Question about Zanussi WJS1397W Front Load Washer / Dryer
Indesit WI101 tripping Electric RCD
I can plug it in and the power light will stay on, but as soon as I close the door and it tries to start a program, it trips the RCD. It is only just over 2 years old and gets light use, brushes in the motor are fine, I have checked for any obvious wiring fauls or wear, element is also fine, can anyone help??
  • dark_angels Nov 26, 2008
    unplugged the motor and that seems to have stopped the washer tripping the RCD, thanks tresilla, I have taken off the motor and given it the once over, checked all connectors for corrosion dampness, damaged wires etc, all looks good inc the bushes, so I suppose this means I need a new motor?
I stripped the motor down, gave it a good clean checked all the wiring for damage/wear, all was good, put it back on the washer and it's working just fine now
Posted on Nov 28, 2008
  • 1,462 Answers
Try running with the element disconnected and the wires taped up. usual cause is the element down to earth.
try same procedure with the motor disconnected
Posted on Nov 26, 2008
I have a Maytag GC2227 and it is tripping an RCD. If the fridge temperature setting is switched to off the RCD does not trip but as soon as the temperature setting is adjusted the RCD??
Refrigerators are never supposed to be on GFCI devices, they will tend to "leak" a bit of current to ground during defrost and "trip" when there is no real problem... You can test this theory by plugging the machine into a two-prong adapter to see if it still exhibits the same symptom, the only problem I have seen in home refrigerators that can trip a 20 amp circuit break is a seized compressor that is drawing "locked rotor amperage." By design, the start relay/overload should interrupt power before this happens... Hard Start Kit RCO410
Jul 04, 2016 | Maytag Refrigerators
Rcd tripping
Either the start relay in the compressor is grounding electrically or the defrost heater is (most likely start relay). To replace this yourself is difficult as it requires technical knowledge. If you are located in California, bay area I could help you personally
Apr 21, 2014 | GE Profile PSW26P Stainless Steel Side by...
Hotpoint wmf740 washing machine tripping RCD
try this open the door and then plug it back in when the door is closed its got power so when open the power is really low if it trip after that it will be you main Bord and poss door switch but i will tell you its going to cost cheaper to buy a second hand machine if you have done what i have told you then get a call out but make sure the call out is cheap ok it could be a waste of time ok
Oct 22, 2012 | Hotpoint Washing Machines
Ariston a1600wd wont turn on
Before you change fuses, do you have an internal fuse board or RCD system in your home? Sometimes, an individual RCD can trip out, locking off sockets. Some sockets are individually set up for up and downstairs in a house, or different rooms. If you have a board or RCDs, check them out :)
Nov 18, 2017 | Ariston Technologies Washing Machines
Machine partially fills and then stops working.
THE RCD SWITCH is concealed on the inner side of the hindges of the door or on the top innerside of the door. it is a simple push switch which has a mechanism of push to on/off
this switch has got stuck in off position.
change this switch or spray a drop of rust removal oil. it will start functioning
Aug 27, 2009 | Whirlpool AWM8123 Front Load Washer
Panasonic microwave, when unit is plugged in, unit is ok, when opening the door the RCD in the consumer box trips, close the door and reset the RCD power stays on try to run the microwave, and the RCD...
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 10, 2008 | Panasonic Microwave Ovens
Rcd tripping
Well done ! Thanks for the information.
Jun 07, 2007 | Baumatic 23 in. BDW5 Built-in Dishwasher
Indesit D61D tripping RCD
the heater is faulty(shorted) and check that the hot water is getting to the appliance as the buzzing is the soliniod being powered but the water is not passing through
Aug 15, 2006 | Maytag 24 in. MDB8600AW Jetclean II...
Zanussi WJS1397W Front Load Washer / Dryer Logo
414 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
