Question about Empire DV-215-SG Wall Mounted Panel Heater
Thermopile where can I buy a thermocouple or thermopile for dv215-sg?
  • 833 Answers
Most thermopile/therocouple units are generic.  Remove the old one and go to a large hardware store.  The correct one will be easily found among the several available.
Posted on Nov 26, 2008
PILOT LIGHT WONT STAY LIT i CHANGED THERMOPILE
pilot flame to small
over temp safety thermostat trip
dirty connection points
thermocouple fail not the same as thermopile fail
thermopile drives the gas valve.700MV
thermocouple drives the pilot light safety system.30MV
gas valve magnet fail
check the above for any faults
Jan 19, 2016 | Kitchen Appliances - Others
Where can we find thermocouple for adru richelieu fireplace?
I apologize I do not recognize the brand but since a month has passed without an answer I can tell you we have often had to find a replacement without being able to go through a manufacturer. For a fireplace we would need you to upload pictures of the control valve because it is very common for a fireplace valve to have a thermopile and not a thermocouple. If the valve has a battery pack or a electrical plug then the chances are that you have a thermocouple but if there is not an external power source the flame is probably heating a thermopile in order to generate the power needed for the controls.
If that is the case you would need to physically bring it to a shop to be tested for the proper amount of power needed because thermopiles can have a tremendous range.
Oct 23, 2014 | World Marketing 24-3508P Thermocouple Vent...
Riva 67 fire
Just making sure you did replace the Thermopile, not thermocouple. Unless it has an external power source. The thermopile creates the power for the valve to open and close. If the pilot flame is not hitting it correctly it will not produce the power needed to hold the valve open. I would look at the thermopile placement in the pilot flame. Good luck
Sep 08, 2012 | Heating & Cooling
How to replace thermocouple in 42v50-50f
Copy following link:
http://waterheatertimer.org/How-to-replace-thermocouple.html
Rheem 42V50-50 is ordinary atmospheric-vent gas water heater with mechanical (non-electronic) gas control valve, which says that unit has ordinary thermocouple, and not thermopile.
Buy generic thermocouple from local hardware.
To replace the thermocouple you need to remove entire burner assembly from water heater, and have replacement Burner access door gasket on hand. 1-800-268-6966
Combustion door held in place with tamper-proof screws
Since the water heater problem may be more complicated than just the thermocouple, and water heater flame arresor screen may need to be cleaned, and burner parts cleaned, door gasket replaced, and gas pressure checked, and piezo electrode checked, it might be best to have qualified service technician do the work for $300.
Jul 28, 2012 | Rheem Water Heaters
I have a used sg-14 pitco that i want to use outside for my family reunionsdo i have to use a large tank oflp or can i use a 30-lb tank when i light the pilot it will not stay lit when i release the button...
You can check the voltage generated by thermopile using a voltmeter. Set the voltmeter on milli-volt setting then heat up the thermopile. When properly heated, it can generate 500 to 750 milli-volts.
May 20, 2010 | Pitco Frialator SG14 Deep Fryer
Gas fireplace will only burn for ten minutes, then shuts down, what is causing this to occur?
HI short pilot /blocked clean out .
check therompile could be low volts ,
Faulty thermocouple / burner needs a clean
Jan 29, 2010 | Heating & Cooling
Pilot won't stay lit
replace the thermocouple pretty easy looks like bare copper wire
Jan 21, 2010 | Imperial IFS40 Deep Fryer
Heater does not stay on for more than a few minutes
You may need to disassemble the pilot module and clean the orifices. It sounds like the pilot is not maintaining sufficient flame to the thermocouple or thermopile, whichever the unit has. If there is sufficient flame, then the thermocouple or thermopile may be bad. Check all connections of those two components as well.
Dec 16, 2009 | Master Heaters 160-IF
Pilot light wont stay lit when button is released
If the thermocouple is being well covered by the pilot flame, then it sounds like the thermocouple or thermopile is bad (a thermocouple and thermopile both perform the same way, but are entirely different devices. I am unsure which yours has.
Also, make sure all connections from the t-couple of generator are snug tight to the gas valve. There may also be a temperature sensor that has tripped that prevents the pilot from remaining lit. Follow the thermocouple/thermopile tubing to locate any inline sensors that may be open, preventing the signal reaching the gas valve.
Let me know if I can help more. I have not been able to find any information on this specific unit, so will have to speak in general about what to look for.
Dec 16, 2009 | Empire ECS HearthRite HB20T Heater
Heating & Cooling Logo
453 people viewed this question
Top Empire Heating & Cooling Experts
Paul Carew
rudyjoe
Level 1 Expert
vance jones
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
