Question about HP PSC 1510 All-In-One InkJet Printer
Printer prints test page each time printer is turned on
So far the only problem I have is the printer prints a test page each and every time I turn it on. The printer was working fine and then just started doing this. Am not sure why or what made it start doing this. Is there a fix or do I have to reinstall all software? thanks for your help Danny
I had this exact same problem, except my printer is a HP PSC 1315v. I did as was suggested (also just like it says on the printed test page), scanned the test page and it SOLVED my problem. THANKS!!
Posted on Jul 23, 2007
    President:
  • 2,961 Answers
There may be something initialised to print a test page everytime it starts, just remove printer, uninstall driver and re start. Re install drivers and connect printer when prompted or when installation has finished. This should revert to default settings.
Posted on Jan 08, 2007
Dmcpherson2's suggestion is correct. This drove me absolutely crazy - I must have printed hundreds of test pages before I actually READ the test page directions, which illustrated to scan the test page once. Problem solved, except it still prints a test page every time a cartridge is replaced (which is often). I believe HP simply wants consumers to waste more ink for quicker 'turn'.
Posted on May 11, 2007
I had this same problem. I think sandrew's solution is nonsense. tomj23 suggested something which worked: If you look at the printed test page, it actually has instructions for what to do. Align it on the right side of the scanner window, and hit the Scan button. (I actually had to turn off my printer, turn it on again which printed another sheet, and then do this. I don't know why.) You won't have to do this every time you turn on printer, but I think you will have to do this every time you install new print cartridges.
Posted on Mar 25, 2007
Prints test copy every time I switch it on.
All right so you are getting print test copy every time you turn on or switch on your printer. You can follow the following steps to fix this issue:-
1.. Turn off the printer and wait 10 seconds. Turn it on again
2. Let the printer print the test page.
3. After the test page is printed, disconnect the USB cable connecting the printer to your computer. DO NOT turn off the printer while disconnecting the USB cable.
4. Place the test page on the scanner glass and press the SCAN button on the printer. The ON light will flash as the page is being scanned.
5. Remove the test page when the ON light is steady.
6. Finally, turn off the printer and wait another 10 seconds. Then turn it on again. No more printing test pages! Yay!
(You may now reconnect the printer to your computer via the USB cable.)
let me know if it fix this issue and helpful to you.
Mar 03, 2011 | HP PSC 1510 All-In-One InkJet Printer
Hi, Wonder can you help my printer keeps printing off test page everytime it is turned on. this is only happening since i changed the cartridge, never did this before. thanks
Your printer is printing alignment pages, because the cartridge alignment was not completed since you replaced them. Follow the below steps to complete alignment.
  1. Turn the printer OFF and then turn back ON.
  2. Wait until the alignment sheet prints out fully.
  3. Place the alignment test page over the scanner glass.
  4. Press start color scan button.
  5. The printer "power" light will start flashing, indication the alignment process.
  6. After the printer stops flashing, turn off and then ON the printer.It will not print any test pages further.
We need to run alignment test every-time while we replace ink cartridges.
Regards
Riztech
Nov 27, 2010 | HP Photosmart Premium C309A All-In-One...
Each time the printer is turned on, it prints the test page
You need to scan the test page in order for the printer to stop printing a test page every time you turn it on.
Sep 24, 2010 | HP PSC 1350v All-In-One InkJet Printer
Test page prints each time it's turned on
Test pages are often printed by holding down one of the buttons on the printer. Make sure that none of the buttons are stuck. Look up in your printer manual which button is for test print and make sure it isn't stuck.
Aug 15, 2009 | HP PSC 1410 All-In-One InkJet Printer
Every time I turn on my printer, a Dell 948, it prints a page
Hi
We have 30+ printers... which we use for testing empty inkjet cartridges prior to refilling with ink. Basically we inject a little Magic Inkjet Flush directly into the dried print head which allows us to unclog them. Then we soak them overnight on Magic Pillows which gives just enough to do a PRINT TEST next day.
As some of our printers always try the alignment test here´s what we do...
1. Pull paper stack slightly away from printer, when it tries to print it thinks it is out of paper and should offer a cancel print option.
2. Alternatively if you print daily? Try leaving your printer power on... Some do alignments every time you power up... so dont switch off (they use very little power in standby.)
3. When exchanging inks like HP immediately switch off printer which cancels the print test. Then just switch on again.
4. Reinserting your printed sheets each time will save paper if not ink.
Good Luck!
Tinteiros (Ebay)
Mar 22, 2009 | Dell 948 All-In-One InkJet Printer
Printer printed test page but won't stop printing
Please follow exactly and IN ORDER.
1. Turn off the printer and wait 10 seconds. Turn it on again
Aug 27, 2008 | HP LaserJet 1320 Printer
Keep printing test sheets
A lot of HP printers print a page to enable the print head alignment and calabration. This normally orcurs when a cartridge has been changed. If the alignment page fails then it will reprint alignment page until it can align.
So, you need to get that page it prints and place it on the glass and press scan, then it will complete alignment and be ready to rock.
See Here
Cheers
Jan 19, 2008 | HP PSC 1510 All-In-One InkJet Printer
HP Photosmart C3100 series
I just got off the HP help line.  After changing my black ink cartridge a test page was printing each time I turned the machine on.  This is very costly, in both time and ink as the cartridges themselves for this machine hold very little ink.  I tried to learn from HP tech how to turn off the test-print while keeping my color cartridge empty.  It turns out that you cant do it.  HP requires you to keep buying and using cartridges whether you need them or not.If you buy the color ink it will use it up in its testings.  And if you dont buy the color cartridge it will use up your black ink by printing the test each time you turn on the printer.  The printer was inexpensive sure, but I'm paying for it in wasted ink.
Dec 26, 2007 | HP Photosmart C3180 All-In-One InkJet...
HP PSC 1410 will not print, printer icon is no longer on the bottom right hand corner of screen either. When i turn off the printer and turn it back on it prints the test page only.
Dear kappa, It is the problem related "Alignment of cartridge" your printer is working properly, I am suggesting a method, with the help of this method you will never get test page until you lift out your cartridge from your printer. When next time printer print a test page, take it and put it into the scanner, remember the printing area should be the side of mirror and the printer prints on the above side of the paper should be left side of the scanner. And press scan button, you will see the green light will be blink and a voice of scanner you will hear. After 30 seconds light will stop blinking, Next time when you will turn on your printer, it will not print test page.
Sep 24, 2007 | HP PSC 1410 All-In-One InkJet Printer
My printer keeps printing the test page every time it's switched on
I had the same problem and it was driving me crazy until I did this. Please follow exactly and IN ORDER.
Dec 23, 2006 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1510 All-In-One InkJet Printer Logo
408 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
