Question about Hotpoint NWXR473EV Dryer
Tumble dryer when switched on cuts power to all sockets in house
I've just replaced the belt and bearing on my Hotpoint VTD00 tumble dryer. Now, when, I switch the machine on, my RCD switch kicks in, and all appliances on the same ring main lose power. The only way I can restore power to the circuit is to disconnect the tumble dryer plug from the socket and continue using the other appliances.
Its just cost me £30 in spares (belt and bearing) to fix those issues. I now find the tumble dryer still won't work.
Any ideas as to what might be causing this problem? Is there a solution?
Many thanks,
  • Dougal01 Nov 26, 2008
    Thanks very much!
    Any chance of a picture, so I know what I'm supposed to disconnect / remove.
  • Dougal01 Dec 08, 2008
    Have tried the dryer with the heater element removed, (completely). As you said, it works (doesn't trip the RCD).
    Have purchased a new dryer as an urgency. Will buy a replacement heater as a back up dryer, when I have some spare cash, so at least I'll have a back-up.
    Thanks for your assistance.
    Word of cauction. Apparently, there are two types of heater element (£40.00 for a replacement heater element).
  • Hotpoint Master
  • 3,463 Answers
Try it with the heater disconnected, you will find it at the rear of the m/c at the bottom left behind a removable panel.
You may have to remove the top cover and the right hand side panel looking at the m/c from the front. Try it again.
I fit does not trip. then your heater is faulty.
If it still trips then you are probably going to have to call en engineer
Posted on Nov 26, 2008
How to fix belt on hotpoint dryer tdc30
Posted on Jan 25, 2009
I had the same problem after it tripped the fuse i looked in the dryer where the cloths were and saw that there was a buildup of steam in the drum. i then realised that because i was using the dryer in a very cold outhouse in the winter the water in the cloths was condensing too fast for the machine to process, this in turn caused a a backup of steam in the drum which backed up so much that the heating elements shorted out and caused the fuse to trip out. i hope this helps. after moving the dryer to a warmer part of the house i have had no problems.
Posted on Dec 08, 2008
Hotpoint tcym 750c tumble dryer serial number tcym750c6p. The wires attached to the timer control and start button have disconnected does anyone know how they go back on?
images for Hotpoint tcym 750c tumble dryer wiring
Hotpoint TCYM 750C Style - YouTube
? 3:07
Oct 8, 2012 - Uploaded by Missing Sleep
Hotpoint TCYM 750C Style. Missing Sleep ... How to replacetumble dryer belt Hotpoint, Indesit, Ariston, Creda, Proline etc - Duration: 9:36. by ...
Hotpoint tcym 750c tumble dryer serial number tcym750c6p ...
48 mins ago - SOURCE: Reconnect wiring on a Hotpoint VTD00 tumble dryer. most electric dryers have a wiring schematic on the back or inside on the back ...
Dec 03, 2015 | Hotpoint Dryers
Rear bearing
We have made a few videos on these dryers and there are some very good repair guides on these.
if you need parts please feel free to see site or contact me with the full model number of the ID plate How-to-Repair
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair Need help fixing your appliances Need help fixing your appliances
Feb 06, 2013 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
Dryer clunking noise
hi try pushing drum at the top at the back if it lifts and nocks at all its the rear bearing cover on bake held by 2 screws you will see a pin through the shaft remove this lever bearing out to replace take lid off put bearing on shaft lift drum by rear edge so you can seat bearing
Jan 27, 2013 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
Cant get top off dryer vtd00
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts Archives How to Repair Home Appliances
Jan 17, 2013 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
Hotpoint vtd00p thermostat
It could be the thermostat has burnt out or possibly the start capacitor
needs replacing
Aug 30, 2012 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
I have a hotpoint VTD00 tumble dryer and it is heating up but the drum isn't spinning and smells of burning. Thanks, Annmarie
The belt is probably worn out and is slipping,the smell is from the belt slipping on the drum.
Mar 02, 2011 | Hotpoint Dryers
Tumble dryer drum won't turn hotpoint vtd00
You are referring to the rear drum bearing that has worn away..
It means replacing the rear bearing and drum shaft.
It comes in a repair kit which you can obtain from Hotpoint.
It comes complete with fitting instructions.
Go the Hotpoint web site, and you should be able to order the parts on line.
In the menu click on>>>>Spare parts and accessories, and follow instructions.
Please ratemy solution.
Jan 31, 2010 | Hotpoint Dryers
most electric dryers have a wiring schematic on the back or inside on the back pannel of the unit it self . try too look for one there and it might help you out
Oct 30, 2009 | Hotpoint Dryers
Dryers Logo
765 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
