Front Load Washer
Kitchenaid dryer keye660wwhi stopped working 30 seconds after turning on. i opened the door and closed it and it turned on again only for it to shut off again in ten seconds.Now it won't even turn on at...
your door latch is getting loose and ont holding the door switch in far enough to make contact,open the door,keep your hands out of the drum and push in or on the switch and see if this fixes the problem and the dryer runs,then just replace door catch hardware
Jan 31, 2010 | Dryers
Indesit washer wont run
the door lock light flashing indicates that the door has not locked or not shut correctly,is the appliance is under 5 yrs old open the door and check the door catch,there are two gaps either side of the catch,if you look into the gaps you should see a metal pin,if the one at the bottom is not there then thats why the door wont catch,there are some screws around the door frame if you take them out and just pry apart the door frame by the catch you will see the pin at the top,push it down till you see it at the bottom gap,refit and test.
Jan 24, 2009 | Indesit W 123 Front Load Washer
Snapped door lock on hotpoint washer/dryer
this happens when unit goes off balance and tub bangs door..open door.. you will see to screws holding the door locking device remove,,now take a screw driver and remove the front wire spring clip..replace latch and door probe,,reverse to put back together
Dec 23, 2008 | Indesit W 123 Front Load Washer
Indesit WIA 121 washing machine, front loader. The door lock led is continuessly flashing red even when the programme has stopped and the door is opened. I have to switch off at the main plug. Machine is...
One of the main problems with Indesit front loaders ( apart from replacing the door interlock switch) is
If the door will not close and click in the lock, then take the door off with a tork screwdriver and take the screws of the inner plastic off the door (make sure you do this on a flat surface) and gently prize off the inner plasic by running round a flat head screwdriver..
Once you have taken off the door and glass bowel - check out the door catch to see if a metal rod has come out of its housing holding the catch and spring in place and refit or replace.
I have come across many door catches like this.
Apr 21, 2008 | Washing Machines
How to reassemble door catch of indesit tumble drier
Very difficult to explain with out pictures, the pin should go through the spring it really is a matter of fiddling until you get it right or go back to where you bought it from and ask them how it goes.
Nov 30, 2007 | Dryers
Bosch Axxis WTA 3510 Electric Dryer Logo
226 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
