This timer was installed for outdoor lighting and the timer stopped working after 1 season. Where can I get a replacement? The size has to be small enough to fit inside the electrical box, checked other outdoor timer such as in Home Depot and they are too large.
Timer brand and model are not identified.
Some timers are rated for incandescent light bulbs, while other timers are rated for CFL incandescent and all types of loads.
Open following links to help identify in-wall timer:
http://waterheatertimer.org/Programmable.html
http://waterheatertimer.org/Woods-timers-and-manuals.html
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: Our church has a Tork DW200A outdoor lighting
Here is the manual: http://www.midwestair.com/pdf/tork-dw200a-timer.pdf
SOURCE: how do you set a older outdoor noma light timer
Hi.
See the instructions below in PDF format, instructions are for Noma two buttons heavy duty outdoor timer. Some model may be different in shape:
24-Hour
Heavy Duty Outdoor Timer
Regards.
Ginko.
SOURCE: I bought a place with intermatic malibu outdoor
Malibu low-voltage light fixtures come equipped with a quick-connect that is pressed onto the power cable to make connection to the wires within it. These quick-connects are handy, but they are also relatively fragile, subject to shorting/disconnections, and nearly impossible to repair. I have spliced a replacement connector's wire leads onto the wire leads from a broken fixture, but the connectors are nearly impossible to find (I remove mine from fixtures that are beyond repair). Perhaps the simplest and most effective repair is to strip small sections of the power cable, splice the fixture wire leads onto the cable (don't be overly concerned about matching polarity), and seal the splice with electrical tape and a silicone sealant.
I hope this information helps.
Bill B.
SOURCE: I need a user manual for the Heath Zenith outdoor
You can download and print the manual, at no cost, here:
http://heath-zenith.hcents.com/data/manuals/595-5578-08.pdf
Bill B.
SOURCE: WHERE CAN I FIND REPLACEMENT PLASTIC MOTION
To be honest with you... you can find new energy efficient, three lamp, two light level, motion with photo controlled security fixtures for $30.00 at Costco, Home Depot or Lowes. Where a new motion detector will cost $10.00 and takes about as much work to change. The lens itself will be difficult to find and is not absolutely necessary. Good Luck!
Douglas
The timer is as listed in the title manufactured by MDL Corp Model 301-0004. It is a rotating face with movable slides to adjust the on and off times and the timer plugs into an outlet inside the electrical box then the plug from the lighting system plugs into the timer. The timer has to be almost an exact size replacement or I will have to replace the whole electrical box.
