Question about Zyxel P660HW-D1 Router
Ps3 not co nnectin g to p-660hw router
It sometimes picks up the Ip wirelessly but never the Dns . Pleasehelp
Hey. do the costume setup in network setup in the ps3, put everything on auto but not the dns. there you put 4.2.2.2 and 4.2.2.3. helped for me:D
Posted on Dec 25, 2008
    Genius:
  • 1,061 Answers
You need to enter the router configuration. How you do this varies by model, but usually involves typing your gateway address into a web browser. Then, you need to assign your Ps3 an internal IP address and activate port triggering or forwarding (depending on the sophistication of your device) to send information on the designated ports to the Ps3
Posted on Dec 14, 2008
The DNS error on my PS3 from LINKSYS
your wireless network should be configured to NOT broadcast the SID and a WEP key. Then after entering the address of the router manually in the network setup on the PS3, you will able to obtain an ip address from the router
Mar 16, 2010 | Sony Playstation 3 (PS3) Console
I want to hook up my ps3 using my 595u sierra wireless air card how do i do it?
You'll have to set up "Port Forwarding" on your router.
Click here to see a picture of which ports to setup under "Port Forwarding" for your router and the PS3.
Here are the settings that you should use when you setup your PS3 with a static IP:
IP Address: 192.168.1.200 (Same as the one you used for Port Forwarding)
Subnet Mask: 255.255.255.0
Default router: 192.168.1.1
Primary DNS: 192.168.1.1
Secendary DNS: 192.168.1.1
Jan 13, 2010 | NetGear WGR614 Wireless Router
I can not connect to people on my ps3 because my NAT is on strict how do i change it?
disable the firewall in the router, enable UPNP, in the router open up the following port numbers for an IP address and assign that IP manually in ur PS3.
TCP:80,443,5223, 10070-10080
UDP:3478, 3479,3658, 10070
Jan 10, 2010 | Zyxel Prestige 660HW Wireless Router...
Can not connect to internet
My first guess is that your Dlink ADSL modem is really a modem router, so you are getting double routing. Sometimes this works just fine, though, so I'm not confident that's the whole explanation.
You'll need to setup your IP plan carefully
set the D-Link modem(router?) to bridging mode & the DLink wireless router does the login to Exetel.
DLink wireless router WAN side: DHCP + login to Exetel
DLink wireless router LAN side: 192.168.0.1
Subnet 255.255.255.0
DHCP on: range 192.168.0.10 to .20
DNS Servers: 220.233.0.3, 220.233.0.4
with PC's wireless adaptor set to DHCP
so picks up eg:
IP address: 192.168.0.10
Gateway address: 192.168.0.1
Aug 03, 2009 | Computers & Internet
Connect ps3 to laptop via web and walk
Connecting PS3 to a network I have LinkSys wireless router which is working perfectly for other devices (like laptop, Xbox360, TiVO). My wireless network is configured to NOT broadcast the SID and with a WEP key. After entering this manually in the network setup on my PS3, I was able to obtain an ip address from my router, I was able to open the configureation page on my router, but connecting to the internet would fail with some kind of DNS error. The way this was resolved for me, was to enter the DNS server addresses manually in the PS3 network settings AND use tetertiary DNS server from my ISP as either the primary or the secondary DNS server. ..btw, this also fixed the similar problem I had with my PSP.. Thanks!
Jul 29, 2009 | Sony Computers & Internet
WRT54G and PS3 not accessing online service
hi,
by default the router ip will be 192.168.1.245 or 192.168.10.245 or 192.168.0.245...
please check this after connecting the router to your system thru network port.
by default password will be admin without any usernames
Mar 31, 2009 | Linksys Wireless-G WRT54G Router
Connecting wireless router to ps3
Sometimes static values solve the problem
try this solution http://www.howtofixanything.co.uk/howto-269.html
I have used this many times to solve wireless problems,
please post the result if this does not work
HPC
Jan 15, 2009 | NetGear WGR614 Wireless Router
Internet connection failed but IP address obtained.
Check to make sure that your router has gotten an IP Address from your ISP. Because you PS3 is telling you that it has an IP from your router. This means that the Router to PS3 connection has layer 3 connectivity, but what about from your router to your ISP? check that in the router by logging into the router's web page and going to the status page it should have your information from your ISP if it does not make sure that the main page is set to the proper settings either get IP automatically (Cable Modem) or Get PPPOE (DSL) connection (Make sure that your password information is correct to).
Now after checking these items make sure that you set the router up as the DNS for your network buy setting this on the status page then in your PS3 (set the DNS setting to point to your router, and set your router up as a caching DNS server).
Then power cycle the router after saving everything, and power cycle your PS3 after setting everything. This should clear up your problem.
Thank you,
Shuttle83
Oct 24, 2008 | Linksys Wireless-G Broadband Router
Cant get internet on ps3
make sure that the ip address that you are getting is a valid one and you are connected to the correct wireless network. for example, if your router's ip address id 192.168.1.1, your computer should have an ip address of 192.168.1.x. if you are getting a valid ip address and you're still getting the dns error, the thing that you can do is set a static ip address and dns to your ps3.
if you don't know the dns to use, go to the command prompt and type ipconfig/all and it'll give you a list that'll contain the dns servers. copy the dns and enter it on the ip settings of your ps3 together with the default gateway (ip address of the router), subnet mask (it's usually 255.255.255.0) and your ip address (make sure that the ip address that you'll set on the ps3 is not being used by any of your computers)
hope this'll help you and just ask me if your still having any problem
ciao!
Jul 05, 2008 | Blitzz Technology BWA711 (B3WL000900)...
Ps3 wont join network
i had a simsilar problem with my nintendo wii. i also have a mac and broadband ( but that doesn't matter). if you get into your wireless router by going to 192.168.1.254 in your safari browser. go to "wireless" settings. there is a channel selection (1-7) change it to 1. that should work. if not change to 2 etc.
Apr 15, 2007 | Sony Playstation 3 (PS3) Console
Zyxel P660HW-D1 Router Logo
137 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
