Question about KitchenAid 30 in. KGCS105GSS Gas Cooktop
Humming noise we have a four burner gas cooktop--when you put on a burner it makes a loud humming noise --sometimes when you ignite the other burners the noise goes off but sometimes it does not and you must cook with the awful noise. A friend told us it has to do with the shut off valve or the place where the gas comes up and arms off to the four burners---it vibrates or there is something loose or caught in there--a tech. guy is coming out this week to look at it hoping it can be fixed--do you have any other suggestions?
5 Suggested Answers
appldoctom
  • 311 Answers
SOURCE: Dead burner on kitchenaid gas cooktop?
it is strange that you have no gas and no spark! if you held a match to the burner and turned the burner valve on it would lite di spite a failed ignitor,but for it not to lite, the burner valve[its what the knob attaches too] would have to be blocked[thats rare]or ........i got it .....the knob is broken.thats the only thing the burner valve and the spark ignitor have in common.try a knob from another burner................again.you have spark,because others are working.spark on troubled burner would work if valve blocked at orifice outlet,and if spark failed you would still get gas they work independent of each other,[but in unison].thats why im thinking knob.its the item that works both .when you turn the knob it opens the gas valve and as the gas valve rotates by turning the knob it activates or turns the spark switch so it closes the curcit allowing the electricty to the spark moduel.hey i hope that helps a little. God bless ,tom
Posted on Feb 13, 2009
jumptrout51
  • 3361 Answers
SOURCE: spark igniters on the burners fire continuously
When cleaning, if the control switches get damp, they will react as you describe.
Unplug the appliance, use a hair dryer and attempt to dry the switches.
Leave it unplugged overnight and try them again tomorrow.
They will eventually dry and be OK.
Posted on Feb 24, 2009
SOURCE: One burner igniter fails to spark after getting wet
Each burner has its own switch to direct current to the igniter. It appears that one of the four switches burned or shorted out, while the other three survived the flood. These switches are replaceable, so that's how I'll fix the problem.
Posted on Jun 27, 2009
heatman101
  • 43501 Answers
SOURCE: We have a kitchenaid cooktop that works great
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Posted on Nov 30, 2010
Even after the burners are lit they keep on trying to ignite, sometimes all four will be clicking.
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
heatman101
Aug 31, 2011 | Wolf Range 18 in. SPR-100 Gas Cooktop
When one burner knob is turned to ignite all four burners turn on.
What do you mean by "all four burners turn on"
Some electronic ignite systems turn on on all the burners, But just the SPARK not the gas part of the burner.
Is this what you are describing?.
Jan 11, 2011 | Jenn-Air JGD8130 Gas Cooktop
My GE gas cooktop keeps making a clicking noise and one of the four burners doesn't ignite unless I light it with a match. What should I do?
the burners use a sw on the gas shaft of each burner to make the igniton work. i belive one of the sw are shorted or housing broken . replace it . / tip when I replace one i do them all .. saves time later . falure caused by spills ect and normal ware .. mm
Jul 16, 2010 | GE Profile JGP636 Gas Cooktop
A spark that causes a snapping noise when a burner is turned on.
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 26, 2010 | Viking 31 in. VGSU101 Gas Cooktop
On our 6 burner gas coocktop, the right two burners don't light
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 10, 2010 | Thermador SGS36GS Gas Cooktop
Electronic igniters will not turn off when the gas burner lites. all four igniters run untill you turn off the nob or unplug the unit
I'm dealing with this same problem. This cooktop has a dedicated simmer burner which is the only thing going on the lowest setting. This simmer burner seems to be how the igniter senses that it can stop. If it doesn't light, the igniter keeps clicking. Usually cleaning the burner will solve this. You may need to unscrew the nut holding the lower piece of the burner in place in order to clean it up.
Apr 17, 2010 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
When you turn the burner on, it makes a popping noise and will not stop.
You're gas burner has an electronic ignition that you're hearing. Sometimes they can get gunked up and become sticky. If you have been using the stovetop regularly and this problem suddenly appeared, we can assume that the power grounding and polarity are correct. If this is all true, then an igniter or igniters are either wet or dirty. Unplug the electricity and thoroughly clean the burner pieces and specifically the igniters (little separate cylinder next to each burner) with a sponge or other non-abrasive dishrag and hot soapy water. Make sure all the burners and igniters are completley dry, plug unit back into electric outlet. If problem persists,call an authorized repair person as you may need 1 or more igniters replaced.
Good luck
Jan 11, 2010 | Viking Pro Series VGRT3626B (Gas)...
Viking cooktop gas unit ignition clicks on all burners when I use
Dec 05, 2009 | Viking 37 in. DGCU165 Gas Cooktop
Whirlpool Cooktop Burners do not light
Hi Scott,
Please view the link and videos below.
http://producthelp.whirlpool.com/Cooking/Cooktops/Cooktop_Product_Assistance/Cause_of_gas_burners_not_igniting%2C_lighting%2C_clicking_or_ticking
Searching youtube can often provide many helpful videos that clearly explain how to repair such issues.
Good Luck.
Jun 02, 2017 | Whirlpool 30 in.GLT3057 Gas Cooktop
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
KitchenAid 30 in. KGCS105GSS Gas Cooktop Logo
326 people viewed this question
Top KitchenAid Cooktops Experts
vince
freddyfox
Marvin
Marvin
Are you a KitchenAid Cooktop Expert? Answer questions, earn points and help others
